F-215
ZLTMM–112–75–L–D–285
LTMM–113–02–T–D
LTMM–110–02–F–D–RA
(2,00 mm) .0787"
LTMM, ZLTMM SERIES
SHROUDED HEADER & STACKER
Mates with:
SQT, SQW, ESQT, SMM
NO. PINS
PER ROW
1
LTMM
02
PLATING
OPTION
TAIL
OPTION
D
OTHER
OPTION
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?LTMM
or www.samtec.com?ZLTMM
Insulator Material:
High Temperature Nylon
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +105°C with Tin;
-55°C to +125°C with Gold
RoHS Compliant:
Yes
–“XX”
04, 05, 06, 07, 08, 10, 12,
13, 15, 17, 20, 22, 25
(Standard sizes)
02 04
(6,00)
.237
RECOGNITIONS
(2,00)
.0787
01 03
–SM
= Surface Mount
–T
–K
(2,00) .0787
(3,55)
.140
(0,51) .020 SQ
T/H
–SM
1
ZLTMM
PLATING
OPTION
Specify
LEAD
STYLE
from
chart.
–F
(0,51)
.020
–L
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
(2,00) .0787 x
No. of positions + (2,39) .094
–T
02 04
= Matte Tin
(6,00)
.237
(2,00)
.0787
01 03
(3,55)
.140
(2,00)
.0787
(4,80)
.190
(3,18)
.125
(0,38)
.015
(0,51)
.020
SQ
D
= Gold flash on post,
Matte Tin on tail
(MOQ Required)
(2,29)
.090
MIN
Note: This Series is
non-standard, non-returnable.
–TR
–RA
LEAD
STYLE
(Standard sizes)
= (7,50 mm)
.295" DIA
Film Pick &
Place Pad
(-SM only)
= Tape & Reel
(–SM only)
–SM
NO. PINS
PER ROW
(1,52)
.060
(2,00)
.0787
(7,79)
.307
–RA
04, 05, 06, 07,
08, 10, 12, 13,
15, 17, 20, 22, 25
ALSO AVAILABLE
(1,27)
.050
(4,80)
.190
(0,38)
.015
(2,29)
.090
(0,38)
.015
(0,89)
.035
(2,97)
.117
• Shrouded IDC headers
and stackers to mate with
TCSD Series. See STMM
and ZSTMM Series.
• Other sizes
• Other platings
Contact Samtec.
= Locking
Clip
(-SM only)
(Manual
placement
required)
= Right
Angle
= Matte Tin
For complete scope of
recognitions see
www.samtec.com/quality
OTHER
SOLUTIONS
–LC
–RA
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max
–F
= Gold flash
on post,
Matte Tin on tail
–L
(2,00) .0787 x
(0,51)
.020
= Polarized
Position
Leave blank for
Through-hole
(3,05)
.120
BODY
HEIGHT
(6,35)
B
.250
(OAL) MIN
BODY
HEIGHT
OTHER
OPTION
–“XXX”
–“XX”
= Body
Height
= Polarized
Position
LEAD
STYLE
–75
–62
–65
–73
–63
–66
–69
–74
–70
–71
–72
B
(OAL)
MAX BODY
HEIGHT
(9,58) 0.377
(7,42) 0.292
(10,08) 0.397 (7,92) 0.312
(10,49) 0.413 (8,33) 0.328
(12,09) 0.476 (9,93) 0.391
(14,10) 0.555 (11,94) 0.470
(15,09) 0.594 (12,93) 0.509
(15,60) 0.614 (13,44) 0.529
(17,09) 0.673 (14,94) 0.588
(17,60) 0.693 (15,44) 0.608
(21,08) 0.830 (18,92) 0.745
(21,62) 0.851 (19,46) 0.766
Note: For added mechanical stability,
Samtec recommends mechanical
board spacers be used in applications
with gold or selective gold plated
connectors. Contact ipg@samtec.com
for more information.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
