09 33 000 6122
09 33 000 6122
    HARTING(浩亭)
    HARTING - 09 33 000 6122 - Heavy Duty Connector Contact, Han E, Pin, 20 AWG, Crimp, 16 A, Copper All...
09 33 000 6122 数据手册
Han® 18 EE Size 10 B 500 V 16 A Number of contacts 18 Inserts Part No. Identification Series Crimp terminal Han® EE Male insert (M) Female insert (F) 09 32 018 3001 09 32 018 3101 Drawing Dimensions in mm Han E / EE Order contacts separately 1) Distance for contact max. 21 mm Contact arrangement View from termination side Panel cut out for inserts for use without hoods/housings Wire gauge Identification (mm ) 2 Part No. Male contacts Female contacts Crimp contacts Power contacts silver plated gold plated 0.14-0.37 0.5 0.75 1.0 1.5 2.5 3 4 *09 33 000 6127* 09 33 000 6121 09 33 000 6114 09 33 000 6105 09 33 000 6104 09 33 000 6102 09 33 000 6106 09 33 000 6107 *09 33 000 6227* 09 33 000 6220 09 33 000 6214 09 33 000 6205 09 33 000 6204 09 33 000 6202 09 33 000 6206 09 33 000 6207 0.14-0.37 0.5 0.75 1.0 1.5 2.5 4.0 *09 33 000 6117* 09 33 000 6122 09 33 000 6115 09 33 000 6118 09 33 000 6116 09 33 000 6123 09 33 000 6119 *09 33 000 6217* 09 33 000 6222 09 33 000 6215 09 33 000 6218 09 33 000 6216 09 33 000 6223 09 33 000 6221 Coding Pin 09 33 000 9954 Dimensions in mm Operation contact Identification 20 10 001 3311 * only to be used with BUCHANAN crimping tool 09 99 000 0001 and adjustment gauge 09 99 000 0203 Relay contact Crimp contact identification Identification Wire gauge no groove 0.14-0.37 mm2 AWG 26-22 no groove 0.5 mm AWG 20 1 groove* 0.75 mm AWG 18 1 groove 1. mm AWG 18 2 grooves 1.5 mm AWG 16 3 grooves 2.5 mm AWG 14 wide groove 3.0 mm AWG 12 no groove 4. mm AWG 12 * on the back crimp collar 2 2 2 2 2 2 2 Stripping length 7,5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm 7.5 mm To avoid accidental incorrect mating of adjacent connectors a coding system is required. Coding is effected – by means of a code pin. For this reason a female contact has to be inserted into the selected chamber.The code pin has to be assembled into this contact from the mating side. The opposite male contact is omitted. Crimp zone FOC contacts for 1 mm plastic fibre Drawing Crimp zone 03 . 19 20 10 001 3321 Stock items in bold type
09 33 000 6122 价格&库存
很抱歉,暂时无法提供与“09 33 000 6122”相匹配的价格&库存,您可以联系我们找货
  • 100+27.46546
  • 200+26.98538
  • 400+26.49072
库存:600
09330006122
  • 50+27.40089
库存:550
09330006122
    • 1+10.70280
    • 10+10.46520
    • 30+10.31400
    库存:19
