09032606865
09032606865
    HARTING(浩亭)
    插件,P=2.54mm
    板对板连接器 直插 针脚数:64Pin 间距:2.54mm 排数:3
09032606865 数据手册
DIN 41 612 · complementary type M-flat Number of contacts 78+2, 60+4, 42+6, 24+8 Part No. Performance levels according to IEC 60 603-2. Explanation chapter 00 Identification Number Contact of contacts arrangement Female connector with solder pins 2.9 mm 78 + 2 09 03 278 6864 09 03 478 6864b) 60 + 4 09 03 260 6864 42 + 6 09 03 242 6864 24 + 8 09 03 224 6864 09 03 224 6864 222f) (without special contacts)* Female connector with solder pins 4.5 mm (without special contacts)* Female connector with press-in pins 4.5 mm (without special contacts)* 3 2 1 78 + 2 60 + 4 42 + 6 DIN Signal up to 2 A Female connectors 09 03 278 6865 Performance level 3 on request 09 03 260 6865 09 03 242 6865 24 + 8 09 03 224 6865 78 + 2 09 03 278 6830 60 + 4 09 03 260 6830 42 + 6 09 03 242 6830 24 + 8 09 03 224 6830 09 03 224 2830 Dimensions a 2.9 4.5 4.5 Solder pins Press-in pins row Order high current, high voltage, coaxial and fibre optic contacts separately, see pages 01.38 ff position Board drillings Mounting side all holes Solder Y position Press-in Y 1 ± 0.1 see recommendation page 00.25 row Board drillings depend on type and special contact loading * Pre-loaded with special contacts on request b) Connectors with snap-in clips see chapter 00 f) Railway classification NFF 16-101, Smoke index: F1, Flammability class: I2 c Type 78 + 2 25 x 2.54 = 63.50 60 + 4 19 x 2.54 = 48.26 42 + 6 13 x 2.54 = 33.02 24 + 8 7 x 2.54 = 17.78 Dimensions in mm 01 . 43
09032606865 价格&库存
很抱歉,暂时无法提供与“09032606865”相匹配的价格&库存,您可以联系我们找货
  • 20+61.95022
  • 100+58.03341
  • 260+55.51803
  • 1+107.135941+13.92506
