09110006212
09110006212
    HARTING(浩亭)
09110006212 数据手册
98 42 937 0201 HARTING Han® GND People | Power | Partnership Han® GND Han® GND - Mateable Potential Equalization The new Han® GND series now enables pluggable grounding systems Han® GND (Han® Ground) is the innovative HARTING solution for potential equalization. The new connector series makes it possible to execute grounding systems in a pluggable design for the first time. The use of connectors has been well-established in the electrical cabling of machines and systems for many years. The advantage is quick and error-free commissioning. Potential equalization lines are still being permanently connected, which is relatively time-consuming and can be subject to errors. HARTING‘s remedy: the Han® GND. The single-pole connector in the robust IP 65 plastic housing is designed for stranded wires from 10 - 35 mm² and is optionally available in crimp or axial screw termination. The latter has the advantage that the lines can be connected without a special tool. A simple screwdriver is all it takes to achieve a quick and easy reliable connection. Extra connector mating security can be provided by the use of additional locking elements that prevent unintentional opening. Fast and easy termination without any special tools robust IP 65 housing Ground connector with green-yellow colour marking 2 Protection against unintentional opening 10 5 -3 ² mm Han® GND Features • New: First connector for potential equalization • Slim, space saving design • Low cost plastic hoods and housings • Colours: green and yellow • Separate axial screw contacts can be terminated without any special tools directly to the wire. Technical characteristics Specifications DIN EN 60 664-1 DIN EN 61 984 Hoods/Housings Material - hoods/housings - seal - cable seal polycarbonate NBR polyamide Limiting temperatures -40 °C ... +85 °C Flammability acc. to UL 94 V0 Degree of protection according to DIN EN 60 529 for coupled connectors IP 65 Mechanical working life ≥ 500 mating cycles Cable diameter 7.5 - 14 mm Modules Number of contacts 1 Material polycarbonate Limiting temperatures -40 °C ... +125 °C Flammability acc. to UL 94 V0 Mechanical working life ≥ 500 mating cycles Crimp Contacts Material Surface - hard-silver plated Contact resistance Crimp terminal - wire gauge1) Axial Screw Contacts Material Surface - hard-silver plated Contact resistance Screw terminal - wire gauge1) - AWG - hexagonal driver - tightening torque copper alloy 3 µm Ag ≤ 0.3 mΩ 10 ... 35 mm² copper alloy 3 µm Ag ≤ 0.3 mΩ 10 ... 35 mm² 6 ... 2 SW 4 mm² 10 16 25 35 Nm 6 6 7 8 3 1) geometric wire gauge Han® GND Number of contacts 1 Mateable Potential Equalization Identification Hood Part-Number 09 14 001 0430 top entry Unlocking Protection 09 14 000 9938 Housing 09 14 001 0330 Hoods, cable to cable 09 14 001 0730 Gender changer / coupler 09 14 001 9901 male / male 4 Drawings Dimensions in mm Han® GND Identification Part-Number Male module (M) Female module (F) Drawings Dimensions in mm Modules order contacts separately M 09 14 001 3032 F 09 14 001 3132 Identification Wire gauge Part number (mm²) Male contact Female contact Drawing Dimensions in mm Crimp contacts* 10 09 11 000 6114 09 11 000 6214 16 09 11 000 6116 09 11 000 6216 25 09 11 000 6125 09 11 000 6225 35 09 11 000 6135 09 11 000 6235 Wire gauge Ø Stripping length (A) 10 mm² 4.3 5.5 7.0 8.2 19 mm 19 mm 19 mm 16 mm 16 mm² 25 mm² 35 mm² for stranded wire acc. to IEC 60 228 Class 5 Axial screw contacts 10-25 09 11 000 6112 09 11 000 6212 16-35 09 11 000 6113 09 11 000 6213 Stripping length 13 mm Identification Part number Drawing Dimensions in mm Hex key SW 4 for axial setscrew with grip 09 99 000 0363 Bit 3/8“ 09 99 000 0370 5 * Crimp zone acc. to DIN EN 46 235 For further information see chapter 99 (Tools) in the main catalogue „Industrial Connectors Han®“ Han® GND Assembly and construction Assembly Please use fine stranded wire (Class 5) which is recommend for the axial screw termination. 1. Do not twist the stripped wire! Please strip the wire. All suitable wire gauges have to be stripped with a length of 13 mm (acc. to Class 5 wire). Insert stripped wire into the terminal and push fully inside. Pay attention that all fine stranded wires are inserted in the contact. 13 mm stripping lenght ↺ turn clockwise Secure axial screw 6 2. Please insert suitable torque key (SW 4) into the contact from mating side and turn the axial screw clockwise. For that purpose secure the axial screw with a spanner (SW 11). Tighten the screw to the specified torque value. Han® GND Assembly and construction 3. ↺ 4. ↺ 5. Insert the installed cable through the cable gland into the Han® GND housing! Push the axial screw contact into the module until you hear an audible click, which is the indicator that the contact snaps into position. Push the module back into the housing and turn the cable gland clockwise. Mount the module in the housing with the enclosed screws. Protection against unintentional opening 1. 2. Push the unlocking protection over the opening latches to prevent an unintentional opening (the connector can only be unma ted with a separate tool). The removal of the unlocking protection can be done with a screwdriver for slotted screws (e.g. size 0.8 x 4.0). Insert the screwdriver in the unlocking protection slot and release the plastic latch until you are able to remove the unlocking protection with your fingers. 7 98 42 937 0201 www.HARTING.com
09110006212 价格&库存
很抱歉,暂时无法提供与“09110006212”相匹配的价格&库存,您可以联系我们找货
  • 1+150.800001+19.49250
  • 25+139.8724725+18.08000
  • 50+129.8191350+16.78050
  • 100+113.03444100+14.61090
  • 250+104.20499250+13.46960
库存:7
09110006212
    • 1+129.60021
    • 12+126.95509
    • 25+124.94522
    • 50+122.49797
    库存:19
