09340032701
09340032701
    HARTING(浩亭)
    Female Insert Gray 3+2+Ground Position Screw
09340032701 数据手册
Han® 3 Hv E/ES Size 10 B 830 V 16 A Number of contacts 3 + + 2 additional contacts for safe high voltage connections Han Hv E Identification Series Cage clamp terminal Han® Hv ES 1-3 Part number Male insert (M) Female insert (F) 09 34 003 2616 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2716 Cage clamp terminal Screw terminal Crimp terminal 1) Han Hv E® 1-3 Dimensions in mm " not plug compatible to screw/crimp terminal Screw terminal Drawing a 18,4 b 33,4 c 18,4 d 35,6 18,5 33,5 18 34,5 Distance for contact max. 21 mm Contact arrangement (view from termination side) Han® 3 Hv ES 09 34 003 2601 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2701 " Han® 3 Hv E Crimp terminal Han Hv E® 1-3 09 34 003 2602 "https://b2b.harting.com/ebusiness/en/ " "https://b2b.harting.com/ebusiness/en/ 09 34 003 2702 " ● Working contact ◐ Relay contact ○ Without contact Panel cut out for inserts for use without hoods/ housings Order crimp contacts separately (see page 04.16) 04 . 04 Crimp terminal and cage clamp terminal could also be used with 10 B standard hood/housing Stock items in bold type
09340032701 价格&库存
很抱歉,暂时无法提供与“09340032701”相匹配的价格&库存,您可以联系我们找货
  • 1+230.411711+29.74160
  • 100+192.06812100+24.79220
  • 250+176.04786250+22.72430
    • 1+145.07517
    • 100+139.27466
    • 500+133.45333
    库存:5
    09340032701
    • 1+325.030341+41.95500
