14FHA-SM1-GAN-ETB(HF) 数据手册
0.5mmピッチ
Emboss Tape
FHA CONNECTOR
NON-
0.5mm pitch/Connectors for FPC
Specifications –––––––––––––––––––
• Current rating: 0.5 A AC, DC
• Voltage rating: 50 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 40 mΩ max.
After environmental tests/ 30 mΩ max.
(variation from initial value)
• Insulation resistance: 50 MΩ min.
• Withstanding voltage: 200 VAC/minute
• Applicable FPC: Conductor pitch/ 0.5 mm
Conductor width/ 0.35 mm
Mating part thickness/ 0.3 ± 0.05 mm
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
This FHA connector is a renewal prduct of
current FHJ connector.
This is Non-ZIF type connector for the 0.3 mm
thickness FPC with a mounting height of
1.1 mm, small and space saving type.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout and Assembly layout
D
A
±0.05
0.8
±0.05
0.5
±0.05
±0.08
4.05
±0.05
1.3
±0.05
1.1
1.9
±0.05
0.3
±0.05
0.6
1
FHA CONNECTOR
Connector
Model No.
4
04FHA-SM1-GAN-ETB(HF)
05FHA-SM1-GAN-ETB(HF)
06FHA-SM1-GAN-ETB(HF)
07FHA-SM1-GAN-ETB(HF)
08FHA-SM1-GAN-ETB(HF)
09FHA-SM1-GAN-ETB(HF)
10FHA-SM1-GAN-ETB(HF)
11FHA-SM1-GAN-ETB(HF)
12FHA-SM1-GAN-ETB(HF)
16FHA-SM1-GAN-ETB(HF)
18FHA-SM1-GAN-ETB(HF)
20FHA-SM1-GAN-ETB(HF)
22FHA-SM1-GAN-ETB(HF)
24FHA-SM1-GAN-ETB(HF)
26FHA-SM1-GAN-ETB(HF)
28FHA-SM1-GAN-ETB(HF)
30FHA-SM1-GAN-ETB(HF)
5
6
7
8
9
10
11
12
14
16
C
18
B
A
22
24
26
1.1
Dimensions (mm)
Circuits
28
30
A
B
C
D
Q’ty/
reel
1.5
2.5
4.0
3.3
7,000
2.0
3.0
4.5
3.8
7,000
2.5
3.5
5.0
4.3
7,000
3.0
4.0
5.5
4.8
7,000
3.5
4.5
6.0
5.3
7,000
4.0
5.0
6.5
5.8
7,000
4.5
5.5
7.0
6.3
7,000
5.0
6.0
7.5
6.8
7,000
5.5
6.5
8.0
7.3
7,000
6.5
7.5
9.0
8.3
7,000
7.5
8.5
10.0
9.3
7,000
8.5
9.5
11.0
10.3
7,000
9.5
10.5
2.0
11.3
7,000
10.5
11.5
13.0
12.3
7,000
11.5
12.5
14.0
13.3
7,000
12.5
13.5
15.0
14.3
7,000
13.5
14.5
16.0
15.3
7,000
14.5
15.5
17.0
16.3
7,000
0.5
Material and Finish
D
Contact: Copper alloy, nickel-undercoated, gold-plated
Housing: Heat resisting resin, black
Reinforcement: Copper alloy, tin-plated
RoHS compliance
Note: The products listed above are supplied on embossed-tape.
Lead section dimensions of FPC
0.5(N+1)
0.5
±0.1
0.5(N-1)
0.35
0.5
±0.1
±0.04
0.3
±0.05
(5.5)
3 min.
0.5
±0.03
±0.05
±0.03
Reinforcing layer
Note: N --- Number of circuits
2
14FHA-SM1-GAN-ETB(HF) 价格&库存
很抱歉,暂时无法提供与“14FHA-SM1-GAN-ETB(HF)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.466831+0.18984
- 300+1.17870300+0.15255
- 500+1.06520500+0.13786
- 1000+0.986621000+0.12769
- 4000+0.916774000+0.11865
- 5000+0.916775000+0.11865
- 国内价格 香港价格
- 1+1.274741+0.16498
- 10+1.1612410+0.15029
- 50+0.7945350+0.10283
- 100+0.71595100+0.09266
- 500+0.66357500+0.08588
- 1000+0.637371000+0.08249
- 2000+0.619912000+0.08023
- 国内价格 香港价格
- 7000+1.396267000+0.18071
- 国内价格 香港价格
- 1+1.393491+0.18035
- 300+1.11977300+0.14493
- 500+1.01194500+0.13097
- 1000+0.937291000+0.12131
- 4000+0.870934000+0.11272
- 5000+0.870935000+0.11272
- 10000+0.8626410000+0.11165
