REVISION AG
DO NOT
SCALE FROM
THIS PRINT
NOTES:
MTMM-1XX-XX-XX-X-XXX-XX-XXX
1. C REPRESENTS A CRITICAL DIMENSION.
2. MAXIMUM ALLOWABLE BOW: 0.005[.13] IN/IN AFTER ASSEMBLY.
3. MAXIMUM PIN ROTATION IN BODY: 2°
4. MINIMUM PUSHOUT FORCE: 1LB
5. CUT PARTS WITH METAL WASHERS TOWARDS OPERATOR ALLOWING
FLASH TO BE ON POST AWAY FROM CRITICAL AREA (METAL WASHERS).
C 6. INSERT PINS SO THAT BANDOLIER MARKS ARE LIMITED IN THE POST
AREA (SEE TABLE 3).
C
TERMINAL SPEC
LEAD STYLE (SEE TABLE 1)
PLATING SPECIFICATION
(NO OF POS x .0787[2.000]) +.0000[0.000]
-.0100[0.254]
.0787 2.000 REF
02
T-1S13-XX-XX-2
OPTION
POLARIZATION
SPECIFY POS -XXX TO BE OMITTED
No OF POSITIONS
-01 THRU -50
01
.020 0.50 SQ
REF (TYP)
OPTION
**-MW: METAL WASHER
(-D & -Q BODY SPECS ONLY)
(SEE FIG 4, SHT 2)
(30 POS PER ROW MAX)
TAIL MUST BE .090[2.29] - .300[7.62]
POST HEIGHT
XXX = "A" (SEE TABLE 1)
-G: 20µ" SELECTIVE GOLD IN CONTACT AREA,
3µ" SELECTIVE GOLD ON TAIL.
-T: MATTE TIN ON CONTACT AND TAIL.
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-H: 30µ" SELECTIVE GOLD IN CONTACT AREA,
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-TM: MATTE TIN ON CONTACT AND TAIL.
-LM: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-FM: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
BODY SPECIFICATION
-S: SINGLE (TMM-50-S, SEE FIG 1)
-D: DOUBLE (TMM-50-D, SEE FIG 2, SHT 2)
-Q: QUAD (TMM-50-Q, SEE FIG 3, SHT 2)
** -MW OPTION, DO NOT DESIGN IN. SAMTEC WILL
ONLY SUPPORT EXISTING BUSINESS 02/08/2002
C "A"±.005[0.124]
(.0000[0.000] MIN)
"L"
TAIL REF
.0590 1.499
REF
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
.0787 2.000 REF
FIG 1
-S: SINGLE ROW OPTION
MTMM-1XX-02-XX-S-100 SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
TERMINAL: PHOS BRONZE
SHEET SCALE: 4:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
2MM TERMINAL STRIP ASSEMBLY
DWG. NO.
F:\DWG\MISC\MKTG\MTMM-1XX-XX-XX-X-XXX-XX-XXX-MKT.SLDDRW
BY: REIDINGER 12/01/1993
SHEET 1 OF 2
REVISION AG
04
02
01
03
.1550 3.937 REF
01
05
.3150 8.000 REF
.0787 2.000 REF
FIG 2
.0787 2.000
REF (TYP)
FIG 3
-D: DOUBLE ROW OPTION
MTMM-1XX-02-XX-D-100 SHOWN
(SAME AS FIG 1, DIFFERENT AS SHOWN)
-Q: QUAD ROW OPTION
MTMM-1XX-02-XX-Q-100 SHOWN
'A'
.090 2.29
'B'
IN PROCESS 1
SCALE 4:1
.005 0.13
MAX
DETAIL 'B'
SCALE 16 : 1
FIG 4
SQT-MW
-MW: METAL WASHER OPTION
MTMM-1XX-02-XX-X-100-MW SHOWN
(ONE PER POSITION)
(-D &-Q PODY SPEC ONLY, SEE NOTE 5)
C
+.0080
+0.203
.0590 - .0050 1.499 - 0.127
"A" REF
(SEE TABLE 1, SHT 4)
DETAIL 'A'
SCALE 8 : 1
.075 1.91 REF
IN PROCESS 2
SCALE 4:1
C BANDOLIER REF
IN PROCESS 4
(-T PLATING ONLY)
(SEE NOTE 6 & TABLE 3)
TAIL AREA
PROPRIETARY NOTE
.0050 0.127 MAX
MEASURE AT TAIL
2 MAX SWAY
(EITHER DIRECTION)
.0050 0.127 MAX
MEASURE AT TAIL
POST AREA
.090 2.29
IN PROCESS 3
SCALE 4:1
REPRESS TO PROPER TAIL DIM
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 2
MTMM-110-02-G-Q-126 价格&库存
很抱歉,暂时无法提供与“MTMM-110-02-G-Q-126”相匹配的价格&库存,您可以联系我们找货
