17340004102
17340004102
    HARTING(浩亭)
17340004102 数据手册
11. har - bus® HM CONNECTORS har-bus® HM connectors are the basis for configuring high-performing backplanes for control and industrial computer systems in 19” technology. These connectors are standardized for the CompactPCI and the VME64x bus. All connectors are designed for press-in technology, the female connectors are also available as a solder version. Ap A nw p l iecnati d uong n sppr rofo fi li e: l: CONNECTION VERBINDUNGSTYP TYPE Board to Board Cable/ Wire to Board ENVIRONMENT UMGEBUNG IP 20 IPIP65 67/ IP 67 Kabelanschlusstechnik Cable termination APPLIKATION APPLICATION Daten Data Signal hohe high performance Performance Power Daten-/ Data Übertratransfer gungsrate rate Leiterplattenanschlusstechnik PCB termination HanQuick Lock® IDC CrimpCrimp anschluss Einlöt THT SchraubScrew anschluß KäfigCage clamp zugfeder AxialAxial screw Schraubanschluß Einpress Press-in SMC Schirmung Shielding Number Polzahl,of contacts, Kontaktcontact dichte density Spannung, Voltage, working Strom current Applikationsstandard Application standard SMT Housing Gehäuseintegration integration seperates Separate Anbaugehäuse housing integriertes Integrated Anbaugehäuse housing 11. har - bus® HM CONNECTORS CONTENTS PAGE Standard Introduction 11.02 General information 11.04 Types A, B, AB, C with 5 + 2 rows Straight male connectors 11.12 Angled female connectors 11.24 Type Monoblock 47 Straight male connectors 11.28 Angled female connectors 11.30 Types D, E, DE with 8 + 2 rows – Straight male connectors 11.32 SMC (Surface Mount Compatible) types A, B, AB, C with 5 + 2 rows – Angled female connectors 11.35 General information 11.40 Angled male connectors 11.42 Straight female connectors 11.44 har-bus HM Power Accessories Coding keys 11.45 Shrouds 11.46 Guiding system 11.51 Customer request form 11.52 tooling see chapter 20 11 01 11. har - bus® HM CONNECTORS HARD METRIC CONNECTORS har-bus® HM IN 2.00 mm PITCH har-bus® HM connectors are the basis for configuring high- connectors are offered for Pin in Hole Intrusive Reflow (PiHIR) performing backplanes for control and industrial computer technology as well. systems in 19” technology. The high current har-bus® HM Power connector complies with the HARTING offers 5 row and 8 row 2 mm hard metric connectors OBSAI specification V1.1. This very compact connector can be har-bus® HM according to IEC 61076-4-101. The product family loaded with up to four contacts, each contact carrying up to 23 A includes all standard types such as all variants for CompactPCI, at 70 °C (in OBSAI configuration). The connector is offered in four inclusive Hot Swap and CTI (Computer Telephony Integration). lengths to allow hot swapping. The right-angled male connectors The modules are defined as the 5+2 row types A, B, AB and C and are available for press-in and for PiHIR soldering. the 8+2 row types D, E and DE. All male and female connectors Accessories and press-in tooling are available for all connectors. har-bus HM are available with press-in terminations. Moreover the female 11 02 SPECIFIC FE ATURES OF THE PRODUC T R ANGE COMBINED STYLE FOR CompactPCI: Additional to the standard insulator types according to the specification there is a Monoblock available, especially for CompactPCI applications. It unites the type A and the type B22 in one connector. With the Monoblock, only one connector is necessary for a standard configuration of a 3U module card which offers a cost advantage in the production process and logistics. “NEEDLE-EYE” PRESS-IN TECHNOLOGY: The har-bus® HM press-in zone is based on the industry renowned needle-eye technology. Its special design allows for compensation of tolerances of pcb surface properties (e.g. superfluous tin plating). The excessive material is displaced within the plated through hole, whereby a gas-tight and corrosion resistant har-bus HM electrical connection is assured. INTERNATIONAL STANDARD: The har-bus® HM connectors are designed to meet the PICMG 2.x specification and can be used in CompactPCI. CompactPCI is a common standard e.g. for industrial computers. 11 03 Technical characteristics Design according : IEC 61 076 - 4 - 101 Approvals Underwriters Laboratories Inc.® : Number of contacts : 55 – 220 signal (77 – 308 fully shielded); or customised Contact spacing : 2.00 mm Working current : 1 A @ 70 °C (80 % derating) Test voltage Ur.m.s. : AC 750 V min. Contact resistance : 20 mΩ max. Insulation resistance : 10 GΩ min. Temperature range : – 55 °C … + 125 °C Durability as per IEC 61076-4-101 : Performance level 2 = 250 mating cycles in total. with their respective ratings documented in file E 102079 First 125 mating cycles, then 4 days gas test using 0.5 ppm SO2 and 0.1 ppm H2S (at 25 ± 2 °C and 75 ± 3 % humidity). Measurement of contact resistance. The remaining 125 mating cycles are subject to measurement of contact resistance and visual inspection. No abrasion of the contact finish through to the base material. No functional impairment. har-bus HM Performance level 1 = 500 mating cycles in total. First 250 mating cycles, then 10 days gas test using 0.5 ppm SO2 and 0.1 ppm H2S (at 25 ± 2 °C and 75 ± 3 % humidity). Measurement of contact resistance. The remaining 250 mating cycles are subject to measurement of contact resistance and visual inspection. No abrasion of the contact finish through to the base material. No functional impairment. Termination technique : compliant press-in Mating force : 0.75 N/pin max. Withdrawal force : 0.15 N/pin min. Materials Mouldings : Thermoplastic resin, glass-fibre filled, UL 94-V0 Contacts : Copper alloy Contact surface Contact zone male Contact zone female Press-in zone : Au/PdNi/Ni, contacts are treated with Bellcore recommended lubricant (PPE) : Au/Ni, contacts are treated with Bellore recommended lubricant (PPE) : Ni 11 04 Packaging : Tube Recommended configuration of plated through holes Due to the high deformation capability and resilience of press-in contacts, they can be easily and repeatedly removed in case of repairs without impairment to their functioning. press-in contacts are extremely versatile and offer a reliable electrical contact, therefore they are especially well suited for applications with these surfaces. Please contact us for detailed test reports. chem. Sn pure Cu Pd Benefits of press-in technology Au Thermal shocks associated with the soldering process and the risk of the board malfunction are avoided. L No need for the subsequent cleaning of the assembled pcb’s L Unlimited and efficient processing of partially goldplated pins for rear I/O - manual soldering is no longer necessary! Recommended configuration of plated through holes Ag Fig. 1: Press-in zone in plated through hole In addition to the hot-air-level (HAL), other pcb surfaces are getting more important. Due to their different properties, such as mechanical strength and coefficient of friction we recommend the following configuration of pcb through holes. Tin plated PCB (HAL) acc. EN 60 352-5 Hole-Ø Cu Sn Plated hole-Ø 0.7±0.02 mm min. 25 μm max. 15 μm 0.60-0.65 mm Chemical tin plated PCB Hole-Ø Cu Sn Plated hole-Ø 0.7±0.02 mm min. 25 μm min. 0.8 μm 0.60-0.65 mm Au / Ni plated PCB Hole-Ø Cu Ni Au Plated hole-Ø 0.7±0.02 mm min. 25 μm 3-7 μm 0.05-0.12 μm 0.60-0.65 mm Silver plated PCB Hole-Ø Cu Ag Plated hole-Ø 0.7±0.02 mm min. 25 μm 0.1-0.3 μm 0.60-0.65 mm Hole-Ø Cu Plated hole-Ø 0.7±0.02 mm min. 25 μm 0.60-0.65 mm OSP copper plated PCB PCB board thickness: ≥ 1.4 mm Hole-Ø Fig. 2: Recommended configuration of plated through holes, valid for har-bus HM L Cu e.g. Sn Plated hole-Ø 11 05 Contacts for male connectors HARTING offers 13 contact lengths for male connectors: the standard mating length of 8.2 mm, pre-leading contacts with 9.7 mm and extra long contacts preferred for shielding with 11.2 mm mating length. On the termination side the standard length is 3.7 mm. With the three termination lengths of 13.0, 14.5 and 16.0 mm even for rear I/O applications different mating levels are possible, depending on the pcb thickness and shroud height. har-bus HM Contact dimensions [mm] Circuit density When using the specified diameter of the finished through hole according to IEC 61076-4-101 (0.6 ± 0.05 mm) with an appropriate annular ring, the remaining distance between the rings is about 1 mm. Under the condition that the width of the track and the space between should be equal, two tracks of 0.2 mm width or three tracks of 0.14 mm width can be placed between two rings. Typical designs are shown in the drawing on the right side. 11 06 For the standard termination length, an extra short contact for special applications with a mating length of 7.2 mm is available. The different contact lengths are designated with letters to identify them in the configurations. For special loadings please use the customer request form at the end of this chapter. All contacts are offered with press-in termination ‘eye of the needle’. In accordance with the application they can be delivered in performance level 1 or 2. Typical configurations on pcb m 50 All HARTING connectors can be assembled end to end in any configuration. 110 signal contacts f Type A General rules: m CompactPCI 3U 220 signal contacts 94 f Type B Type A m CompactPCI 3U 220 signal contacts 94 f Type Monoblock 47 m 100 220 signal contacts Type A • Type C connectors must be assembled at the end of a connector stack, to achieve polarisation and avoid mismating. • To ensure the correct slot position of connector stacks coding can be added with type A connectors. • Starting with an type A module (50 mm) any module can be added within the above recommendation (see typical examples shown in the diagram). m = male connector f = female connector Type A har-bus HM f • Type B connectors should always be used in combination with an A type and/or C type connectors that are fitted with alignment features. m 213 495 signal contacts f Type A Type B Type A Type B Type C m CompactPCI 6U 535 signal contacts 226 f Type B Type A Type B Type B Type A m CompactPCI 6U 535 signal contacts 226 f Type Monoblock 47 Type B Type Monoblock 47 11 Dimensions [mm] 07 AB and AB-friendly connectors Improved guiding with AB-modules: In accordance with the equipment practice each connectors shall front side arrangement of have at least one A-module per slot to ensure that the connector can accommodate ± 2 mm alignment tolerances in rack systems. On some rear I/O arrangements the A-module's alignment capability cannot be utilised, because only B-modules are used for feed through. Consequently AB-modules were introduced to ensure guiding capabilities where formerly only B-modules were used. Those AB-modules represent a combination of A- and B-modules and are specified in CompactPCI by PICMG 2.0 Rev. 3.0 for certain rear I/O applications. The AB-female connector mates either with an AB-shroud or with AB-male connectors. The centered pin positions of the shielding rows of male connectors are simply equipped with short spill contacts (if standard connector and shroud are used). This prevents that the guiding peg of the female AB-module stubbing on the feed through contacts of the front side's fixed connector. These fixed connector loadings are called AB-friendly. The AB-male connector will not be equiped with shielded contacts in the centre where the guiding peg will engage. har-bus HM The AB-modules have guiding pegs similar (but not mating compatible to prevent mismating) to those of the A-module providing the same proven mating tolerances of ± 2 mm. The AB-modules have no coding center but are fully equiped with contacts in order to maintain the full density as per the B-modules. daughtercard 11 08 Fig. 3: CompactPCI 6U configuration backplane rear I/O board CompactPCI ® – general information CompactPCI ® as a standard is maintained and enhanced by the PCI Industrial Computer Manufacturers Group (PICMG®). It defines a combination of the electrical and logical specifications of the PCI standard and the mechanical specifications of the IEEE 1101 and IEC 60297 series of standards. The board connector has been developed from the IEC 610764-101 series of 2.0 mm connectors. The mounting location and dimensions for the 2.0 mm connectors are specified in IEEE 1101.11. Some additional mechanical definitions for 2.0 mm connectors in the Eurocard format are being specified in the VITA 30 draft. Slave or peripheral boards need J1/P1 as a minimum, master or system boards need both J1/P1 and J2/P2 as a minimum. Backplanes should always have the full complement of Other international standards are listed in the CompactPCI ® standard for environmental and connectors to be compatible with any type of board. As opposed to the CPCI standard (pins numbered from bottom to top), the contact numbers on the connector are numbered from top to bottom (according to the IEC standard). 233.35 mm 110 Pins, Type A J4 The front panel of CPCI cards may be equipped with additional keying pegs to code individual board types. There is also an extended pin length to remove any electro static charge before contacts on the rear connnectors mate. This pin also functions as a mechanical guide to position the board as straight as possible for insertion. This prevents pin bending and lowers the insertion force. 95 Pins, Type B19 J3 110 Pins, Type B22 J2 100 mm 110 Pins, Type A J1 160 mm related specifications. This gives CompactPCI ® a solid foundation of international standards and practices for mechanical robustness. The board format is either a 3U or a 6U Eurocard as defined in IEC 60297. There are two or five connectors specified for 3U or 6U boards respectively. Connectors are numbered from J1/P1 through J5/P5 (bottom to top) on the board or backplane. Some applications could require up to 500 pins to be pushed into sockets simultaneously. har-bus HM 110 Pins, Type B22 J5 Connectors for high availability applications (hot swap) come with 3 different lengths of pins for a staged sequence of mate or break of contact. Connector J1/P1 carries the signals for a 32 bit PCI bus (see table of contact assignments for J1/P1). Connector J2/P2 on a system card has the additional signals for a 64 bit PCI bus and some user-defined I/O (see table of contact assignments for J2/P2). On slave cards all of J2/P2 might be user-defined I/O except the top row which carries the signals for geographical addressing. J3/P3 should be reserved for other system bus definitions. J4/P4 and J5/P5 are used for I/O or secondary buses, e.g. H.110 in telecom applications or for bridges into other buses like VMEbus. This is used to accommodate two bus platforms in one card cage on one backplane. 11 09 har-bus HM CompactPCI ® – general information Contact assignment on CompactPCI ® system position (J1/P1) Contact assignment on CompactPCI ® system position (J2/P2) In mechanical terms J1/P1 is a 25x5 matrix of contacts. Three rows of 5 contacts (rows 12 - 14) are not used for electrical contacts. Instead, plastic keys of different orientation and configuration are used to key board locations as to system or peripheral slot, voltage options, etc. All connectors used for CompactPCI ® are based on a 7 column pitch. The inner 5 columns are used for logic signals and power. The outer columns on either side are reserved for shielding or ground. J2/P2 is a shortened connector with only 22 rows of contacts instead of 25 rows for a standard size. HARTING now offers monolithic versions with J1/P1 and J2/P2 combined in one single connector. This combination together with some space left on the card to fit into guide rails makes maximum use of the 100 mm rear edge of the 3U Eurocard. On a 6U card this connector setup is repeated on J4/P4 and J5/P5. The J3/P3 connector is a shortened version of the 2.0 mm connector with 19 rows of 5 signal contacts. 11 10 The size results from the height of a 6U board (233 mm) which is more than double the height of a 3U board. Executive Member VME64x – general information In VMEbus systems it is possible to use custom connectors in the J0/P0 area (e.g. coax connectors). To prevent problems with non-mating backplanes it is strongly recommended to use front panel keying. The IEEE 1101 documents J0/P0 can also be used with rear transition modules for pluggable I/O cabling. As mentioned above, the contacts on this connector may be bussed. One example is the ATM CellBus, which is in the process of being standardised. The bus on J0/P0 connectors might actually be a plug-on mezzanine backplane rather than conducting traces integrated into the backplane itself. har-bus HM The VMEbus has evolved over a period of more than 25 years to become the leading bus architecture in open industrial applications. The specification is an ANSI norm, the original specification has been extended to become a draft standard VME64x ANSI/VITA 1.1-1997. This draft standard includes the specification for the 5-row DIN compatible connector (IEC 61076-4-113) and for a centre connector J0/P0 on 6U VME cards, which is identical to J3/P3 in CompactPCI ® systems. The 2.0 mm J0/P0 connector in VME64x systems is used for additional I/O, for new high speed sub busses or I/O for mezzanine modules, e.g. IP modules on VMEbus boards. The connector is placed on the Eurocard to work in combination with the non-metric original VMEbus connectors DIN 41 612 type C or the newer 5-row connector har-bus® 64. The mounting location and dimensions for the J0/P0 VMEbus connector (IEC 61076-4-101) is specified in IEEE 1101.11. The VMEbus 2.0 mm connector uses 5 columns of signal contacts and optional two additional outer columns on either side for shielding. All 95 signal contacts are user defined. 11 11 Type A Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Type A 110 8.2 3.7 17 01 110 1201 17 01 110 2201 132 / 8.2/ 11.2 3.7 17 01 132 1203 17 01 132 2203 Type A Type A har-bus HM / 132 8.2/ 11.2 3.7/ 13.0/ 16.0/ 17 01 132 1007 17 01 132 2007 154 / 8.2/ 11.2 3.7 17 01 154 1201 17 01 154 2201 110 9.7 3.7 17 01 110 1204 17 01 110 2204 154 / 9.7/ 11.2 3.7 17 01 154 1205 17 01 154 2205 Type A Type A Type A 11 12 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.14 Contact configuration Type A Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type A 110 8.2 13.0 17 01 110 1402 17 01 110 2402 154 / 9.7/ 11.2 /14.5/ 16.0 17 01 154 1001 17 01 154 2001 154 / 8.2/ / 9.7/ 11.2 3.7 17 01 154 1203 17 01 154 2203 154 / 9.7/ 11.2 16.0 17 01 154 1604 17 01 154 2604 154 / 8.2/ / 9.7/ 11.2 16.0 17 01 154 1603 17 01 154 2603 154 / 8.2/ / 9.7/ 11.2 3.7 17 01 154 1204 17 01 154 2204 Type A Type A har-bus HM CompactPCI Position P1 Type A CompactPCI Position P4 Type A CompactPCI Position P4 Type A CompactPCI hot swap Position P1 11 13 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.14 Type A Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type A CompactPCI computer telephony Position P4 100 / 8.2/ / 9.7/ 11.2 /13.0/ /14.5/ 16.0 17 01 100 1001 17 01 100 2001 100 / 8.2/ / 9.7/ 11.2 3.7 17 01 100 1201 17 01 100 2201 Type A Connector dimensions [mm] har-bus HM Datum plane Contact dimensions [mm] depth CompactPCI computer telephony Position P4 Row Position Row Board drillings Position Row 11 14 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 All holes Type B Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type B25 125 8.2 3.7 17 02 125 1201 17 02 125 2201 150 / 8.2/ 11.2 3.7 17 02 150 1201 17 02 150 2201 175 / 8.2/ 11.2 3.7 17 02 175 1201 17 02 175 2201 125 / 9.7/ 11.2 3.7 17 02 125 1205 17 02 125 2205 175 / 8.2/ / 9.7/ 11.2 3.7 17 02 175 1202 17 02 175 2202 175 / 8.2/ 11.2 13.0/ 16.0/ 17 02 175 1006 17 02 175 2006 Type B25 har-bus HM Type B25 Type B25 Type B25 Type B25 11 15 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.18 Type B Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Type B22 110 8.2 3.7 17 04 110 1201 17 04 110 2201 154 / 8.2/ 11.2 3.7 17 04 154 1201 17 04 154 2201 154 / 9.7/ 11.2 3.7 17 04 154 1203 17 04 154 2203 132 / 8.2/ / 9.7/ 11.2 /13.0/ /14.5/ 16.0 17 04 132 1001 17 04 132 2001 154 / 9.7/ 11.2 / 3.7/ 16.0 17 04 154 1010 17 04 154 2010 / / 3.7/ /14.5/ 16.0 17 04 154 1002 17 04 154 2002 Type B22 Type B22 har-bus HM CompactPCI Position P2 Type B22 CompactPCI computer telephony Type B22 CompactPCI AB friendly Type B22 CompactPCI AB friendly 154 9.7/ 11.2 11 16 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.18 Contact configuration Type B Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type B19 VME Position J0 95 8.2 3.7 17 05 095 1201 17 05 095 2201 133 / 8.2/ 11.2 3.7 17 05 133 1201 17 05 133 2201 133 / 9.7/ 11.2 3.7 17 05 133 1203 17 05 133 2203 95 8.2 13.0 17 05 095 1401 17 05 095 2401 133 / 9.7/ 11.2 / 3.7/ 16.0 17 05 133 1005 17 05 133 2005 133 / 8.2/ 11.2 16.0 17 05 133 1602 17 05 133 2602 Type B19 VME Position J0 Type B19 har-bus HM VME Position J0 Type B19 VME Position J0 Type B19 CompactPCI AB friendly Position P3 Type B19 Compact PCI Position P3 VME Position J0 11 17 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.18 Type B Male connectors, straight Dimensions in mm Contact dimensions [mm] Connector dimensions [mm] Datum plane depth Drawing Row Position Row Board drillings har-bus HM Position Row Contact positions 19 22 25 11 18 x1 x2 37.9 43.9 49.9 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) All holes Type AB Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type AB25 125 8.2 3.7 17 15 125 1201 17 15 125 2201 Type AB25 169 / 8.2/ 11.2 3.7 17 15 169 1201 17 15 169 2201 169 / 8.2/ 11.2 13.0/ 16.0/ 17 15 169 1003 17 15 169 2003 Type AB25 Position har-bus HM depth Connector dimensions [mm] Datum plane Contact dimensions [mm] Row Row Board drillings All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 11 19 Type AB Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type AB22 110 8.2 3.7 17 14 110 1201 17 14 110 2201 146 / 8.2/ 11.2 3.7 17 14 146 1201 17 14 146 2201 146 / 9.7/ 11.2 16.0 17 14 146 1601 17 14 146 2601 Type AB22 Type AB22 har-bus HM Position Row Row Board drillings All holes Position Row 11 20 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 depth Connector dimensions [mm] Datum plane Contact dimensions [mm] Type AB Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type AB19 95 8.2 3.7 17 13 095 1201 17 13 095 2201 127 / 8.2/ 11.2 3.7 17 13 127 1201 17 13 127 2201 127 / 9.7/ 11.2 16.0 17 13 127 1601 17 13 127 2601 Type AB19 har-bus HM Connector dimensions [mm] depth Contact dimensions [mm] Datum plane Type AB19 Row Position Row Board drillings All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 11 21 Type C Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Type C 55 8.2 3.7 17 03 055 1201 17 03 055 2201 77 / 8.2/ 11.2 3.7 17 03 077 1201 17 03 077 2201 55 9.7 3.7 17 03 055 1202 17 03 055 2202 77 / 9.7/ 11.2 3.7 17 03 077 1202 17 03 077 2202 55 8.2 13.0 17 03 055 1401 17 03 055 2401 66 8.2/ 11.2/ 13.0/ 16.0/ 17 03 066 1001 17 03 066 2001 Type C har-bus HM Type C Type C Type C Type C 11 22 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.23 Contact configuration Type C Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type C 77 / 8.2/ 11.2 / 3.7/ 13.0 17 03 077 1001 17 03 077 2001 77 / 8.2/ 11.2 16.0 17 03 077 1601 17 03 077 2601 har-bus HM Connector dimensions [mm] depth Contact dimensions [mm] Datum plane Type C Row Position Row Board drillings All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 11 23 Type A Female connectors, angled Identification No. of contacts Contact length [mm] termination side 110 3.4 17 21 110 1101 17 21 110 2101 110 3.4 17 21 110 1102 17 21 110 2102 Type A Type A with upper shield CompactPCI Positions J1, J4 Part number Lower shield for type A connectors 17 21 000 4102 Type A with split upper shield CompactPCI computer telephony Position J4 90 3.4 17 21 090 1103 17 21 090 2103 Lower shield for type A connectors (rows 1 – 5) CompactPCI computer telephony 17 29 000 4102 Lower shield for type A connectors (rows 15 – 25) har-bus HM CompactPCI computer telephony 17 23 000 4102 Dimensions [mm] Without shielding Position With shielding Position Row Row Board drillings Board drillings All holes Position 11 24 Row Position Row All holes Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 * hole on even contact numbers only needed for lower shielding Type B Female connectors, angled Identification Type B19 VME, Position P0 Type B19 with upper shield CompactPCI, Position J3 – VME, Position P0 No. of contacts Contact length [mm] termination side 95 3.4 17 25 095 1101 17 25 095 2101 95 3.4 17 25 095 1102 17 25 095 2102 Lower shield for type B19 connectors 17 25 000 4102 Type B22 Type B22 with upper shield CompactPCI, Positions J2, J5 110 3.4 17 24 110 1101 17 24 110 2101 110 3.4 17 24 110 1102 17 24 110 2102 Lower shield for type B22 connectors 17 24 000 4102 Type B25 Type B25 with upper shield 125 3.4 17 22 125 1101 17 22 125 2101 125 3.4 17 22 125 1102 17 22 125 2102 Lower shield for type B25 connectors x1 37.9 43.9 49.9 x2 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) Without shielding Dimensions [mm] har-bus HM 17 22 000 4102 Contact positions 19 22 25 With shielding Position Position Row Row Board drillings Part number All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Board drillings All holes Position Row 11 25 * hole on even contact numbers only needed for lower shielding Type AB Female connectors, angled Identification No. of contacts Contact length [mm] termination side Type AB19 95 3.4 17 33 095 1101 17 33 095 2101 Type AB19 with upper shield 95 3.4 17 33 095 1102 17 33 095 2102 CompactPCI, Position RJ3 Lower shield for type AB19 connectors 17 33 000 4102 Type AB22 110 3.4 17 34 110 1101 17 34 110 2101 Type AB22 with upper shield 110 3.4 17 34 110 1102 17 34 110 2102 CompactPCI, Positions RJ2, RJ5 Lower shield for type AB22 connectors 17 34 000 4102 Type AB25 125 3.4 17 35 125 1101 17 35 125 2101 Type AB25 with upper shield 125 3.4 17 35 125 1102 17 35 125 2102 har-bus HM Lower shield for type AB25 connectors 17 21 000 4102 Contact positions 19 22 25 Position Without shielding Board drillings Dimensions [mm] x2 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) x1 37.9 43.9 49.9 Position With shielding Row Row All holes Position 11 26 Part number Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Board drillings All holes Position Row * hole on even contact numbers only needed for lower shielding Type C Female connectors, angled Identification No. of contacts Contact length [mm] termination side 55 3.4 17 23 055 1101 17 23 055 2101 55 3.4 17 23 055 1102 17 23 055 2102 Part number Type C Type C with upper shield Lower shield for type C connectors Without shielding Dimensions [mm] With shielding Position Position Row Row Board drillings har-bus HM 17 23 000 4102 Board drillings All holes All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Position Row 11 27 * hole on even contact numbers only needed for lower shielding Type Monoblock 47 Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Type Monoblock 47 220 8.2 3.7 17 06 220 1201 17 06 220 2201 308 / 8.2/ 11.2 3.7 17 06 308 1201 17 06 308 2201 220 9.7 3.7 17 06 220 1202 17 06 220 2202 308 / 8.2/ / 9.7/ 11.2 3.7 17 06 308 1202 17 06 308 2202 308 / 8.2/ / 9.7/ 11.2 3.7 17 06 308 1203 17 06 308 2203 232 / 8.2/ / 9.7/ 11.2 3.7 17 06 232 1201 17 06 232 2201 Type Monoblock 47 har-bus HM Type Monoblock 47 Type Monoblock 47 CompactPCI Positions P1 and P2 Type Monoblock 47 CompactPCI hot swap Type Monoblock 47 CompactPCI computer telephony 11 28 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Connector dimensions see page 11.29 Contact configuration Type Monoblock 47 Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type Monoblock 47 CompactPCI I/O 308 / 8.2/ / 9.7/ 11.2 / 3.7/ 16.0 17 06 308 1001 17 06 308 2001 308 / 9.7/ 11.2 / 3.7/ 16.0 17 06 308 1005 17 06 308 2005 Type Monoblock 47 Connector dimensions [mm] Row har-bus HM Datum plane Contact dimensions [mm] depth CompactPCI AB friendly Positions P4 and P5 Position Row Board drillings Position All holes Row 11 29 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 Type Monoblock 47 Female connectors, angled Identification Type Monoblock 47 No. of contacts Contact length [mm] termination side 220 3.4 17 26 220 1101 17 26 220 2101 220 3.4 17 26 220 1102 17 26 220 2102 200 3.4 17 26 200 1103 17 26 200 2103 Type Monoblock 47 with upper shield Type Monoblock 47 with upper shield CompactPCI computer telephony Lower shield for type Monoblock 47 connectors Part number 17 26 000 4102 Lower shield for type Monoblock 47 connectors (rows 1 – 22) 17 24 000 4102 CompactPCI computer telephony Lower shield for type Monoblock 47 connectors (rows 23 – 27) 17 29 000 4102 CompactPCI computer telephony har-bus HM Lower shield for type Monoblock 47 connectors (rows 37 – 47) 17 23 000 4102 CompactPCI computer telephony Without shielding With shielding Position Position Row Row Board drillings Board drillings All holes Position Row Position Row All holes 11 30 Dimensions [mm] Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 * hole on even contact numbers only needed for lower shielding har-bus HM Notes 11 31 Type D Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type D 176 8.2 3.7 17 11 176 1201 17 11 176 2201 220 / 8.2/ 11.2 3.7 17 11 220 1201 17 11 220 2201 220 / 9.7/ 11.2 /14.5/ 16.0 17 11 220 1001 17 11 220 2001 Type D Connector dimensions [mm] depth Contact dimensions [mm] Datum plane har-bus HM Type D Row Position Row Board drillings Position Row 11 32 Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 All holes Type E Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type E 200 8.2 3.7 17 12 200 1201 17 12 200 2201 250 / 8.2/ 11.2 3.7 17 12 250 1201 17 12 250 2201 250 / 9.7/ 11.2 /14.5/ 16.0 17 12 250 1001 17 12 250 2001 Type E har-bus HM Connector dimensions [mm] depth Contact dimensions [mm] Datum plane Type E Row Position Row Board drillings All holes Position Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 11 33 Type DE Male connectors, straight Identification Number Contact length [mm] of mating termination contacts side side Part number Contact configuration Type DE 200 8.2 3.7 17 10 200 1201 17 10 200 2201 244 / 8.2/ 11.2 3.7 17 10 244 1201 17 10 244 2201 244 / 9.7/ 11.2 /14.5/ 16.0 17 10 244 1001 17 10 244 2001 Type DE Connector dimensions [mm] Position Row Row Board drillings All holes Position 11 34 Row Thin print part numbers: performance level 1 Bold print part numbers: performance level 2 depth Contact dimensions [mm] Datum plane har-bus HM Type DE Type A Female connectors, angled Identification No. of contacts Contact length [mm] termination side Part number 110 2.5 17 21 110 1801 110 2.5 17 21 110 1802 Type A Type A with upper shield Position without shielding with shielding Position Row har-bus HM Row Board drillings Position All holes Row Diameter of drillings: Diameter of plated through holes: Ø 0.7 ± 0.025 mm Ø 0.6 ± 0.050 mm Position All holes Row Dimensions [mm] All part numbers: performance level 1 11 35 Type B Female connectors, angled No. of contacts Contact length [mm] termination side Part number Type B19 95 2.5 17 25 095 1801 Type B19 with upper shield 95 2.5 17 25 095 1802 Type B22 110 2.5 17 24 110 1801 Type B22 with upper shield 110 2.5 17 24 110 1802 Type B25 125 2.5 17 22 125 1801 Type B25 with upper shield 125 2.5 17 22 125 1802 Identification without shielding with shielding Position Row Row har-bus HM Position Board drillings Diameter of drillings: Diameter of plated through holes: Position All holes Row 11 36 Contact positions 19 22 25 Ø 0.7 ± 0.025 mm Ø 0.6 ± 0.050 mm Position x1 38 44 50 x2 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) All holes Row Dimensions [mm] All part numbers: performance level 1 Type AB Female connectors, angled Identification No. of contacts Contact length [mm] termination side Part number Type AB19 95 2.5 17 33 095 1801 Type AB19 with upper shield 95 2.5 17 33 095 1802 Type AB22 110 2.5 17 34 110 1801 Type AB22 with upper shield 110 2.5 17 34 110 1802 Type AB25 125 2.5 17 35 125 1801 Type AB25 with upper shield 125 2.5 17 35 125 1802 without shielding with shielding Position Row Row har-bus HM Position Board drillings Diameter of drillings: Diameter of plated through holes: Position All holes Row Contact positions 19 22 25 Ø 0.7 ± 0.025 mm Ø 0.6 ± 0.050 mm Position x1 38 44 50 x2 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) All holes Row Dimensions [mm] All part numbers: performance level 1 11 37 Type C Female connectors, angled Identification No. of contacts Contact length [mm] termination side Part number 55 2.5 17 23 055 1801 55 2.5 17 23 055 1802 Type C Type C with upper shield without shielding with shielding Position Position Row har-bus HM Row Board drillings Diameter of drillings: Diameter of plated through holes: Ø 0.7 ± 0.025 mm Ø 0.6 ± 0.050 mm All holes All holes Position Row 11 38 Position Row Dimensions [mm] All part numbers: performance level 1 har-bus HM Notes 11 39 Power General information The Power connector is designed according to the OBSAI Specification V 1.1. It is well-suited to be used in conjunction with 2 mm connectors. The durability is according to IEC 61076-4-101 (250 mating cycles). Loaded with four power contacts, each contact can carry up to 20 A @ 70 °C / 80 % derating. With a configuration of two power contacts, GND and ENA, the current carrying capacity is even up to 23 A @ 70 °C / 80 % derating per contact. The straight female connector for the backplane is fitted with press-in contacts, the right angled male connector for daugther cards can be supplied with either, press-in or PIHIR (Pin In Hole Intrusive Reflow) termination.  Current [A] * Œ Ž Ambient temperature [°C] har-bus HM The compact, high temperature moulding can be loaded with up to four high current contacts. Four different contact lengths are available from 7.4 mm to 12.35 mm. This makes sequenced and nonsequenced loadings possible (e.g. with GND and ENA). Any other contact assignments, also partially loaded, are available on request. Œ Temperature raise  Derating Ž Derating curve at Imax x 0.8 (DIN EN 60 512-5-2) The distance between adjacent contacts is 3 mm, which enables wider pcb traces, larger solder paste areas and an improved heat dissipation. For the female backplane connector no special tooling is necessary due to the flatrock design. For the male connector HARTING offers a special press-in tool (see chapter 20). HARTING's Signal and Power connectors meet OBSAI (Open Base Station Architecture Initiative) specifications and provide a reliable and cost effective solution for connecting plug-in units to the backplane. The connector solutions available from the HARTING technology group will offer full compatibility and intermateability with base station modules. Benefits: Small form factor High current rating up to 23 A per contact (OBSAI configuration) L 3 level staggering (or even 4) L Flatrock design L Matched with 2 mm connectors L L 11 40 * Type XL on request Power Technical characteristics Design according : OBSAI System Spezifikation V 1.1 Number of contacts : up to 4 Contact spacing : 3.00 mm Clearance and creepage distances between contacts : > 2.3 mm Working current : 23 A max. (OBSAI configuration) 20 A max. (fully loaded with power contacts) Test voltage Ur.m.s. : AC 1500 V min. Contact resistance : < 1 mΩ Insulation resistance: : > 10 GΩ Temperature range : - 55 °C ... + 125 °C during reflow soldering Durability as per IEC 61 076-4-101 220 °C for 2 minutes, 260 °C max. short-term : Performance level 2 = 250 mating cycles in total. First 125 mating cycles, then 4 days gas test using 0.5 ppm SO2 and 0.1 ppm H2S (at 25 + 2 °C and 75 + 3 % humidity). Measurement of contact resistance. har-bus HM The remaining 125 mating cycles are subject to measurement of contact resistance and visual inspection. No abrasion of the contact finish through to the base material. No functional impairment. Termination technique Male connectors : Press-in or solder termination, suitable for (lead-free) pin-in-hole reflow soldering Female connectors : Press-in termination Mating force : max. 4 N / contact Withdrawal force : min. 0.5 N / contact Materials Mouldings : Thermoplastic resin, glass-fibre filled, UL 94-V0 Contacts : Copper alloy Contact surface : Selectively gold plated (contact zone) Contact styles : Standard, leading, lagging Packaging Tube : Male and female connectors Tape & Reel : On request for male solder connectors 11 41 Power Male connectors angled, with press-in termination Identification Number Contact length [mm] of termination contacts side Part number Contact loading Connector with same sized contacts 4 2.8 17 61 004 2102 Position Connector with same sized contacts 4 2.8 17 61 004 2103 Position Connector with leading/lagging contacts OBSAI configuration 4 2.8 17 61 004 2101 Position Connector with leading contact 4 2.8 17 61 004 2104 Position Connector dimensions [mm] har-bus HM Contact dimensions [mm] Board drillings Position Position All holes 11 42 1) Non-metallized drillings Type XL on request Tooling see chapter 20 2) All holes (View magnified) Power Male connectors angled, with solder (SMC) termination Identification Number Contact length [mm] of termination contacts side Part number Contact loading Connector with same sized contacts 4 2.5 17 61 004 2802 Position Connector with leading/lagging contacts OBSAI configuration 4 2.5 17 61 004 2801 Position Connector dimensions [mm] har-bus HM Contact dimensions [mm] Position Board drillings Position All holes All holes (View magnified) 11 43 1) 2) Non-metallized drillings Type XL on request Power Female connector straight, with press-in termination Identification Number Contact length [mm] of termination contacts side Part number Connector with same sized contacts 4 3.7 17 66 004 2201 Connector dimensions [mm] har-bus HM Position Position All holes Board drillings All holes 11 44 Coding keys Coding keys are used to prevent mismating of boards. • Cadmium yellow for CompactPCI to identify 3.3 V They can be inserted into the multifunctional area of bus signalling male and female connectors with special tooling. This • Brilliant blue for CompactPCI to identify 5.0 V bus can be easily done after the connectors have been signalling pressed in. • Reseda green to prevent accidental board insertion in VME64x on CompactPCI applications Coding keys have different bright and pre-defined • Strawberry red to prevent accidental board insertion RAL colours to simplify the identification. In the table in telephony applications below the colours and code numbers in acc. with the IEC 61076-4-101 are listed. They are used for the • Pastel orange for user defined bus • Nut brown for rear I/O and user I/O following applications: Coding keys for female connectors Coding key Code number Colour Part number Coding key Code number Colour Part number 3568 Pastel orange RAL 2003 17 79 000 0010 1247 Pastel orange RAL 2003 17 79 000 0020 3467 Slate grey RAL 7015 17 79 000 0012 1258 Slate grey RAL 7015 17 79 000 0022 Cadmium yellow RAL 1021 17 79 000 0013 for CPCI, 3.3 V 1278 3456 Cadmium yellow RAL 1021 17 79 000 0023 for CPCI, 3.3 V 2578 Reseda green RAL 6011 17 79 000 0014 1346 Reseda green RAL 6011 17 79 000 0024 1567 Brilliant blue RAL 5007 for CPCI, 5.0 V 17 79 000 0015 2348 Brilliant blue RAL 5007 for CPCI, 5.0 V 17 79 000 0025 1356 Blue lilac RAL 4005 17 79 000 0016 2478 Blue lilac RAL 4005 17 79 000 0026 1248 Strawberry red RAL 3018 17 79 000 0018 3567 Strawberry red RAL 3018 17 79 000 0028 1236 Nut brown RAL 8011 17 79 000 0019 4578 Nut brown RAL 8011 17 79 000 0029 All codings are in acc. with the IEC 61076-4-101 specification har-bus HM Coding keys for male connectors 11 45 Shrouds – general information HARTING's shrouds protect the pins protruding the rear side of the backplane from irregular mating tolerances, thus ensuring a quality connection. To accommodate pcb thickness, from 1.6 up to 4 mm nominal, the shrouds have integrated standoffs of corresponding height. Thus forming a one piece solution that reduces assembling cost significantly. The shroud can be mounted without the additional requirement of spacers to ensure the desired pin lengths on the rear side of the pcb. Fixing of the component is carried out on the rear post via a smooth friction fit process. har-bus HM For ease of assembly the same tooling as for the press-in connectors on the front side is utilised for assembly. 11 46 Shrouds type A Identification Type A shroud 25 positions Board thickness [mm] Part number 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 1001 17 70 000 1002 17 70 000 1003 17 70 000 1004 Dimensions Row har-bus HM Position Board thickness [mm] 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 a [mm] 3.1 ± 0.05 2.3 ± 0.05 1.5 ± 0.05 0.7 ± 0.05 Dimensions [mm] 11 47 Shrouds type B Identification Board thickness [mm] Part number 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 2001 17 70 000 2002 17 70 000 2003 17 70 000 2004 22 positions 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 4001 17 70 000 4002 17 70 000 4003 17 70 000 4004 19 positions 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 5001 17 70 000 5002 17 70 000 5003 17 70 000 5004 Type B shroud 25 positions Dimensions Row har-bus HM Position Board thickness [mm] 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 11 48 Contact positions 19 22 25 x1 [mm] 18 x 2 (= 36) 21 x 2 (= 42) 24 x 2 (= 48) x2 [mm] 38 – 0.2 44 – 0.2 50 – 0.2 x3 [mm] 38.4 – 0.2 44.4 – 0.2 50.4 – 0.2 a [mm] 3.1 ± 0.05 2.3 ± 0.05 1.5 ± 0.05 0.7 ± 0.05 Dimensions [mm] Shrouds type AB Identification Board thickness [mm] Part number 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 8001 17 70 000 8002 17 70 000 8003 17 70 000 8004 22 positions 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 7001 17 70 000 7002 17 70 000 7003 17 70 000 7004 19 positions 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 6001 17 70 000 6002 17 70 000 6003 17 70 000 6004 Type AB shroud 25 positions Dimensions Row har-bus HM Position Board thickness [mm] 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 Contact positions 19 22 25 x1 [mm] 7 x 2 (= 14) 8 x 2 (= 16) 10 x 2 (= 20) x2 [mm] 37.9 43.9 49.9 x3 [mm] 38.2 44.2 50.2 x4 [mm] 4 3 4 a [mm] 3.1 ± 0.05 2.3 ± 0.05 1.5 ± 0.05 0.7 ± 0.05 Dimensions [mm] 11 49 Shrouds type C Identification Type C shroud 11 positions Board thickness [mm] Part number 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 17 70 000 3001 17 70 000 3002 17 70 000 3003 17 70 000 3004 Dimensions Row har-bus HM Position Board thickness [mm] 1.6 ± 0.4 2.4 ± 0.4 3.2 ± 0.4 4.0 ± 0.4 11 50 a [mm] 3.1 ± 0.05 2.3 ± 0.05 1.5 ± 0.05 0.7 ± 0.05 Dimensions [mm] Guiding system Identification Part number Guide pin 17 79 000 0080 Receptacle for guide pin 4) Dimensions [mm] Guide pin Receptacle for guide pin Board drillings (View-X) 1) Non-metallised drillings 2) No tracks, except solder eyes 3) Limit area of components (valid for both pcb sides) 4) Recommended board drilling is 3.5 (-0.05) mm Recommended accessories: hexagon nut ISO 4032-M3-8 serrated lock washer DIN 6798-A-3.2 FSt General information The guide pin solution from HARTING allows safe mating under sometimes extreme conditions. This might be large and heavy boards that bow under their own weight. Also insufficiently aligned or worn out rack systems can be tolerated better with the use of HARTING's guiding system, which also reduces the potential danger of damaging cards when being forced into flexing racks. The guide pin and receptacle's design solution allows to overcome a 3 mm [.118'] offset between the backplane and the mating daughtercard. The reducing diameter of the pin (from 4.85 mm to 3.4 mm) ensures that its positioning task is smoothly transferred to the connectors as soon as they start to engage. Finally the thin diameter section of the guide pin is no longer positioned by the ferrule of the receptacle, ensuring that the pin is able to freely follow any movement imposed by the engaging connector. This ensures that there is no static stress between the connectors and the guiding system. The rugged metal designed guide pin is screwed to the backplane with standard hexagon screws. Whereas the molded receptacle is designed with four pressin pegs that can be installed to the board together with the connectors. har-bus HM 07 73 000 0280 The tooling can be ordered with the part numbers 07 79 000 0157 (top tool) and 11 07 79 000 0158 (bottom tool). 51 HARTING customer request form* Should you need a specially loaded connector for your application, please use this request form. Fill out the drawing for the desired connector style and mark each position with the required contact length (A, B, …, S, T). Type A Contact dimensions [mm] Type B (19, 22 or 25 positions) Type C har-bus HM Type Monoblock 47 Name: Performance level: n1 n2 Company: Drawing: n yes n no Address: Samples: n no n yes, quantity Volume (pcs./year): Phone: Fax: 11 52 E-Mail: * For AB types see page 11.53 For D, E and DE types see page 11.54 Special requirements: HARTING customer request form Should you need a specially loaded connector for your application, please use this request form. Fill out the drawing for the desired connector style and mark each position with the required contact length (A, B, …, S, T). Type AB (19 positions) Contact dimensions [mm] Type AB (22 positions) har-bus HM Type AB (25 positions) Name: Performance level: n1 n2 Company: Drawing: n yes n no Address: Samples: n no n yes, quantity Volume (pcs./year): Phone: Fax: E-Mail: Special requirements: 11 53 HARTING customer request form Should you need a specially loaded connector for your application, please use this request form. Fill out the drawing for the desired connector style and mark each position with the required contact length (A, B, …, S, T). Type D Contact dimensions [mm] Type E har-bus HM Type DE Name: Performance level: n1 n 2 Company: Drawing: n yes n no Address: Samples: n no n yes, quantity Volume (pcs./year): Phone: Fax: 11 54 E-Mail: Special requirements: har-bus HM Notes 11 55
17340004102 价格&库存
很抱歉,暂时无法提供与“17340004102”相匹配的价格&库存,您可以联系我们找货
  • 80+73.47305
    • 80+124.8397880+16.19786
    • 80+79.1658380+10.27170
