Han® HP Direct B
Sizes 6 B, 10 B, 16 B, 24 B
Features
Technical characteristics
Housings systen without using a bulkheasd
mounting housing on the device side
• Hoods in size 6 B, 10 B, 16 B and 24 B
Suitable for all contact inserts Han® B
Top and side entry from M20 to M40 all sizes
Optional coding by two coding elements
• Panel cut-outs compatible with standard Han® B
panel cut-outs
Specifications
DIN EN 61 984
DIN EN 60 664-1
Hoods
Material
Colour
Surface
- top coat
aluminium die-cast
RAL 7037 (grey)
powder coated
Locking element
Screw locking
Marerial
M6
stainless steel
Tightening torque
4 Nm
Housing seal NBR
Mounting Flange
Material
Colour
zinc die-cast
unpainted
Surface
electrically conductive
Coding element
Material
Color
polycarbonat
red
-40 °C ... +125 °C
Limit temperature
Protection degree acc. to
DIN EN 60 529
in locked position
IP66 / IP68 / IP69K
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495
www.HARTING.com | electric@HARTING.com
Han®
2016-08-16
Data Sheet 1159
Han® HP Direct B
Cable
Identification
Part number
entry
Drawing
Han® 6 HP Direct B
Hood
top entry
19 39 606 0445
19 39 606 0446
19 39 606 0447
19 39 606 0448
M20
M25
M32
M40
Panel cut out
Han® 6 HP Direct B
Hood
side entry
19 39 606 0545
19 39 606 0546
19 39 606 0547
19 39 606 0548
M20
M25
M32
M40
Panel cut out
Han® 10 HP Direct B
Hood
top entry
19 39 610 0445
19 39 610 0446
19 39 610 0447
19 39 610 0448
M20
M25
M32
M40
Panel cut out
Han® 10 HP Direct B
Hood
side entry
19 39 610 0545
19 39 610 0546
19 39 610 0547
19 39 610 0548
M20
M25
M32
M40
Panel cut out
Dimensions in mm
Han® HP Direct B
Cable
Identification
Part number
entry
Drawing
Han® 16 HP Direct B
Hood
top entry
19 39 616 0445
19 39 616 0446
19 39 616 0447
19 39 616 0448
M20
M25
M32
M40
Panel cut out
Han® 16 HP Direct B
Hood
side entry
19 39 616 0545
19 39 616 0546
19 39 616 0547
19 39 616 0548
M20
M25
M32
M40
Panel cut out
Han® 24 HP Direct B
Hood
top entry
19 39 624 0445
19 39 624 0446
19 39 624 0447
19 39 624 0448
M20
M25
M32
M40
Panel cut out
Han® 24 HP Direct B
Hood
side entry
19 39 624 0545
19 39 624 0546
19 39 624 0547
19 39 624 0548
M20
M25
M32
M40
Panel cut out
Dimensions in mm
Han® HP Direct B
Cable
Identification
Part number
entry
Mountimh Flange
Set 2 pieces
09 39 000 9902
Coding element
Set 4 pieces
09 39 000 9903
Drawing
Dimensions in mm
很抱歉,暂时无法提供与“19396240445”相匹配的价格&库存,您可以联系我们找货
