2002-406
2002-406
    WAGO(万可电子)
2002-406 数据手册
Data sheet  |  Item number: 2022-2202 1-conductor/1-pin double deck receptacle terminal block; Through/through terminal block; N/L; without marker carrier; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm2; gray www.wago.com/2022-2202 Color: Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 690 V Rated impulse voltage (III / 3) 6 kV Rated current 24 A Rated current (2) 28 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Open Tool Slot Push-in Connectable conductor materials Copper Nominal cross section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor, push-in termination 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG 25.08.2019    Page 1/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Strip length 10 … 12 mm / 0.39 … 0.47 inch Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross section can also be inserted via push-in termination. Total number of connection points 2 Total number of potentials 2 Number of levels 2 Type of wiring Front-entry wiring Geometrical Data Width 5.2 mm / 0.205 inch Height from upper-edge of DIN-35 rail 51.3 mm / 2.02 inch Depth 80.1 mm / 3.154 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Potential marking L/L Marking level Side marking Material Data Color gray Insulating material Polyamide 66 (PA 66) Fire load 0.245 MJ Weight 11.749 g Commercial data Product Group 18 (X-COM-System) Country of origin DE GTIN 4045454916503 Customs Tariff No. 85369010000 Approvals / Certificates Radio-Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7628 CSA C22.2 No. 158 70107915 DEKRA Certification B.V. 25.08.2019    Page 2/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 DEKRA Certification B.V. KEMA/KEUR DEKRA Certification B.V. EN 60947 71101201 KEMA/KEUR DEKRA Certification B.V. EN 61984 71101201 Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL 7628 CSA DEKRA Certification B.V. C22.2 No. 158 2437422 KEMA/KEUR DEKRA Certification B.V. EN 60947,EN 61984 71101201 LR Lloyds Register EN 60947 91/20112 (E9) Ship Approvals Logo Certificate name Approval Additional Approval Text ABS American Bureau of Shipping EN 60947 14HG1293677PDA BV Bureau Veritas S.A. EN 60947 38586/A0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR EN 60947 91/20112 25.08.2019    Page 3/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 LR Lloyds Register EN 60947 91/20112 (E9) Other Approvals Logo Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 Approval Additional Approval Text Certificate name UR Underwriters Laboratories Inc. UL 1059 E45172 UL-Approvals Logo Compatible products Insulation stop Item no.: 2002-171 Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray www.wago.com/2002-171 Item no.: 2002-172 Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray www.wago.com/2002-172 Protective Warning Marker Item no.: 2002-115 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/2002-115 General accessories Item no.: 2002-121 Adaptor Item no.: 2022-161 Start module for 1-conductor female connector; with integrated end plate; 2.5 mm²; 1-pole; 2,50 www.wago.com/2002-121 www.wago.com/2022-161 mm2; gray 25.08.2019    Page 4/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 mm2; gray Item no.: 2022-162 Start module for 1-conductor female connector; with integrated end plate; 2.5 mm²; 1-pole; 2,50 mm2; orange www.wago.com/2022-162 Item no.: 2022-164 Start module for 1-conductor female connector; with integrated end plate; 2.5 mm²; 1-pole; 2,50 mm2; blue www.wago.com/2022-164 Item no.: 2022-167 Start module for 1-conductor female connector; with integrated end plate; 2.5 mm²; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-167 Item no.: 2022-171 Center module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; gray www.wago.com/2022-171 Item no.: 2022-172 Center module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; orange www.wago.com/2022-172 Item no.: 2022-174 Center module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; blue www.wago.com/2022-174 Item no.: 2022-177 Center module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-177 Item no.: 2022-181 End module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; gray www.wago.com/2022-181 Item no.: 2022-182 End module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; orange www.wago.com/2022-182 Item no.: 2022-184 End module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; blue www.wago.com/2022-184 Item no.: 2022-187 End module for 1-conductor female connector; 2.5 mm²; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-187 Item no.: 2009-174 Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray www.wago.com/2009-174 Item no.: 2009-182 Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray www.wago.com/2009-182 Item no.: 216-241 Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; white www.wago.com/216-241 Item no.: 216-242 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-242 Item no.: 216-243 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-243 Item no.: 216-244 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-244 check ferrule Item no.: 216-246 25.08.2019    Page 5/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 216-246 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-246 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-263 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-284 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-284 Item no.: 216-286 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-286 Item no.: 2022-2291 End and intermediate plate; 1 mm thick; gray www.wago.com/2022-2291 Item no.: 2022-2292 End and intermediate plate; 1 mm thick; orange www.wago.com/2022-2292 Item no.: 2022-100 Carrier with 6 coding pins; for coding of female plugs; orange www.wago.com/2022-100 End plate Coding Marking accessories Item no.: 2002-161 Adaptor www.wago.com/2002-161 Item no.: 2009-110 Marking strips; on reel; not stretchable; plain; snap-on type; white www.wago.com/2009-110 Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 25.08.2019    Page 6/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 2009-145 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-145 Item no.: 2009-145/000-002 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-145 /000-002 Item no.: 2009-145/000-005 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/2009-145 /000-005 Item no.: 2009-145/000-006 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-145 /000-006 Item no.: 2009-145/000-007 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-145 /000-007 Item no.: 2009-145/000-012 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-145 /000-012 Item no.: 2009-145/000-023 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-145 /000-023 Item no.: 2009-145/000-024 Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-145 /000-024 Item no.: 2009-191 Group marker carrier www.wago.com/2009-191 Item no.: 2009-192 Group marker carrier www.wago.com/2009-192 Item no.: 2009-193 Group marker carrier www.wago.com/2009-193 Item no.: 2009-198 Adaptor www.wago.com/2009-198 Item no.: 248-501 25.08.2019    Page 7/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 248-501 Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card www.wago.com/248-501 Item no.: 248-501/000-002 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/248-501 /000-002 Item no.: 248-501/000-005 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-005 Item no.: 248-501/000-006 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-006 Item no.: 248-501/000-007 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-007 Item no.: 248-501/000-012 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-012 Item no.: 248-501/000-017 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-017 Item no.: 248-501/000-023 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-023 Item no.: 248-501/000-024 Mini-WSB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/248-501 /000-024 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 www.wago.com/793-501 25.08.2019    Page 8/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501 on type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Item no.: 210-720 Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft www.wago.com/210-720 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 tools Carrier rail Item no.: 210-114 25.08.2019    Page 9/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Item no.: 2022-101 1-conductor female plug; 2.5 mm²; 1-pole; 2,50 mm2; gray www.wago.com/2022-101 Item no.: 2022-101/000-006 1-conductor female plug; 1-pole; 2,50 mm2; blue www.wago.com/2022-101 /000-006 Item no.: 2022-101/000-012 1-conductor female plug; 1-pole; 2,50 mm2; orange www.wago.com/2022-101 /000-012 Item no.: 2022-101/000-016 1-conductor female plug; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-101 /000-016 Item no.: 2022-101/122-000 1-conductor female plug; 1-pole; 2,50 mm2; gray www.wago.com/2022-101 /122-000 Item no.: 2022-101/122-006 1-conductor female plug; 1-pole; 2,50 mm2; blue www.wago.com/2022-101 /122-006 Item no.: 2022-101/122-016 1-conductor female plug; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-101 /122-016 Female plug Item no.: 2022-101/132-000 25.08.2019    Page 10/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-101/132-000 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; gray www.wago.com/2022-101 /132-000 Item no.: 2022-101/132-006 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; blue www.wago.com/2022-101 /132-006 Item no.: 2022-101/132-016 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-101 /132-016 Item no.: 2022-101/142-000 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; gray www.wago.com/2022-101 /142-000 Item no.: 2022-101/142-006 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; blue www.wago.com/2022-101 /142-006 Item no.: 2022-101/142-016 1-conductor female plug; Strain relief plate; 1-pole; 2,50 mm2; green-yellow www.wago.com/2022-101 /142-016 Item no.: 2022-102 1-conductor female plug; 2.5 mm²; 2-pole; 2,50 mm2; gray www.wago.com/2022-102 Item no.: 2022-102/000-006 1-conductor female plug; 2.5 mm²; 2-pole; 2,50 mm2; blue www.wago.com/2022-102 /000-006 Item no.: 2022-102/000-016 1-conductor female plug; 2.5 mm²; 2-pole; 2,50 mm2; green-yellow www.wago.com/2022-102 /000-016 Item no.: 2022-102/122-000 1-conductor female plug; Locking lever; 2.5 mm²; 2-pole; 2,50 mm2; gray www.wago.com/2022-102 /122-000 Item no.: 2022-102/132-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 2-pole; 2,50 mm2; gray www.wago.com/2022-102 /132-000 Item no.: 2022-102/142-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 2-pole; 2,50 mm2; gray www.wago.com/2022-102 /142-000 Item no.: 2022-103 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; gray www.wago.com/2022-103 Item no.: 2022-103/000-006 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; blue www.wago.com/2022-103 /000-006 Item no.: 2022-103/000-016 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; green-yellow www.wago.com/2022-103 /000-016 Item no.: 2022-103/000-036 www.wago.com/2022-103 25.08.2019    Page 11/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-103/000-036 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-103 /000-036 Item no.: 2022-103/000-037 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-103 /000-037 Item no.: 2022-103/000-038 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-103 /000-038 Item no.: 2022-103/000-039 1-conductor female plug; 2.5 mm²; 3-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-103 /000-039 Item no.: 2022-103/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 3-pole; 2,50 mm2; gray www.wago.com/2022-103 /123-000 Item no.: 2022-103/133-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 3-pole; 2,50 mm2; gray www.wago.com/2022-103 /133-000 Item no.: 2022-103/143-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 3-pole; 2,50 mm2; gray www.wago.com/2022-103 /143-000 Item no.: 2022-104 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; gray www.wago.com/2022-104 Item no.: 2022-104/000-006 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; blue www.wago.com/2022-104 /000-006 Item no.: 2022-104/000-016 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; green-yellow www.wago.com/2022-104 /000-016 Item no.: 2022-104/000-036 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-104 /000-036 Item no.: 2022-104/000-037 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-104 /000-037 Item no.: 2022-104/000-038 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-104 /000-038 Item no.: 2022-104/000-039 1-conductor female plug; 2.5 mm²; 4-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-104 /000-039 Item no.: 2022-104/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 4-pole; 2,50 mm2; gray www.wago.com/2022-104 /123-000 Item no.: 2022-104/133-000 www.wago.com/2022-104 25.08.2019    Page 12/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-104/133-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 4-pole; 2,50 mm2; gray www.wago.com/2022-104 /133-000 Item no.: 2022-104/143-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 4-pole; 2,50 mm2; gray www.wago.com/2022-104 /143-000 Item no.: 2022-105 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; gray www.wago.com/2022-105 Item no.: 2022-105/000-006 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; blue www.wago.com/2022-105 /000-006 Item no.: 2022-105/000-016 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; green-yellow www.wago.com/2022-105 /000-016 Item no.: 2022-105/000-036 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-105 /000-036 Item no.: 2022-105/000-037 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-105 /000-037 Item no.: 2022-105/000-038 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-105 /000-038 Item no.: 2022-105/000-039 1-conductor female plug; 2.5 mm²; 5-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-105 /000-039 Item no.: 2022-105/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 5-pole; 2,50 mm2; gray www.wago.com/2022-105 /123-000 Item no.: 2022-105/134-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 5-pole; 2,50 mm2; gray www.wago.com/2022-105 /134-000 Item no.: 2022-105/144-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 5-pole; 2,50 mm2; gray www.wago.com/2022-105 /144-000 Item no.: 2022-106 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; gray www.wago.com/2022-106 Item no.: 2022-106/000-006 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; blue www.wago.com/2022-106 /000-006 Item no.: 2022-106/000-016 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; green-yellow www.wago.com/2022-106 /000-016 Item no.: 2022-106/000-036 25.08.2019    Page 13/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-106/000-036 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-106 /000-036 Item no.: 2022-106/000-037 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-106 /000-037 Item no.: 2022-106/000-038 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-106 /000-038 Item no.: 2022-106/000-039 1-conductor female plug; 2.5 mm²; 6-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-106 /000-039 Item no.: 2022-106/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 6-pole; 2,50 mm2; gray www.wago.com/2022-106 /123-000 Item no.: 2022-106/134-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 6-pole; 2,50 mm2; gray www.wago.com/2022-106 /134-000 Item no.: 2022-106/144-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 6-pole; 2,50 mm2; gray www.wago.com/2022-106 /144-000 Item no.: 2022-107 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; gray www.wago.com/2022-107 Item no.: 2022-107/000-006 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; blue www.wago.com/2022-107 /000-006 Item no.: 2022-107/000-016 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; green-yellow www.wago.com/2022-107 /000-016 Item no.: 2022-107/000-036 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-107 /000-036 Item no.: 2022-107/000-037 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-107 /000-037 Item no.: 2022-107/000-038 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-107 /000-038 Item no.: 2022-107/000-039 1-conductor female plug; 2.5 mm²; 7-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-107 /000-039 Item no.: 2022-107/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 7-pole; 2,50 mm2; gray www.wago.com/2022-107 /123-000 25.08.2019    Page 14/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-107/135-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 7-pole; 2,50 mm2; gray www.wago.com/2022-107 /135-000 Item no.: 2022-107/145-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 7-pole; 2,50 mm2; gray www.wago.com/2022-107 /145-000 Item no.: 2022-108 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; gray www.wago.com/2022-108 Item no.: 2022-108/000-006 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; blue www.wago.com/2022-108 /000-006 Item no.: 2022-108/000-016 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; green-yellow www.wago.com/2022-108 /000-016 Item no.: 2022-108/000-036 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-108 /000-036 Item no.: 2022-108/000-037 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-108 /000-037 Item no.: 2022-108/000-038 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-108 /000-038 Item no.: 2022-108/000-039 1-conductor female plug; 2.5 mm²; 8-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-108 /000-039 Item no.: 2022-108/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 8-pole; 2,50 mm2; gray www.wago.com/2022-108 /123-000 Item no.: 2022-108/135-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 8-pole; 2,50 mm2; gray www.wago.com/2022-108 /135-000 Item no.: 2022-108/145-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 8-pole; 2,50 mm2; gray www.wago.com/2022-108 /145-000 Item no.: 2022-109 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; gray www.wago.com/2022-109 Item no.: 2022-109/000-006 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; blue www.wago.com/2022-109 /000-006 Item no.: 2022-109/000-016 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; green-yellow www.wago.com/2022-109 /000-016 Item no.: 2022-109/000-036 www.wago.com/2022-109 25.08.2019    Page 15/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-109/000-036 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-109 /000-036 Item no.: 2022-109/000-037 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-109 /000-037 Item no.: 2022-109/000-038 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-109 /000-038 Item no.: 2022-109/000-039 1-conductor female plug; 2.5 mm²; 9-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-109 /000-039 Item no.: 2022-109/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 9-pole; 2,50 mm2; gray www.wago.com/2022-109 /123-000 Item no.: 2022-109/135-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 9-pole; 2,50 mm2; gray www.wago.com/2022-109 /135-000 Item no.: 2022-109/145-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 9-pole; 2,50 mm2; gray www.wago.com/2022-109 /145-000 Item no.: 2022-110 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; gray www.wago.com/2022-110 Item no.: 2022-110/000-006 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; blue www.wago.com/2022-110 /000-006 Item no.: 2022-110/000-016 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; green-yellow www.wago.com/2022-110 /000-016 Item no.: 2022-110/000-036 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-110 /000-036 Item no.: 2022-110/000-037 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-110 /000-037 Item no.: 2022-110/000-038 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-110 /000-038 Item no.: 2022-110/000-039 1-conductor female plug; 2.5 mm²; 10-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-110 /000-039 Item no.: 2022-110/123-000 1-conductor female plug; Locking lever; 2.5 mm²; 10-pole; 2,50 mm2; gray www.wago.com/2022-110 /123-000 Item no.: 2022-110/135-000 www.wago.com/2022-110 25.08.2019    Page 16/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-110/135-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 10-pole; 2,50 mm2; gray www.wago.com/2022-110 /135-000 Item no.: 2022-110/145-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 10-pole; 2,50 mm2; gray www.wago.com/2022-110 /145-000 Item no.: 2022-111 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; gray www.wago.com/2022-111 Item no.: 2022-111/000-006 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; blue www.wago.com/2022-111 /000-006 Item no.: 2022-111/000-016 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; green-yellow www.wago.com/2022-111 /000-016 Item no.: 2022-111/000-036 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-111 /000-036 Item no.: 2022-111/000-037 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-111 /000-037 Item no.: 2022-111/000-038 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-111 /000-038 Item no.: 2022-111/000-039 1-conductor female plug; 2.5 mm²; 11-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-111 /000-039 Item no.: 2022-111/126-000 1-conductor female plug; Locking lever; 2.5 mm²; 11-pole; 2,50 mm2; gray www.wago.com/2022-111 /126-000 Item no.: 2022-111/136-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 11-pole; 2,50 mm2; gray www.wago.com/2022-111 /136-000 Item no.: 2022-111/146-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 11-pole; 2,50 mm2; gray www.wago.com/2022-111 /146-000 Item no.: 2022-112 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; gray www.wago.com/2022-112 Item no.: 2022-112/000-006 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; blue www.wago.com/2022-112 /000-006 Item no.: 2022-112/000-016 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; green-yellow www.wago.com/2022-112 /000-016 Item no.: 2022-112/000-036 25.08.2019    Page 17/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-112/000-036 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-112 /000-036 Item no.: 2022-112/000-037 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-112 /000-037 Item no.: 2022-112/000-038 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-112 /000-038 Item no.: 2022-112/000-039 1-conductor female plug; 2.5 mm²; 12-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-112 /000-039 Item no.: 2022-112/126-000 1-conductor female plug; Locking lever; 2.5 mm²; 12-pole; 2,50 mm2; gray www.wago.com/2022-112 /126-000 Item no.: 2022-112/136-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 12-pole; 2,50 mm2; gray www.wago.com/2022-112 /136-000 Item no.: 2022-112/146-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 12-pole; 2,50 mm2; gray www.wago.com/2022-112 /146-000 Item no.: 2022-113 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; gray www.wago.com/2022-113 Item no.: 2022-113/000-006 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; blue www.wago.com/2022-113 /000-006 Item no.: 2022-113/000-016 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; green-yellow www.wago.com/2022-113 /000-016 Item no.: 2022-113/000-036 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-113 /000-036 Item no.: 2022-113/000-037 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-113 /000-037 Item no.: 2022-113/000-038 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-113 /000-038 Item no.: 2022-113/000-039 1-conductor female plug; 2.5 mm²; 13-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-113 /000-039 Item no.: 2022-113/126-000 1-conductor female plug; Locking lever; 2.5 mm²; 13-pole; 2,50 mm2; gray www.wago.com/2022-113 /126-000 25.08.2019    Page 18/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-113/136-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 13-pole; 2,50 mm2; gray www.wago.com/2022-113 /136-000 Item no.: 2022-113/146-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 13-pole; 2,50 mm2; gray www.wago.com/2022-113 /146-000 Item no.: 2022-114 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; gray www.wago.com/2022-114 Item no.: 2022-114/000-006 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; blue www.wago.com/2022-114 /000-006 Item no.: 2022-114/000-016 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; green-yellow www.wago.com/2022-114 /000-016 Item no.: 2022-114/000-036 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-114 /000-036 Item no.: 2022-114/000-037 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-114 /000-037 Item no.: 2022-114/000-038 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-114 /000-038 Item no.: 2022-114/000-039 1-conductor female plug; 2.5 mm²; 14-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-114 /000-039 Item no.: 2022-114/126-000 1-conductor female plug; Locking lever; 2.5 mm²; 14-pole; 2,50 mm2; gray www.wago.com/2022-114 /126-000 Item no.: 2022-114/136-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 14-pole; 2,50 mm2; gray www.wago.com/2022-114 /136-000 Item no.: 2022-114/146-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 14-pole; 2,50 mm2; gray www.wago.com/2022-114 /146-000 Item no.: 2022-115 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; gray www.wago.com/2022-115 Item no.: 2022-115/000-006 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; blue www.wago.com/2022-115 /000-006 Item no.: 2022-115/000-016 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; green-yellow www.wago.com/2022-115 /000-016 Item no.: 2022-115/000-036 www.wago.com/2022-115 25.08.2019    Page 19/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2022-115/000-036 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; gray, green-yellow www.wago.com/2022-115 /000-036 Item no.: 2022-115/000-037 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; green-yellow, gray www.wago.com/2022-115 /000-037 Item no.: 2022-115/000-038 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; gray, blue, green-yellow www.wago.com/2022-115 /000-038 Item no.: 2022-115/000-039 1-conductor female plug; 2.5 mm²; 15-pole; 2,50 mm2; green-yellow, blue, gray www.wago.com/2022-115 /000-039 Item no.: 2022-115/127-000 1-conductor female plug; Locking lever; 2.5 mm²; 15-pole; 2,50 mm2; gray www.wago.com/2022-115 /127-000 Item no.: 2022-115/137-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 15-pole; 2,50 mm2; gray www.wago.com/2022-115 /137-000 Item no.: 2022-115/147-000 1-conductor female plug; Strain relief plate; 2.5 mm²; 15-pole; 2,50 mm2; gray www.wago.com/2022-115 /147-000 Item no.: 2002-400 Adjacent jumper for continuous commoning; insulated; 2-way; Nominal current 25 A; light gray www.wago.com/2002-400 Item no.: 2002-402 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; light gray www.wago.com/2002-402 Item no.: 2002-402/000-005 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; red www.wago.com/2002-402 /000-005 Item no.: 2002-402/000-006 Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; blue www.wago.com/2002-402 /000-006 Item no.: 2002-403 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; light gray www.wago.com/2002-403 Item no.: 2002-403/000-005 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; red www.wago.com/2002-403 /000-005 Item no.: 2002-403/000-006 Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; blue www.wago.com/2002-403 /000-006 Item no.: 2002-404 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; light gray www.wago.com/2002-404 Jumper Item no.: 2002-404/000-005 25.08.2019    Page 20/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2002-404/000-005 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; red www.wago.com/2002-404 /000-005 Item no.: 2002-404/000-006 Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; blue www.wago.com/2002-404 /000-006 Item no.: 2002-405 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; light gray www.wago.com/2002-405 Item no.: 2002-405/000-005 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; red www.wago.com/2002-405 /000-005 Item no.: 2002-405/000-006 Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; blue www.wago.com/2002-405 /000-006 Item no.: 2002-405/011-000 Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray www.wago.com/2002-405 /011-000 Item no.: 2002-406 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; light gray www.wago.com/2002-406 Item no.: 2002-406/000-005 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; red www.wago.com/2002-406 /000-005 Item no.: 2002-406/000-006 Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; blue www.wago.com/2002-406 /000-006 Item no.: 2002-406/020-000 Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray www.wago.com/2002-406 /020-000 Item no.: 2002-407 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; light gray www.wago.com/2002-407 Item no.: 2002-407/000-005 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; red www.wago.com/2002-407 /000-005 Item no.: 2002-407/000-006 Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; blue www.wago.com/2002-407 /000-006 Item no.: 2002-408 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; light gray www.wago.com/2002-408 Item no.: 2002-408/000-005 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; red www.wago.com/2002-408 /000-005 Item no.: 2002-408/000-006 Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; blue www.wago.com/2002-408 /000-006 25.08.2019    Page 21/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2002-409 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; light gray www.wago.com/2002-409 Item no.: 2002-409/000-005 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; red www.wago.com/2002-409 /000-005 Item no.: 2002-409/000-006 Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; blue www.wago.com/2002-409 /000-006 Item no.: 2002-410 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; light gray www.wago.com/2002-410 Item no.: 2002-410/000-005 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; red www.wago.com/2002-410 /000-005 Item no.: 2002-410/000-006 Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; blue www.wago.com/2002-410 /000-006 Item no.: 2002-423 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; light gray www.wago.com/2002-423 Item no.: 2002-423/000-005 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; red www.wago.com/2002-423 /000-005 Item no.: 2002-423/000-006 Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; blue www.wago.com/2002-423 /000-006 Item no.: 2002-433 Push-in type jumper bar; insulated; from 1 to 3; Nominal current 25 A; light gray www.wago.com/2002-433 Item no.: 2002-434 Push-in type jumper bar; insulated; from 1 to 4; Nominal current 25 A; light gray www.wago.com/2002-434 Item no.: 2002-435 Push-in type jumper bar; insulated; from 1 to 5; Nominal current 25 A; light gray www.wago.com/2002-435 Item no.: 2002-436 Push-in type jumper bar; insulated; from 1 to 6; Nominal current 25 A; light gray www.wago.com/2002-436 Item no.: 2002-437 Push-in type jumper bar; insulated; from 1 to 7; Nominal current 25 A; light gray www.wago.com/2002-437 Item no.: 2002-438 Push-in type jumper bar; insulated; from 1 to 8; Nominal current 25 A; light gray www.wago.com/2002-438 Item no.: 2002-439 Push-in type jumper bar; insulated; from 1 to 9; Nominal current 25 A; light gray www.wago.com/2002-439 Item no.: 2002-440 Push-in type jumper bar; insulated; from 1 to 10; Nominal current 25 A; light gray www.wago.com/2002-440 Item no.: 2002-472 Staggered jumper; insulated; 2-way; Nominal current 25 A; suitable for 2002 and 2003 Series rail- www.wago.com/2002-472 25.08.2019    Page 22/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Staggered jumper; insulated; 2-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-472 Item no.: 2002-473 Staggered jumper; insulated; 3-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-473 Item no.: 2002-473/011-000 Ready-made staggered jumper; insulated; 2-way (1-3); Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-473 /011-000 Item no.: 2002-474 Staggered jumper; insulated; 4-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-474 Item no.: 2002-475 Staggered jumper; insulated; 5-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-475 Item no.: 2002-475/011-000 Ready-made staggered jumper; insulated; 3-way (1-3-5); Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-475 /011-000 Item no.: 2002-476 Staggered jumper; insulated; 6-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-476 Item no.: 2002-477 Staggered jumper; insulated; 7-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-477 Item no.: 2002-477/011-000 Ready-made staggered jumper; insulated; 1-3-5-7; Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-477 /011-000 Item no.: 2002-478 Staggered jumper; insulated; 8-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-478 Item no.: 2002-479 Staggered jumper; insulated; 9-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-479 Item no.: 2002-479/011-000 www.wago.com/2002-479 Ready-made staggered jumper; insulated; 1-3-5-7-9; Nominal current 25 A; with contact lugs broken /011-000 off at the factory and circuit marking; light gray Item no.: 2002-480 Staggered jumper; insulated; 10-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-480 Item no.: 2002-481 Staggered jumper; insulated; 11-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-481 Item no.: 2002-481/011-000 Ready-made staggered jumper; insulated; 1-3-5-7-9-11; Nominal current 25 A; with contact lugs broken off at the factory and circuit marking; light gray www.wago.com/2002-481 /011-000 Item no.: 2002-482 Staggered jumper; insulated; 12-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray www.wago.com/2002-482 Item no.: 2002-492 www.wago.com/2002-492 25.08.2019    Page 23/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Item no.: 2002-492 Double-deck vertical jumper; insulated; light gray www.wago.com/2002-492 Item no.: 2002-492/000-012 Double-deck vertical jumper; insulated; orange www.wago.com/2002-492 /000-012 Item no.: 2009-412 Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-412 Item no.: 2009-414 Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-414 Item no.: 2009-416 Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 1.5 mm²; suitable for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black www.wago.com/2009-416 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Downloads Documentation Bid Text 2022-2202 docx 15.7 kB Download pdf 2.1 MB Download URL Download Additional Information Technical explanations Apr 3, 2019 CAD/CAE - Smart Data CAD data 3D Download 2022-2202 EPLAN EPLAN Data Portal Download WSCAD WSCAD Universe Download 25.08.2019    Page 24/25 Data sheet  |  Item number: 2022-2202 www.wago.com/2022-2202 Product family X-COM S Show all products from the family   Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 25.08.2019    Page 25/25
2002-406 价格&库存
很抱歉,暂时无法提供与“2002-406”相匹配的价格&库存,您可以联系我们找货
  • 25+51.7022525+6.70160
  • 100+36.79321100+4.76910
库存:75
2002-406
  • 1+42.530511+5.51277
  • 10+36.1488010+4.68558
  • 25+33.8851225+4.39216
  • 50+32.2650550+4.18217
  • 100+30.72398100+3.98242
  • 250+28.80042250+3.73309
  • 500+27.42615500+3.55495
  • 1000+26.118041000+3.38540
  • 2500+24.484692500+3.17369
库存:404
2002-406
  • 29+23.5332629+3.05036
库存:38
2002-406
    • 1+696.51908
    库存:125
