HARTING
Han® 24 HPR
Ha-VIS
enlarged
eCon 2050-AA
Ethernet Switch
IP 30
Advantages
General Description
• Flat housing format
• Robust metal housing
• Adapted for mounting onto top hat
mounting rail 35 mm according to EN
60 715
• RoHS compliant
• Full Gigabit Ethernet Switch
• Jumbo Frames up to 9728 Bytes
Energy-Efficient Ethernet according to
IEEE 802.3az
The Ethernet Switch HARTING Ha-VIS eCon 2050-AA can
be used in industrial environments and supports Ethernet
(10 Mbit/s), Fast Ethernet (100 Mbit/s) and Gigabit Ethernet
(1000 Mbit/s). Up to 5 Ethernet devices can be connected
via the RJ45-ports.
Identification
Drawing
Part number
The Ethernet Switch supports a simple and quickly network
diagnostics with integrated LEDs at every port. It works
as unmanaged switch in the Store and Forward switching
mode and supports Auto-crossing and Auto-negotiation.
Dimensions in mm
HARTING Ha-VIS
eCon 2050-AA
Ethernet Switch with
5 ports RJ45
20 76 105 3001
All data represent the current state of development at the time of print and are therefore non-binding.
HARTING reserves the right to modify designs without prior notice.
Han® Data Sheet 0370
Technical characteristics
Features
Auto-crossing
Auto-negotiation
Store and Forward switching mode
8 K Mac addresses
Ethernet Interface
Number of ports
• 5x 10/100/1000Base-T(X), unmanaged
Cable types acc. to IEEE 802.3
• Shielded Twisted Pair (STP) or Unshielded Twisted Pair (UTP),
Category 5
Data rate
• 10 / 100 / 1000 Mbit/s (RJ45)
Maximum cable length
• 100 m (Twisted Pair; with cable Category 5 acc. to EN 50 173-1)
Terminating method
• RJ45 (Twisted Pair)
Diagnostics (via LED)
Topology
Line, Star or mixed
Status Link - green
Status Data transfer (Act) - green flashing
Data transfer rate (Speed) - 10 Mbit/s: OFF / 100 Mbit/s: yellow /
1000 Mbit/s: green
Power Supply
Power supply
24 V DC
Permissible range
12 V ... 48 V
Current consumption
220 mA (at 24 V DC)
Power supply
Terminating Power supply
3-pole pluggable contact (+24 V DC / 0 V / FE)
Design features
Material of housing
Aluminium
Dimensions (W x H x D)
70.2 x 113.5 x 27.3 mm (without connectors)
Degree of protection
acc. to DIN 60 529
IP 30
Environmental conditions
Operating temperature
-40 °C ... +85 °C
Storage temperature
-40 °C ... +85 °C
Relative humidity
10 % ... 95 % (non-condensing)
Approvals
cUL
(in preparation)
2013-04-26
HARTING Electric GmbH & Co. KG
Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | P.O.Box 14 73 | D-32328 Espelkamp
Phone: +49 5772 47-97100 | Fax: +49 5772 47-688 | HARTING.Electric@HARTING.com | www.HARTING.com
很抱歉,暂时无法提供与“20761053001”相匹配的价格&库存,您可以联系我们找货
