24034160010
24034160010
    HARTING(浩亭)
    HA-VISECON3160GB-A-UNMANAGED
24034160010 数据手册
Ha-VIS eCon 3000 Full Gigabit Ethernet Basic Unmanaged Plug-and-Play Ethernet Switches for Assembly on DIN Rail in Control Cabinets Commercial Temp.: 0 °C ... +55 °C / Industrial Temp.: -40 °C ... +70 °C Specification Number of ports copper / termination 16 x 10BASE-T / 100BASE-TX EEE / 1000Base-T EEE / RJ45 (twisted pair) Nominal voltage Permissible voltage range Termination 24 / 48 VDC 9 V ... 60 VDC Screw type terminal block, pluggable, 3-poles (+ / - / Current consumption typical @ 24 V / 48 V 382 mA / 191 mA Dimensions (W x H x D) 38.0 x 142.0 x 107.5 mm (without pluggable screw type terminal block) 700 g s. eCatalogue Weight MTBF in million hours Approvals Identification Ha-VIS eCon 3160GB-A ) CE FCC CFR 47 Part 15, cUL US 508 listed ABB IIT Part number Drawing Dimensions in mm 24 03 416 0010 0 °C ... +55 °C Ha-VIS eCon 3160GBT-A 24 03 416 0000 -40 °C ... +70 °C HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com/en/ethernet-switches | ICPN-Service@harting.com 2016-01-29 Han® Datenblatt 1079
24034160010 价格&库存
很抱歉,暂时无法提供与“24034160010”相匹配的价格&库存,您可以联系我们找货
  • 1+7699.028001+996.42685
