24030080010
    HARTING(浩亭)
    ETHERNETSW3080B-A
24030080010 数据手册
Ha-VIS eCon 3000 Fast Ethernet Basic 3 to 16 Ethernet ports RJ45 and SC English Unmanaged plug and play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Fast Ethernet Non-Blocking switch architecture in accordance with IEEE 802.3 ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Wide range power supply 24/48 VDC ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet ■ Optimised DIN rail bracket Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 3000 Fast Ethernet family of unmanaged Ethernet switches is equipped with up to 16 Fast Ethernet ports and allow for cost-efficient and quick expansion and/or reconstruction of network infrastructures. The slender design of the switches enables an extremely high packing density on the DIN rail. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (autopolarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch features Ethernet ports 10BASE-Te / 100BASE-TX EEE Enclosure width 25 mm 38 mm 38 mm Number of ports 3, 5, 6, 7, 8 9, 10 16 Type of connection RJ45 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Auto-MDI(X) Yes Frame size 1522 bytes 1632 bytes 2000 bytes MAC table size Transfer conditions 1k entries 2k entries 8k entries 448 kbit 1 Mbit 2 Mbit Transfer speed 10 / 100 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size Non-blocking Yes Quality of Service Yes Energy Efficient Ethernet Yes PROFINET compatible Yes EthernetIP compatible Yes Twisted pair Ethernet ports 100BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions FOC Wavelength Power supply Nominal voltage 24 VDC Permissible voltage range 48 VDC 9 VDC ... 60 VDC Surge protection Yes Reverse polarity proof Yes Output power Input sensitivity Starting current 1.6 A Overcurrent protection at input Yes (12 A for 8 ports) Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout 3.2 A 1.80 W ... 6.72 W 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany ICPN-Service@harting.com | Service hotline: +49 5772 47-9479 Fax: +49 5772 47-495 | www.HARTING.com/de/ethernet-switches 1310 nm Transfer speed Transfer length Single-mode (SM) SC Duplex 100 Mbit/s 2 km 15 km -20 dBm ... -14 dBm -15 dBm ... -8 dBm ≤ -30 dBm ≤ -32 dBm Environmental conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0 % ... 95 % (non-condensing) Relative humidity (storage and transport) 0 % ... 95 % (non-condensing) Air pressure 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. Enclosures Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) 25 mm 38 mm 142 mm x 25 mm x 107.5 mm 142 mm x 38 mm x 107.5 mm Weight 425 g ... 531 g Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium / powder coated steel sheet Protection class (with pluggable screw type terminal block) III Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green Link is active Link is active and data is transferred Link speed ("Spd") off EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) IP30 Protection class Approvals CE, FCC CFR 47 Part 15, cUL US 508 listed, DNV, GL, ABS, NK, ABB IIT Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions 10 Mbit/s Link speed ("Spd") illuminated yellow Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C RJ45 SFP SC Enclosure width 2 - 1x MM (2 km) 25 mm 97 mA 2.51 Ha-VIS eCon 3021B-AD 24 03 002 1110 Ha-VIS eCon 3021BT-AD 24 03 002 1100 2 - 1x SM (15 km) 25 mm 97 mA 2.51 Ha-VIS eCon 3021B-AF 24 03 002 1210 Ha-VIS eCon 3021BT-AF 24 03 002 1200 4 - 1x MM (2 km) 25 mm 111 mA 2.35 Ha-VIS eCon 3041B-AD 24 03 004 1110 Ha-VIS eCon 3041BT-AD 24 03 004 1100 4 - 1x SM (15 km) 25 mm 111 mA 2.35 Ha-VIS eCon 3041B-AF 24 03 004 1210 Ha-VIS eCon 3041BT-AF 24 03 004 1200 4 - 2x MM (2 km) 25 mm 142 mA 2.27 Ha-VIS eCon 3042B-AD 24 03 004 2110 Ha-VIS eCon 3042BT-AD 24 03 004 2100 4 - 2x SM (15 km) 25 mm 142 mA 2.27 Ha-VIS eCon 3042B-AF 24 03 004 2210 Ha-VIS eCon 3042BT-AF 24 03 004 2200 6 - - 25 mm 75 mA 2.29 Ha-VIS eCon 3060B-A 24 03 006 0010 Ha-VIS eCon 3060BT-A 24 03 006 0000 6 - 1x MM (2 km) 25 mm 121 mA 2.21 Ha-VIS eCon 3061B-AD 24 03 006 1110 Ha-VIS eCon 3061BT-AD 24 03 006 1100 6 - 1x SM (15 km) 25 mm 121 mA 2.21 Ha-VIS eCon 3061B-AF 24 03 006 1210 Ha-VIS eCon 3061BT-AF 24 03 006 1200 8 - - 25 mm 85 mA 2.16 Ha-VIS eCon 3080B-A 24 03 008 0010 Ha-VIS eCon 3080BT-A 24 03 008 0000 8 - 1x MM (2 km) 38 mm 227 mA 0.94 Ha-VIS eCon 3081B-AD 24 03 008 1110 Ha-VIS eCon 3081BT-AD 24 03 008 1100 8 - 1x SM (15 km) 38 mm 227 mA 0.94 Ha-VIS eCon 3081B-AF 24 03 008 1210 Ha-VIS eCon 3081BT-AF 24 03 008 1200 8 - 2x MM (2 km) 38 mm 273 mA 0.93 Ha-VIS eCon 3082B-AD 24 03 008 2110 Ha-VIS eCon 3082BT-AD 24 03 008 2100 8 - 2x SM (15 km) 38 mm 273 mA 0.93 Ha-VIS eCon 3082B-AF 24 03 008 2210 Ha-VIS eCon 3082BT-AF 24 03 008 2200 10 - - 38 mm 220 mA 0.91 Ha-VIS eCon 3100B-A 24 03 010 0010 Ha-VIS eCon 3100BT-A 24 03 010 0000 16 - - 38 mm 93 mA 1.75 Ha-VIS eCon 3160 B-A 24 03 016 0010 Ha-VIS eCon 3160BT-A 24 03 016 0000 Copyright© 2014 HARTING Technology Group All rights reserved Power consumption @ 24 VDC MTBF in million h Switch Part no. Switch Part no. Date of issue 08.2015 ICPN Datasheet 0842/03
24030080010 价格&库存
很抱歉,暂时无法提供与“24030080010”相匹配的价格&库存,您可以联系我们找货
  • 1+1998.934681+248.84860
  • 5+1878.755345+233.88740
库存:3
24030080010
    • 1+1727.12446
    库存:28
    24030080010
    • 1+1918.018531+238.77530
    • 10+1844.9605110+229.68027
    库存:3
