249-117
249-117
    WAGO(万可电子)
    无螺丝端止挡,适用于DIN导轨
249-117 数据手册
Accessories Manuals, GSD and EDS Files, Marking Accessories, Mounting Accessories Group marking carrier Gruppenbezeichnungsträger Miniature WSB quick Mini-WSBmarking system Schnellbezeichnungssystem End stop Endklammer Description Manuals: for fieldbus couplers/controllers and ECO fieldbus couplers: PROFINET, PROFIBUS, ETHERNET, DeviceNet, CANopen, ETHERNET Powerlink, MODBUS, INTERBUS, CC-Link, Firewire, CAL, Telecontrol, II/O-LIGHTBUS, KNX IP, BACnet, LON, Peer to Peer; Available in German and English on the Internet at www.wago.com or as DVD AUTOMATION Tools and Docs 0888-0412/xxxx-0101 for I/O modules (digital input, digital output, analog input, analog output, specialty modules, system modules, Ex i, PROFIsafe) GSD and EDS files: available for the fieldbus system PROFIBUS, DeviceNet and CANopen Description Marker cards for group marking carrier Miniature WSB quick marking system End stop, for DIN 35 rail End stop, for DIN 35 rail Communication cable Screwdriver with partially insulated shaft Screwdriver with partially insulated shaft Subject to design changes 10.09.2008 Item no. Pack. unit sheet DIN A4 (160 cards) 750-100 1 sheet plain yellow red blue gray orange light green green violet 6 mm/0.236 in wide 10 mm/0.394 in wide 248-501 248-501/000-002 248-501/000-005 248-501/000-006 248-501/000-007 248-501/000-012 248-501/000-017 248-501/000-023 248-501/000-024 249-116 249-117 750-920 210-619 210-620 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 100 (4x25) 50 (2x25) 1 1 1 Type 1, blade 2.5 x 0.4 mm / 0.098 x 0.016 in Type 2, blade 3.5 x 0.5 mm / 0.137 x 0.020 in WAGO Kontakttechnik GmbH & Co. KG Postfach 2880 •D-32385 Minden Tel.: +49(0)571/887-0 E-Mail: info@wago.com Hansastr. 27 •D-32423 Minden Fax: +49(0)571/887-169 www.wago.com Accessories Miniature WSB Quick Marking System Description Miniature WSB quick marking system, Marking per card: 0V 0V 24 V 24 V + + 3 3 PE PE A0 A1 ... A8 A9 E0 E1 ... E8 E9 X0 X1 ... X8 X9 0 to 09 10 to 19 20 to 29 30 to 39 40 to 49 50 to 59 60 to 69 70 to 79 80 to 89 90 to 99 00 to 49 50 to 99 100 to 149 150 to 199 200 to 249 250 to 299 300 to 349 350 to 399 400 to 449 450 to 499 500 to 549 550 to 599 600 to 649 650 to 699 700 to 749 750 to 799 800 to 849 850 to 899 900 to 949 950 to 999 .0 to .7 / plain .0 to .7 /.0 to .7 /.0 to .7 /+ .0 to .7 /+ .0 to .7 /N .0 to .7 /N .0 to .7 /L 100 x blue 100 x white 100 x blue 100 x white 100 x red 100 x white 100 x red 100 x white 100 x light green 100 x white 100 x light green 100 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 10 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 2 x white 10 x /20 x white 10 x /20 x white 10 x /20 x blue 10 x /20 x white 10 x /20 x red 10 x /20 x white 10 x /20 x blue 10 x /20 x white Item no. Pack. unit 247-506/000-006 247-506 247-507/000-006 247-507 247-508/000-005 247-508 247-509/000-005 247-509 247-552/000-017 247-552 248-578/000-017 248-578 247-510 247-511 247-512 247-513 247-514 247-515 247-516 247-517 247-518 247-519 247-520 247-521 247-522 247-523 247-524 247-525 247-526 247-527 247-528 247-529 247-530 247-531 247-532 247-533 247-534 247-535 247-536 247-537 247-538 247-539 247-540 247-541 247-542 247-543 247-544 247-544/000-006 247-545 247-545/000-005 247-546 247-546/000-006 247-547 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards 5 cards
249-117 价格&库存
很抱歉,暂时无法提供与“249-117”相匹配的价格&库存,您可以联系我们找货
  • 1+5.44320
  • 10+4.19040
  • 25+3.65040
库存:46
249-117
    • 1000+1.88660
    库存:1001
    249-117
      • 1+2.47390
      • 25+2.22640
      • 50+2.22530
      库存:25
