QMS-104-05.75-L-D-RF1 数据手册
F-215
QMS–078–05.75–L–D–RF1
TM
QMS–052–06.75–L–D–PC4
(0,635 mm) .025"
QMS-PC, QMS-RF SERIES
HIGH SPEED COMBO RF & POWER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QMS
Insulator Material:
Liquid Crystal Polymer
Terminal & Ground
Plane Material:
Phosphor Bronze
Plating:
Au over 50µ" (1,27 µm) Ni
(Tin on Ground Plane Tail)
Current Rating:
Signal Contact:
2.6 A per pin
(1 pin powered per row)
Power Contact:
4.0 A per pin
(4 pins powered per end)
Ground Plane:
15.7 A per ground plane
(1 ground plane powered)
Voltage Rating:
300 VAC mated with QFS
Operating Temp:
-55°C to +125°C
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (026-078)
Board Stacking:
For applications requiring more
than two connectors per board,
contact ipg@samtec.com
Board Mates:
QFS-PC, QFS-RA-PC,
QFS-RF
• Increased
insertion depth
• Integral guide post
APPLICATION
Rated @ 3dB
Insertion Loss
QMS-PC/QFS-PC
Type
10 mm Stack Height
with PCB w/o PCB
effects* effects**
Single-Ended
9 GHz / 8.5 GHz /
–D 18
Signaling
Gbps 17 Gbps
Differential Pair
8
GHz
GHz /
–D 16 Gbps/ 8.5
Signaling
17 Gbps
*Performance data includes effects of a
non-optimized PCB.
**Test board losses de-embedded from
performance data.
Performance data for other stack heights
and complete test data available at
www.samtec.com?QMS or contact
sig@samtec.com
QMS
NO. OF PINS
PER ROW
–026, –052, –078
(52 total pins per bank)
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
ALSO AVAILABLE
(MOQ Required)
• Other platings
• Differential Pairs
• Retention Pins
• 8 Power Pins/End for
(1,60 mm) 0.62"
thick Board
• 4 or 8 Power Pins/End
for (2,36 mm) .093"
thick Board
• 2 RF Connectors/End
• Hot Pluggable
Contact Samtec.
Choice of Power and RF
options
Integral
metal plane
for power or
ground
(2,00)
.07874
QFS
MATED
HEIGHT
QMS
QMS
LEAD
STYLE
MATED
HEIGHT*
–05.75
–06.75
10 mm
11 mm
*Processing conditions
will affect mated height.
PLATING
OPTION
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
END
OPTION
D
–PC4
–L
= 10µ" (0,25 µm) Gold on Signal Pins
and Ground Plane
(Tin on Signal Pin tails,
and Ground Plane tails)
= 4 Power
Pins per End for
(1,60 mm) .062"
thick Board
(N/A with
–RF1)
LEAD
STYLE
A
–RF1
–05.75
(5,38)
.212
–06.75
(6,35)
.250
= One RF
Plug per End
(–05.75 only,
not available
with –PC4)
(2,29) .090
(21,35) .840
01
(2,54)
.100
(2,31)
.091
OTHER
SOLUTIONS
(7,52)
.296
(0,635)
.025
02
(0,23)
.009
No. of Banks x (21,34) .840 + (13,21) .520
A
–PC4 OPTION
No. of Banks x (21,34) .840 + (14,86) .585
01
(1,78)
.070
(0,70)
.028
DIA
See SO Series for precision
machined standoffs.
02
Note: Some lengths,
styles and options are
non-standard, non-returnable.
–RF1 OPTION
(3,56)
.140
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
QMS-104-05.75-L-D-RF1 价格&库存
很抱歉,暂时无法提供与“QMS-104-05.75-L-D-RF1”相匹配的价格&库存,您可以联系我们找货
