QTH-060-04-F-D-A-K-TR 数据手册
RIGHT-ANGLE & EDGE MOUNT
HIGH-SPEED GROUND PLANE
CONNECTORS
• Right-Angle and Edge Mount designs for coplanar
and perpendicular mating
• Q Strip® Right-Angle High-Speed Connectors
on 0.50 mm & 0.635 mm pitches
• Q2™ Right-Angle & Edge Mount Rugged
High-Speed Connectors on 0.635 mm pitch
• Q Rate® Right-Angle Slim Body High-Speed
Connectors on 0.80 mm pitch
• Visit samtec.com/QSeries for complete specifications and
ordering information
Q STRIP ® HIGH-SPEED GROUND PLANE CONNECTORS
(0.50 mm) .0197" PITCH RIGHT-ANGLE GROUND PLANE HEADERS & SOCKETS
QTH-RA
Board Mates:
QSH
SERIES
QTH
–030, –060, –090
Header
QSH-RA
- 01 -
PINS PER ROW
NO. OF PAIRS
–D = (60 total pins per bank)
QSH
–020, –040, –060
Socket
–D–DP = (20 pairs per bank)
Board Mates:
QTH
PLATING
TYPE
–F
= Gold Flash on
contact, Matte
Tin on tails
–L
- RA -
–D
= Single-Ended
–D–DP
OTHER OPTION
–PGP
= Plastic Guide Post
(QTH only)
–GP
= Differential Pair
= 10 µ"
(0.25 µm)
Gold contact,
Matte Tin on
tails
=Guide Post Holes
(QSH only)
–K
= Polyimide film Pick &
Place Pad
View complete specifications at: samtec.com?QTH-RA or samtec.com?QSH-RA
(0.635 mm) .025" PITCH RIGHT-ANGLE GROUND PLANE HEADERS & SOCKETS
QTS-RA
Board Mates:
QSS
SERIES
QTS
Header
QSS-RA
Board Mates:
QTS
QSS
Socket
POSITIONS PER ROW
–025, –050, –075
(50 total Positions per bank)
- 01 -
PLATING
D
- RA -
–F
= Gold Flash on Signal Pins
and Ground Plane, Matte
Tin on tails
WT
–WT
= Weld Tab
(N/A with -025
Positions)
OTHER
OPTION
–L
= 10 µ" (0.25 µm) Gold on
Signal Pins and Ground
Plane, Matte Tin on tails
Cable Mates:
SQCD
Note:
Some lengths, styles and options
are non-standard, non-returnable.
F-224
–SP
= Solder Pin
(QTS only)
View complete specifications at: samtec.com?QTS-RA or samtec.com?QSS-RA
samtec.com/QSeries
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QTH-060-04-F-D-A-K-TR 价格&库存
很抱歉,暂时无法提供与“QTH-060-04-F-D-A-K-TR”相匹配的价格&库存,您可以联系我们找货
