RPCU-G-00.50-AMS-BC
RPCU-G-00.50-AMS-BC
    SAMTEC(申泰)
    USB 2.0 缆线 A 公型至线缆(圆形) 1.64'(500.0mm) 屏蔽
RPCU-G-00.50-AMS-BC 数据手册
IP68 SEALED USB PANEL MOUNT RPBU, RPCU SERIES RPBU Mates wtih: RCU (Single Port only) RPBU - NO. OF PORTS - –01 SPECIFICATIONS –02 –VT = USB A Type –B OPTION –LC = Vertical Through-hole = Locking Clip (–VT only) –RA = USB B Type (45.20) 1.780 - LEAD STYLE –A = 30 µ" (0.76 µm) Gold on contact, Matte tin on tail = Dual Port (–A only) - TYPE –S = Single Port Insulator Material: Black Liquid Crystal Polymer Contact: Phosphor Bronze Current Rating: 4.2 A per pin (1 pin powered) Operating Temp Range: -20 °C to +80 °C Seal: Silicone Lead-Free Solderable: Yes - PLATING = Right-angle A (20.50) .807 (16.80) .661 TYPE –B TYPE –A (36.20) 1.425 (17.06) .672 NO. OF PORTS A B C –01 (48.15) 1.896 (39.10) 1.539 (20.01) .788 –02 (69.80) 2.748 (60.75) 2.392 (42.00) 1.654 B C DUST CAPS DCA-RPBU-01-01-A (9.53) .375 –B–VT RPCU Mates with: RCU RPCU –B–RA - PLATING –G = 30 µ" (0.76 µm) Gold on contact, Nickel on shell SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Operating Temp Range: -20 °C to +80 °C Shield Material: Phosphor Bronze Wire: 20 AWG (Power) 25 AWG (Signal) 28 AWG (Drain) –A–VT - DCA-RPBU-02-01-A DCA-RPBU-01-01-B –A–RA CABLE LENGTH - –00.25 = (0.25 m) 9.84" Cable –00.50 = (0.50 m) 19.68" Cable Standard lengths END 1 OPTION –AMS END 2 OPTION AM = USB A Type, Sealed = USB A Type, Not Sealed –BMS –BM = USB B Type, Sealed = USB B Type, Not Sealed –BC (Assembled Length = Cable Length + (42.8 mm) 1.69") = Blunt Cut Cable Length + (42.8) 1.69 (15.90) .626 (20.00) .787 Note: Some lengths, styles and options are non-standard, non-returnable - –AMS samtec.com/AccliMate samtec.com?RPBU or samtec.com?RPCU –AM F-224227 WEB Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
RPCU-G-00.50-AMS-BC 价格&库存
很抱歉,暂时无法提供与“RPCU-G-00.50-AMS-BC”相匹配的价格&库存,您可以联系我们找货
RPCU-G-00.50-AMS-BC
  • 1+166.223371+20.68475
  • 10+154.0311010+19.16756
  • 25+141.6531225+17.62725
  • 50+130.5590350+16.24670
库存:3
