REVISION DC
DO NOT
SCALE FROM
THIS PRINT
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: .5 LB.
3. COPLANARITY: .004[0.10] = POS 05 THRU 26
.006[0.15] = POS 27 THRU 50
4. TUBE ALL POSITIONS. PARTS TO BE TUBED WITH
NOTCH GOING WITH ARROW.
5. PINS CAN BE ORIENTED IN ANY DIRECTION;
BOTH ROWS MUST FACE SAME WAY.
6. SEE NOTCH FOR PROPER ORIENTATION.
7. MAXIMUM PIN HEIGHT VARIATION: .003[0.08].
8. DUE TO HIGH AMOUNT OF INSERTION FORCE
NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH
AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL
PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION.
*: DIMENSIONS N/A FOR -N OPTION
*.145 3.68 REF
*.020 0.51 REF
.120 3.05 REF
*.080 2.03 REF
.050 1.27 REF
02
CL
01
CL
SFM-1XX-XX-XXX-D-XXX
No OF POSITIONS
ALL POSITIONS AVAILABLE
-02 THRU -50
(USE BODY: SFM-XX-D-XX-X)
OPTIONS
(LEAVE BLANK FOR STANDARD
AND USE SFM-XX-D)
-N: NO POLARIZATION NOTCH
(USE SFM-XX-D-XX-N)
-A: ALIGNMENT PIN (USE SFM-XX-D-A-X)
(SEE FIG 4, SHT 2)
-LC: LOCKING CLIP (SEE FIG 6, SHT 3 & NOTE 8)
(AVAILABLE ON ALL LEADS)
-P: PICK AND PLACE PAD
(SEE FIG 5, SHT 2)
-TR: TAPE & REEL (SEE SHT 4)
(NOT AVAILABLE WITH -DS OPTION)
-K: POLYIMIDE FILM PAD (.005[0.13] THICKNESS)
(SEE FIG 3, SHT 2) (USE K-DOT-.157-.250-.005)
-SN: SOLDER NAIL FOR .062 BOARD
(SFM-XX-D-SN AND WT-27-01-T)
(AVAILABLE WITH LEAD STYLE -02, -L2 & -T2)
(NOT AVAILABLE WITH -A & -LC)
-SN2: SOLDER NAIL FOR .093 BOARD
(SFM-XX-D-SN AND WT-27-02-T)
-DS: DUAL SCREW DOWN FOR .062 BOARD
(SEE FIG 8, SHT 3)
(ONLY AVAILABLE WITH -01, -02 AND -03 LEAD
STYLE, 02 THRU 40 POSITIONS)
(NOT AVAILABLE WITH OPTIONS -N, -A, -LC, -P,
-TR, -K, -SN AND SN2), (USES SFM-XX-D-DS,
CPS-RR-XX-XX-X, ACCRT-01 AND WT-27-XX-T
ALWAYS FILLED)
LEAD STYLE
-01: THROUGH HOLE
(USE CONTACT: C-44-01-XXX)
(SEE FIG 1, SHT 1)
-02: SURFACE MOUNT
(USE CONTACT: C-44-02-XXX)
(SEE FIG 2, SHT 2)
-03: STRAIGHT MODIFIED
(USE CONTACT: C-44-03-XXX)
(SEE FIG 1, SHT 1)
-L1: THROUGH HOLE (LOW INSERTION)
(USE CONTACT: C-61-01-XXX)
(SEE FIG 1, SHT 1)
-L2: SURFACE MOUNT (LOW INSERTION)
(USE CONTACT: C-61-02-XXX)
(SEE FIG 2, SHT 2)
-L3: STRAIGHT MODIFIED (LOW INSERTION)
(USE CONTACT: C-61-03-XXX)
(SEE FIG 1, SHT 1)
-T1: THROUGH HOLE (PHOS BRONZE)
(USE CONTACT: C-119-01-XXX)
(SEE FIG 1, SHT 1)
-T2: SURFACE MOUNT (PHOS BRONZE)
(USE CONTACT: C-119-02-XXX)
(SEE FIG 2, SHT 2)
.050 1.27 REF
BODY SPECIFICATION
-D: DOUBLE ROW
(NO. OF POS x .050[1.27]) + .015[0.38] REF
"A"
CL
SFM-XX-D-LC-X
(NO. OF POS x .050[1.27]) + .155[3.94] REF
C-XX-01-XXX
(SEE NOTE 5)
.180 4.57 REF
.110 2.79 REF
.015 0.38 REF
"A"
(SEE TABLE 1)
"A"
CL
2 MAX SWAY (TYP)
"B" REF
1 MAX
SWAY (TYP)
.050 1.27
.005 0.13 REF
(NO. OF POS x .050[1.27]) - .050[1.27] REF
FIG 1
THROUGH HOLE/STRAIGHT MODIFIED
PLATING SPECIFICATION
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-H: 30µ" HEAVY GOLD IN CONTACT AREA,
3µ" GOLD ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-STL: 30µ" SELECTIVE GOLD IN CONTACT AREA,
TIN/LEAD (90/10+/-5%) TAIL
(ONLY AVAILABLE ON -02 OR -L2 LEADSTYLES)
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
SECTION "A"-"A"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
INSULATOR: LCP, COLOR: BLACK
CONTACT: TIGER EYE = BeCu
TIGER EYE LITE = PHOSPHOR BRONZE
F:\DWG\MISC\MKTG\SFM-1XX-XX-XXX-D-XXX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 x .050 SOCKET STRIP DOUBLE ROW ASSEMBLY
DWG. NO.
BY: JORDAN
12/11/89
SHEET 1 OF 4
REVISION DC
"R"
(SEE NOTE)
"S"
(SEE NOTE)
(TOL ACCUM ±.005[0.13] OVER 50 POS)
C-XX-02-XXX
.019±.010 0.48±0.254
02
+.005
+0.13
.190 - .002 4.83 - 0.05
.1575±.0050 4.000±0.127
01
IN-PROCESS
-X2
2 MAX SWAY (TYP)
FIG 3
(SAME AS FIG 1, DIFFERENT AS SHOWN)
FOR HAND FILL ONLY
NOTE: "R" = USED MEASURED DIMENSION REF
"S" = {("R" - .1575[4.000])/2}±.020[0.51]
NOTE: DIMENSION APPLIES PRIOR
TO RE-PRESS, SEE SECTION "B-B"
FOR FINISHED DIMENSION
"B"
.190 4.83
SFM-XX-D-LC-X
+.002
+0.051
.185 - .005 4.70 - 0.127
(SEE NOTE 7)
4°
SEE NOTE 3
SEE NOTE
"B"
FIG 2
2°
.165 4.19 REF
-X2: SURFACE MOUNT
SECTION "B"-"B"
.394 10.01
REF
"A"±.010[0.25] (SEE TABLE 2)
.225 5.72
REF
(NO. OF POS x .050[1.27]) + .125[3.18] REF
PPP-02
.062 1.57
SFM-XX-D-A-X
.050 1.27
REF
FIG 5
.050 1.27
REF
R REF
(NO. OF POS x .050[1.27]) + .075[1.91] REF
FIG 4
-A: ALIGNMENT PIN
(PAD TO BE ORIENTED A SHOWN FOR 5-12 POSITION PARTS)
(FOR 13-50 POSITION PARTS, PAD MAY BE ORIENTED IN EITHER DIRECTION)
PROPRIETARY NOTE
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: JORDAN
12/11/89
SHEET 2 OF 4
REVISION DC
SFM-XX-D-LC-X
(NO OF POS x .050[1.27] + .360[9.14]
.065 1.65
.056 1.42 REF
(NO OF POS x .050[1.27] + .075[1.91] REF
LC-05-TM
.218 5.52
REF
C
02
.010 0.25 REF
01
FIG 6
-LC: LOCKING CLIP
(AVAILABLE IN ALL LEADS)
CPS-RR-M2-01-X
'E'
SFM-XX-D-DS
.070 1.78
REF
.145 3.68
.335 8.50
REF
"D"
WT-27-XX-T
(NO OF POS x .050[1.27] + .600[15.24] REF
.114 2.90 REF
.012 0.30
REF
ACCRT-01
DETAIL 'E'
SCALE 6 : 1
(NO OF POS x .050[1.27] + .185[4.70] REF
SFM-XX-D-SN
"C"
FLUSH TO .005[0.13] ABOVE
FIG 8
(SAME AS FIG 2, DIFFERENT AS SHOWN)
"C" REF
WT-27-XX-T
PROPRIETARY NOTE
"C"
(NO OF POS x .050[1.27] + .085[2.16] REF
.026 0.66
REF
2 MAX SWAY (TYP)
SECTION "C"-"C"
FIG 7
-SNX: SOLDER NAIL
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: JORDAN
12/11/89
SHEET 3 OF 4
REVISION DC
PT-1-24-13-09
PACKAGING VIEW
PACKAGE PARTS IN TUBES AS SHOWN (SEE NOTE 4)
.630 16.00
PT-SFM004-X1-X3-D
PT-SFM004-X1-X3-D
PT-1-24-01-60
2.205 56.00
"D"
"D"
UNWINDING DIRECTION
(SEE NOTE 6)
SECTION "D"-"D"
SCALE 2 : 1
PACKAGING VIEW
-TR: TAPE AND REEL
*FOR MACHINE LOADING OF TUBES FOR PARTS W/O PADS USE PT-1-24-14-09,
W/PADS USE PT-1-24-13-09
5 POS -01 AND -03 LEAD STYLES MAY BE TUBED USING
PT-1-24-15-09, TP-24-02
PROPRIETARY NOTE
SHEET SCALE: 1.5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: JORDAN
12/11/89
SHEET 4 OF 4
