F-219
SFMC–125–T2–L–D–P
SFMC–117–T1–L–D
SFMC–105–T2–L–D
SFMC–112–03–L–D
(1.27 mm) .050"
SFMC SERIES
FLEXIBLE PIN COUNT TIGER EYE SOCKETS
SPECIFICATIONS
Board Mates:
TFM
For complete specifications and
recommended PCB layouts
see www.samtec.com?SFMC
Cable Mates:
FMTP, FFMD*
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Tiger Eye™ = BeCu
Tiger Eye™ LITE=
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.9 A per pin
(2 pins powered)
Voltage Rating:
220 VAC/310 VDC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
(3.05 mm) .120" to
(4.06 mm) .160"
Normal Force:
Standard= 132 g (1.29 N) avg.
LIF= 90 g (0.88 N) avg.
Max Cycles:
10,000 with 30 µ" (0.76 µm) Au
RoHS Compliant:
Yes
*Note: Standard FFMD callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
Any number of
positions from
2 through 50
High-reliability
Tiger Eye™
contacts
Slotted SMT tails
Available with optional
pick & place pads
SFMC
1
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-26)
(0.15 mm) .006" max (27-50)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
LEAD
STYLE
NO. PINS
PER ROW
PLATING
OPTION
–01, –03
= Through-hole
02 thru 50
–L1, –L3
= Low Insertion Force
Through-hole
RECOGNITIONS
LEAD
STYLE
For complete scope
of recognitions see
www.samtec.com/quality
A
–02
B
= Surface Mount
– 01, –L1, –T1 (3.05) (0.51)
– 03, –L3
.120
(1.91)
.075
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
.020
(0.41)
.016
–T1
ALSO AVAILABLE
(MOQ Required)
(1.27) .050 x No. of Positions
+ (0.38) .015
• Other platings
(1.27)
.050
TYP
(3.05)
.120
–T2
(1.27)
.050 TYP
(0.51)
.020
(1.27)
.050
–P OPTION
(0.58) .023
(0.13)
.005
TYP
(4.57)
.180
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(10.00)
.394
x
(5.72)
.225
= Through-hole
Tiger Eye™ LITE
= Surface Mount
Tiger Eye™ LITE
A
B
(0.13)
.005
TYP
(4.19)
.165
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
OPTION
–K
= (4.00 mm) .157
DIA Polyimide
film Pick &
Place Pad
(4 positions
minimum)
–P
–L2
Surface Mount
FILE NO. E111594
D
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
= Plastic Pick &
Place Pad
(5 positions
minimum)
–TR
= Tape & Reel
很抱歉,暂时无法提供与“SFMC-118-T2-F-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+29.2958725+3.78987
