855-8006
855-8006
    WAGO(万可电子)
    WAGO - 855-8006 - Power Tap, Fuse, 2 A, 400 VAC, M5 Screw Mount, 855 Series
855-8006 数据手册
Data sheet | Item number: 855-8006 Power tap; for busbar; with fuse; Mounting screw M6 www.wago.com/855-8006 Item description Short description: WAGO's Voltage Taps serve as busbar taps for measuring L- or N-conductors and are equipped with an integrated SIBA fuse with indicator. The built-in fuse is located directly above the voltage-carrying busbar. In the event of an overload and short circuit, the downstream measurement unit is safely disconnected before major damage occurs. The voltage taps can be mounted directly on the busbar. Mounting is performed via M6 screw. The measurement line is connected via Push-in CAGE CLAMP®, the universal connection technology for all conductor types that provides the simplicity of push-in terminations. Rigid conductors, such as solid and stranded conductors, as well as fine-stranded conductors with ferrules, can be terminated by simply pushing them in – no operating tool needed. The connection unit with a fuse and Push-in CAGE CLAMP® rotates. This creates additional added value by directly guiding subsequent wiring into the cable channel. In addition, the voltage taps can be labeled with two different marking options. Features: Fuse-protected voltage tap for measurement purposes Safe protection through integrated fuse with indicator (measurement line/device) WAGO push-in termination technology Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 1/5 Data sheet | Item number: 855-8006 www.wago.com/855-8006 WAGO push-in termination technology WAGO labeling options (WMB markers or marking strips) Note: Spare fuse: WAGO 855-8020 Data Technical data Output – voltage tap Rated voltage AC 400 V Fuse (voltage path) 2 A; 450 V; F; 70 kA; 5 x 25 mm (WAGO 855-8020) Connection data Connection technology Push-in CAGE CLAMP® WAGO Connector WAGO 2724 Series Solid conductor 0.2 … 6 mm² / 24 … 10 AWG Fine-stranded conductor 0.2 … 6 mm² / 24 … 10 AWG Strip length 10 … 12 mm / 0.39 … 0.47 inch Physical data Width 57 mm / 2.244 inch Height 14 mm / 0.551 inch Depth 48 mm / 1.89 inch Mechanical data Mounting type M6 mount Mounting type Installation on busbar Material data Weight 30 g Environmental requirements Surrounding air temperature (operation) -25 … 70 °C Surrounding air temperature (storage) -40 … 85 °C Relative humidity 5 … 85 % (without condensation) Operating altitude (max.) 2000 m Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 2/5 Data sheet | Item number: 855-8006 www.wago.com/855-8006 Operating altitude (max.) 2000 m Vibration resistance 10g (industry; 5 … 2000 Hz; per IEC 60068-2-6); 4g (ship; 5 … 150 Hz; per IEC 60068-2-6) Standards and specifications Standards/Specifications IEC 60947-7-3 Commercial data PU (SPU) 1 Stück Packaging type bag Country of origin NL GTIN 4055143720038 Customs tariff number 85366990990 Optional accessories General accessories Item no.: 2007-8873 Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured www.wago.com/2007-8873 Item no.: 2007-8874 Compact terminal block; for current and voltage transformers; 6,00 mm²; multicoloured www.wago.com/2007-8874 Item no.: 2007-8875 Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8875 Item no.: 2007-8876 Compact terminal block; for 3-phase current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8876 Item no.: 2007-8877 Compact terminal block; for current transformer circuit; 6,00 mm²; multicoloured www.wago.com/2007-8877 Item no.: 2857-570/024-000 www.wago.com/2857-570 3-Phase Power Measurement Module; 3x400/690 V/RC; Modbus RTU; Digital output; Configuration via /024-000 software; Supply voltage: 24 VDC Item no.: 2857-570/024-001 www.wago.com/2857-570 3-Phase Power Measurement Module; 3x400/690 V/1 A; Modbus RTU; Digital output; Configuration via /024-001 software; Supply voltage: 24 VDC Item no.: 2857-570/024-005 www.wago.com/2857-570 3-Phase Power Measurement Module; 3x400/690 V/5 A; Modbus RTU; Digital output; Configuration via /024-005 software; Supply voltage: 24 VDC Item no.: 855-8020 Miniature fuse; 5 x 25 mm; with indicator www.wago.com/855-8020 Item no.: 857-560 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 3/5 Data sheet | Item number: 855-8006 www.wago.com/855-8006 Item no.: 857-560 Voltage signal conditioner; Voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC; 6 mm module width Item no.: 857-569 Power signal conditioner; Current and voltage input signal; Current and voltage output signal; Digital output; Configuration via software; Supply voltage: 24 VDC; 6 mm module width www.wago.com/857-560 www.wago.com/857-569 Downloads Documentation Bid Text 855-8006 19 Feb 2019 xml 4.6 kB Download 20 Feb 2019 docx 17.6 kB Download V 1.0.0 pdf 736.5 kB Download V 1.0.0 pdf 265.8 kB Download URL Download X81 - Datei 855-8006 docx - Datei Instruction Leaflet Potentialabgriffe Additional Information Disposal; Electrical and electronic equipment, Packaging Environmental Product Compliance Compliance Search Environmental Product Compliance 855-8006 Power tap; for busbar; with fuse; Mounting screw M6 Installation Notes Installation Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 4/5 Data sheet | Item number: 855-8006 www.wago.com/855-8006 Installation on busbar; fastening with Allen wrench Installation Integrated SIBA fuse (overload and short circuit protection) Installation Push-in CAGE CLAMP® connection technology Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 03.08.2021    Page 5/5
855-8006 价格&库存
很抱歉,暂时无法提供与“855-8006”相匹配的价格&库存,您可以联系我们找货
