862-0504/RN01-0000
862-0504/RN01-0000
    WAGO(万可电子)
    WAGO - 862-0504/RN01-0000 - TERMINAL BLOCK PLUGGABLE 16 POSITION, 20-12AWG
862-0504/RN01-0000 数据手册
Fastening Options chassis sten onto screw a F m o g Fasten fr lf by self tappin se om top ia screw ia v fr v ) n e w Ø st lo m a F (2.9 m Ø) be m w m re (3 sc t and nu tapping ) into from top (2.9 mm Ø sing hou terminal mmØ) screw (3 ia v n e st ssis Fa ad in cha into thre nut 24 0.94” 36 1 .42” 24 0.94” 12 0.47” and ia screw Fasten v ) Ø (3 mm from top 48 1 .89” ounting ap-in m ing via sn Fasten feet Ferrules Insulated ferrules Uninsulated ferrules Sleeve for mm2 AWG Color Stripped length mm L 0.5 0.75 1.0 1.5 0.5 0.75 1.0 1.5 22 20 18 16 22 20 18 16 white grey red black 12.0 12.0 12.0 12.0 10 10 10 10 16.0 16.0 16.0 16.0 10 10 10 10 L1 D mm D D2 Item No. Pack.-unit pcs 10.0 10.0 10.0 10.0 3.1 3.3 3.5 4.0 2.1 2.3 2.5 2.8 2.6 2.8 3.0 3.5 1.0 1.2 1.4 1.7 1.0 1.2 1.4 1.7 216-241 216-242 216-243 216-244 216-141 216-142 216-143 216-144 1000 1000 1000 1000 1000 1000 1000 1000 Tools Crimp Tool 206-204 0.25 - 4 mm2 AWG 24 - 12 Subject to design changes Stripper / Cutter 206-101 0.5 - 6 mm2 AWG 28 - 8 WAGO Corporation N120 W19129 Freistadt Road; P.O. Box 1015; Germantown, WI 53022 1-800 DIN Rail (346-7245) Fax: (262) 255-3232 info.us@wago.com www.wago.us 51011208 0888-0153/0001-3601 rev2 10/05 Printed in the United States Dimensions (mm) 862 Series Terminal Blocks for Chassis Mounting 862 Series - Terminal Block for Chassis Mounting 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A l Available in black and white without ground/ earth contact 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A 2U for fastening screw 3 mm /0.118 in Ø or for self tapping screw 2.9 mm / 0.114 in Ø from top without marking L1-N (pre-marked) N-L1 (pre-marked) for self tapping screw 2.9 mm / 0.114 mm Ø from below without marking L1-N (pre-marked) N-L1 (pre-marked) 1 snap-in foot per pole without marking L1-N (pre-marked) N-L1 (pre-marked) for fastening screw 3 mm / 0.008 in Ø or for self tapping screw 2.9 mm / 0.114 in Ø from top without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 1 snap-in foot per pole without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 snap-in feet at pos. 1+3 without marking PE-N-L1 (pre-marked) N-PE-L1 (pre-marked) (pre-marked) N-PE-L1 (pre-marked) PE-N-L1 Item No. black l 10 – 11 mm / 0.41 in 2 poles /8 connection points with ground/ earth contact 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A Item No. white 2U 862-0552 862-1552 862-2552 862-0652 862-1652 862-2652 500 500 500 862-0562 862-1562 862-2562 862-0662 862-1662 862-2662 500 500 500 862-0532 862-1532 862-2532 862-0632 862-1632 862-2632 500 500 500 Accessories Item No. black Item No. white Available in black and white Pack.-unit pcs 862-0503 862-1503 862-2503 862-8503 862-9503 862-0603 862-1603 862-2603 862-8603 862-9603 250 250 250 250 250 862-0533 862-1533 862-2533 862-8533 862-9533 862-0633 862-1633 862-2633 862-8633 862-9633 250 250 250 250 250 862-0593 862-1593 862-2593 862-8593 862-9593 862-0693 862-1693 862-2693 862-8693 862-9693 250 250 250 250 250 Comb-type jumper bar, can easily be inserted into the wire entry, 32 A 862-482 5 Test plug, with cable 500 mm / 1'7.7" 2 mm /0.079 in Ø, red 210-136 1 Test plug, with cable 500 mm / 1'7.7" 2.3 mm /0.091 in Ø, yellow 210-137 50 (5 x 10) Screwdriver, with partially inslated shaft (3.5 x 0.5) mm (.14 x .0025) in 210-620 1 Marker strip, white, plain for central marking; 7.5 mm wide, on roll, 50 m long 709-178 1 Marker strip, white, plain for central marking; 7.5 mm wide, on roll, 300 m long 709-188 1 Cost-effective features: The new 862 Series chassis mount terminal block was developed specifically to minimize wiring costs, while accommodating requirements for easy mounting, multiple connection points, marking, and handling. • The new 862 Series allows the connection of up to four conductors from wire size 20 to 12 AWG. Due to the multiple connection points per pole, different wire sizes can be used within the same terminal block position. • The CAGE CLAMP®S termination technology allows solid conductors, stranded conductors with ferrules, or ultrasonically bonded conductors to be easily connected by simply pushing the conductor into the contact. • An integrated push button, with molded-in slots, accommodates fast and easy wiring of all conductor types - either by hand, or with a slotted tip/ phillips screwdriver. • Convenient automatic grounding contact available as an option (see page 3 for illustration). • Snap-in mounting feet for fast assembly (see back page for illustration). • Flexible marking options with standard marking (pre-marked), marker strip, or custom marked per your specifications with large quantity orders. • Built-in test points simplify testing with 2 mm / 0.079 in diameter test plug. 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A 2U l 10 – 11 mm / 0.41 in 10 – 11 mm / 0.41 in 3 poles /12 connection points Pack.-unit pcs 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A without ground/ earth contact for fastening screw 3 mm Ø or for self tapping screw 2.9 mm Ø from top without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 1 snap-in foot per pole without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 snap-in feet at pos. 1+4 without marking PE-N-L1-L2 (pre-marked) N-PE-L1-L2 (pre-marked) (pre-marked) N-PE-L1-L2 (pre-marked) PE-N-L1-L2 for fastening screw 3 mm Ø or for self tapping screw 2.9 mm Ø from top without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 1 snap-in feet at pos. 2+4 without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 snap-in feet at pos. 1+3+5 without marking PE-N-L1-L2-L3 (pre-marked) L3-N-PE-L1-L2 (pre-marked) (pre-marked) L3-N-PE-L1-L2 (pre-marked) PE-N-L1-L2-L3 4 x AWG 20 –12 300 V, 20 A 600 V, 5 A 2U l 10 – 11 mm / 0.41 in 4 poles /16 connection points with ground/ earth contact 4 x 0.5 – 4 mm2 500 V/6 kV/2 32 A 5 poles /20 connection points Item No. black Item No. white Pack.-unit pcs 862-0504 862-1504 862-2504 862-8504 862-9504 862-0604 862-1604 862-2604 862-8604 862-9604 200 200 200 200 200 862-0534 862-1534 862-2534 862-8534 862-9534 862-0634 862-1634 862-2634 862-8634 862-9634 200 200 200 200 200 862-0594 862-1594 862-2594 862-8594 862-9594 862-0694 862-1694 862-2694 862-8694 862-9694 200 200 200 200 200 Item No. black Item No. white Pack.-unit pcs 862-0505 862-1505 862-2505 862-8505 862-9505 862-0605 862-1605 862-2605 862-8605 862-9605 200 200 200 200 200 862-0525 862-1525 862-2525 862-8525 862-9525 862-0625 862-1625 862-2625 862-8625 862-9625 200 200 200 200 200 862-0515 862-1515 862-2515 862-8515 862-9515 862-0615 862-1615 862-2615 862-8615 862-9615 200 200 200 200 200 Ground (earth) contact Conductor connection Marking and testing • Makes an automatic contact to the mounting plate • Varnish coating is penetrated automatically • Four conductors per pole • For solid and flexible conductors • Mixed wiring with solid and flexible conductors of different cross sections • Marking by direct printing and/or marker strips • Testing with test plug 2 mm Ø
862-0504/RN01-0000 价格&库存
很抱歉,暂时无法提供与“862-0504/RN01-0000”相匹配的价格&库存,您可以联系我们找货
862-0504/RN01-0000
  • 1+34.81191
  • 10+28.40481
  • 100+25.09448
  • 250+23.08929
  • 500+22.18755
  • 1000+21.22649
库存:1073
