09060152912
09060152912
    HARTING(浩亭)
    P=5.08mm
    板对板连接器 面板安装 针脚数:15Pin 间距:5.08mm 排数:2
09060152912 数据手册
Low currents and voltages DIN power male connector Type H standard contacts have a silver plated surface. This precious metal has excellent conductive properties. In the course of a contact’s lifetime, the silver surface generates a black oxide layer due to its affinity to sulphur. This layer is smooth and very thin and is partly interrupted when the contacts are mated and unmated, thus guaranteeing very low contact resistances. In the case of very low currents or voltages small changes to the transmitted signal may be encountered. In systems where such a change to the transmitted signal could lead to faulty functions and also in extremely aggressive environments, HARTING recommend the use of gold plated contacts. General information Design IEC 60603-2 No. of contacts 15 Contact spacing 5,08 mm / 6,5 mm between the rows Test voltage 3100 V Contact resistance < 8 mOhm Insulation resistance Working current > 1012 Ohm 15 A@20°C (see derating diagram) Temperature range -55°C … +125°C Termination technology solder pins Clearance distance min. 4,5 mm Creepage distance min. 8,0 mm Below is a table derived from actual experiences. types: H male Insertion and withdrawal force 15pol. ≤ 90N Mating cycles - PL1 acc. to IEC 60 603-2 => UL file E102079 RoHS - compliant Yes Leadfree Yes Hot plugging No 500 mating cycles Soldering instructions The connectors should be protected when being soldered in a dip, flow or film soldering baths. Otherwise, they might become contaminated as a result of soldering operations or deformed as a result of overheating. Insulator material Material PBT (thermoplastics, glass fiber reinforcement 30%) Color RAL 7032 (grey) UL classification UL 94-V0 Material group acc. IEC 60664-1 IIIa (175 < CTI < 400) NFF classification I3, F4 (1) For prototypes and short runs protect the connectors with an industrial adhesive tape, e.g. Tesaband 4331 (www.tesa.de). Cover the underside of the connector moulding and the adjacent parts of the pcb as well as the open sides of the connector. This will prevent heat and gases of the soldering apparatus from damaging the connector. About 140 + 5 mm of the tape should suffice. (2) For large series a jig is recommended. Its protective cover with a fast action mechanical locking device shields the connectors from gas and heat generated by the soldering apparatus. As an additional protection a foil can be used for covering the parts that should not be soldered. Cross section of solder pins Contact material Copper alloy Plating termination zone Ag or Au Plating contact zone Ag or Au Derating diagram acc. to IEC 60512-5 (Current carrying capacity) A The current carrying capacity is limited by maximum temperature of materials for inserts and contacts including terminals. The current capacity curve is valid for continuous, non interrupted current loaded contacts of connectors when simultaneous power on all contacts is given, without exceeding the maximum temperature. Control and test procedures according to DIN IEC 60512-5 15 12 Electrical load [A] Released / Freigegeben 2011-10-04-06:44:08:007 UTC Contact material 9 6 3 Date 0 20 40 60 Temperature [°C] 80 100 120 °C EC01557 Mod. Subject to change without prior notice, all rights reserved Name Detail. 28/04/11 mte Inspec. 28/04/11 TD Stand. Date Name HARTING Electronics GmbH & Co. KG Technical data sheet DIN power male connector DS 09 06 110 02 02 Page 1 of 1
09060152912 价格&库存
很抱歉,暂时无法提供与“09060152912”相匹配的价格&库存,您可以联系我们找货
  • 1+120.61846
  • 20+109.26332
  • 60+99.93245
  • 100+95.68026
  • 260+88.93665
库存:23
09060152912
  • 1+173.475681+22.47117
