Han® 18 EE
Size 10 B
500 V
16 A
Number of contacts
18
Inserts
Part No.
Identification
Series
Crimp terminal
Han® EE
Male insert (M)
Female insert (F)
09 32 018 3001
09 32 018 3101
Drawing
Dimensions in mm
Han
E / EE
Order contacts
separately
1)
Distance for contact max. 21 mm
Contact arrangement
View from termination side
Panel cut out for inserts
for use without
hoods/housings
Wire gauge
Identification
(mm )
2
Part No.
Male contacts
Female contacts
Crimp contacts
Power contacts
silver plated
gold plated
0.14-0.37
0.5
0.75
1.0
1.5
2.5
3
4
*09 33 000 6127*
09 33 000 6121
09 33 000 6114
09 33 000 6105
09 33 000 6104
09 33 000 6102
09 33 000 6106
09 33 000 6107
*09 33 000 6227*
09 33 000 6220
09 33 000 6214
09 33 000 6205
09 33 000 6204
09 33 000 6202
09 33 000 6206
09 33 000 6207
0.14-0.37
0.5
0.75
1.0
1.5
2.5
4.0
*09 33 000 6117*
09 33 000 6122
09 33 000 6115
09 33 000 6118
09 33 000 6116
09 33 000 6123
09 33 000 6119
*09 33 000 6217*
09 33 000 6222
09 33 000 6215
09 33 000 6218
09 33 000 6216
09 33 000 6223
09 33 000 6221
Coding Pin
09 33 000 9954
Dimensions in mm
Operation contact
Identification
20 10 001 3311
* only to be used with BUCHANAN crimping tool 09 99 000 0001
and adjustment gauge 09 99 000 0203
Relay contact
Crimp contact identification
Identification
Wire gauge
no groove
0.14-0.37 mm2 AWG 26-22
no groove
0.5 mm
AWG 20
1 groove*
0.75 mm
AWG 18
1 groove
1. mm
AWG 18
2 grooves
1.5 mm
AWG 16
3 grooves
2.5 mm
AWG 14
wide groove
3.0 mm
AWG 12
no groove
4. mm
AWG 12
* on the back crimp collar
2
2
2
2
2
2
2
Stripping
length
7,5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
7.5 mm
To avoid accidental incorrect mating of adjacent connectors a coding
system is required. Coding is effected – by means of a code pin. For this reason a female contact has to be inserted into the selected chamber.The code
pin has to be assembled into this contact from the
mating side. The opposite male contact is omitted.
Crimp zone
FOC contacts
for 1 mm plastic fibre
Drawing
Crimp zone
03
19
20 10 001 3321
Stock items in bold type
很抱歉,暂时无法提供与“0932 018 3001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+279.119791+36.27233
- 10+237.1910810+30.82359
- 25+222.3366625+28.89322
- 50+211.7309650+27.51498
- 100+201.63181100+26.20257
- 250+189.02346250+24.56408
- 国内价格
- 1+87.82560
- 10+83.70000
- 30+76.55040
