09474747004
09474747004
    HARTING(浩亭)
09474747004 数据手册
Han® RJ45 female module cat. 6    Number of contacts 8 Part number Identification Male insert (M) Female insert (F) Female module (Gender Changer) Drawing Dimensions in mm 09 14 001 4721 for patch cable Han® Data Sheet 0352-2 Han® RJ45 female module cat. 6 Features • Single module with completely shielded RJ45 metal block • Cat 6 for all data pairs (all 8 pins) • Conforming to the RoHS directive • The RJ45 inserts are protected by a reliable plastic insulator • Patch cables are assembled/removed without tools Technical characteristics Specifications DIN EN 60 664-1 DIN EN 61 984   Inserts Number of contacts Electrical data acc. to EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree Transmission features Transmission rate Insulation resistance Material Limiting temperatures Flammability acc. to UL 94 Mechanical working life - mating cycles 8 1 A 50 V 0.8 kV 3 1A 50 V 0.8 kV 3 Category 6 / Class E up to 250 MHz; acc. to ISO/IEC 24 702 or and ISO/IEC 11 801 10/100/1000 Mbit/s ≥ 1010 Ω polycarbonate -40 °C ... +85 °C V0 ≥ 500 Han® RJ45 male module Patch cables     Number of contacts 8 Identification Part number Male module for patch cable Drawing Dimensions in mm Drawing Dimensions in mm 09 14 001 4623 Adapter for HARTING patch cable 09 14 000 9966 Identification Part number Cat. 5e RJ45 patch cable 0,2 m 09 47 474 7001 09 47 474 7002 09 47 474 7003 09 47 474 7004 09 47 474 7005 09 47 474 7006 09 47 474 7007 09 47 474 7008 09 47 474 7009 09 47 474 7010 09 47 474 7011 09 47 474 7012 09 47 474 7013 09 47 474 7014 09 47 474 7015 09 47 474 7016 09 47 474 7017 09 47 474 7018 09 47 474 7019 09 47 474 7020 09 47 474 7021 09 47 474 7022 09 47 474 7023 Cat. 6 RJ45 patch cable 09 47 474 7101 09 47 474 7102 09 47 474 7103 09 47 474 7104 09 47 474 7105 09 47 474 7106 09 47 474 7107 09 47 474 7108 09 47 474 7109 09 47 474 7110 09 47 474 7111 09 47 474 7112 09 47 474 7113 09 47 474 7114 09 47 474 7115 09 47 474 7116 09 47 474 7117 09 47 474 7118 09 47 474 7119 09 47 474 7120 09 47 474 7121 09 47 474 7122 09 47 474 7123 0,3 m 0,4 m Length 0,5 m 0,6 m 0,7 m 0,8 m 0,9 m 1,0 m 1,5 m 2,0 m 2,5 m 3,0 m 4,0 m 5,0 m 6,0 m 7,0 m 7,5 m 8,0 m 9,0 m 10 m 15 m 20 m 0,2 m 0,3 m 0,4 m Length 0,5 m 0,6 m 0,7 m 0,8 m 0,9 m 1,0 m 1,5 m 2,0 m 2,5 m 3,0 m 4,0 m 5,0 m 6,0 m 7,0 m 7,5 m 8,0 m 9,0 m 10 m 15 m 20 m Han® RJ45 male module Patch cables Features • Locking lever protection for RJ45 connector latch • Very short plug design in combination with robust bend protection • RoHS compliant • Fully EMC screened (aluminium-clad foil and braid) Technical characteristics Specifications ISO/IEC 24 702 ISO/IEC 11 801 ISO/IEC 61 935-2   Cat. 5 e RJ45 patch cable Transmission features Transmission rate Cable type Material cables Limiting temperatures - mobile - stationary Flammability Degree of protection Category 5 / Class D up to 100 MHz; acc. to ISO/IEC 24 702 or ISO/IEC 11 801 10/100/1000 Mbit/s 1:1 EIA/TIA 568 B, 8 poles SF/UTP, PUR, yellow 0 °C ... +60 °C -40 °C ... +80 °C flame retardant, halogen-free IP 20   Cat. 6 RJ45 patch cable Transmission features Transmission rate Cable type Material cables Limiting temperatures - mobile - stationary Flammability Degree of protection Category 6 / Class E up to 250 MHz; acc. to ISO/IEC 24 702 or ISO/IEC 11 801 10/100/1000 Mbit/s 1:1 EIA/TIA 568 B, 8 poles SF/UTP, PUR, yellow 0 °C ... +60 °C -20 °C ... +80 °C flame retardant, halogen-free IP 20 Han® RJ45 male module RJ Industrial     Number of contacts 4/8 Identification Part number Male insert (M) Male Module for RJ Industrial Drawing   View termination side Dimensions in mm 09 14 001 4623 Han-Modular® RJ Industrial RJ45 connector set Cat. 5 4 pins for AWG 24 ... 22 4 pins for AWG 26 09 45 400 1100 09 45 400 1109 Cat. 6 Gigalink, 8 pins, white Gigalink, 8 pins, blue 09 45 400 1500 09 45 400 1510 Cat. 6 10G, 8 pins, 09 45 400 1560 Set consists of the relevant RJ45 insert and the suitable adapter for Han® RJ45 module, male. HARTING RJ Industrial® Gigalink Assembly tool 09 45 800 0500 Han® RJ45 male module RJ Industrial Features Technical characteristics Han-Modular® RJ Industrial RJ45 connector set • Conforming to the RoHS directive • 360° shielded contact • Field assembly without tools possible by means of HARAX® rapid termination in IDC technology • Suitable for termination of massive and flexible wires Specifications IEC 60 603-7 DIN EN 60 664-1 DIN EN 61 984   HARTING RJ Industrial®, 4 pins Number of contacts Transmission features Transmission rate Wire termination Terminated cable - Conductor cross section flexible solid - Cable outside diameter Material insert Limiting temperatures Han-Modular® RJ Industrial Gigalink RJ45 connector set • Conforming to the RoHS directive • 360° shielded contact • Field assembly by means of piercing contacts • Suitable for termination of flexible wires 4 Category 5 / Class D up to 100 MHz; acc. to ISO/IEC 11 801:2002 and EN 50 173-1 10/100 Mbit/s IDC contacts; without tools AWG 24/7 ... AWG 22/7 AWG 23/1 ... AWG 22/1 ≤ 1.6 mm polyamide -40 °C ... +70 °C   HARTING RJ Industrial® Gigalink, 8 pins Number of contacts Transmission features Transmission rate Wire termination Terminated cable - Conductor cross section flexible - Cable outside diameter Material insert Limiting temperatures 8 Category 6 / Class E up to 250 MHz; acc. to ISO/IEC 11 801:2002 and EN 50 173-1 10/100/1000 Mbit/s Piercing contacts AWG 28/7 ... AWG 24/7 ≤ 1.05 mm polyamide -40 °C ... +70 °C   HARTING RJ Industrial® 10G, 8 pins Number of contacts Transmission features Transmission rate Wire termination Terminated cable - Conductor cross section flexible solid - Cable outside diameter Material insert Limiting temperatures 8 Category 6 / Class E up to 250 MHz; acc. to ISO/IEC 11 801:2002 and EN 50 173-1 10/100/1000 Mbit/s IDC contacts; without tools AWG 27/7 ... AWG 22/7 AWG 27/1 ... AWG 22/1 ≤ 1.5 mm polyamide -40 °C ... +70 °C HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Fon: +49 57 72 47-97100 | Fax: +49 57 72 47-124 Internet: www.HARTING.com | E-Mail: HARTING.Electric@HARTING.com 2011-03-10
09474747004 价格&库存
很抱歉,暂时无法提供与“09474747004”相匹配的价格&库存,您可以联系我们找货
    库存:10
    09474747004
    • 1+130.838061+16.99520
    • 3+113.265403+14.71260
    • 5+100.129405+13.00630
    • 10+87.6023510+11.37910
    库存:1
    09474747004
    • 1+84.78947
    • 10+83.10242
    • 50+81.43621
    库存:109
