BNC7T-J-P-GN-ST-EM1D 数据手册
75 Ω BNC TO 12 GHz
BNC
Cable Assemblies
SERIES
RFC6T, RFA6T,
RFB6T, RF179
END 1
CONNECTOR
RFC6T*
END 2
CONNECTOR
OVERALL
LENGTH
–“XXXX”
–74SP3
= 12G-SDI, Belden 4694R Cable
= 75 Ω BNC Straight Plug
RFA6T
= Overall Length
in millimeters
–D4SP3
= RG 6 Cable
= 75 Ω BNC Die Cast Straight Plug
(RFA6T, RFB6T, RF179 only)
RFB6T
–0300 (300 mm)
11.81" minimum
(RFA6T, RFB6T, RFC6T)
–74BJ3
= Belden 1694A Cable
–0100 (100 mm)
3.94" minimum
(RF179)
= 75 Ω BNC Bulkhead Jack (RF179 only)
RF179
–74RP3
= RG 179 Cable
= 75 Ω BNC Right-angle Plug
(RFA6T, RFB6T, RFC6T only)
ALSO AVAILABLE
75 Ω: DIN 1.0/2.3, HDBNC = RFA6T, RFB6T, RFC6T
75 Ω: DIN 1.0/2.3, SMB, MCX, MMCX = RF179
*Designed to meet SMPTE 2082
12G-SDI specifications.
BNC
Cable Connectors
CONNECTORS FOR INDUSTRY STANDARD CABLES
BNC7T-CA
**BNC7T-P-C-GN-ST-CA3
Machined, RG 179 Cable
**BNC7T-P-C-GN-RA-CA3
**BNC7T-P-C-GN-ST-CA6
*Machined, RG 6 Cable
**BNC7T-P-C-GN-RA-CA6
**BNC7T-P-C-GN-ST-CA6B
Belden 4694R Cable
**BNC7T-P-C-GN-RA-CA6B
Belden 4694R Cable
**BNC7T-J-C-GN-ST-BH3
Machined, Bulkhead, RG 179 Cable
BNC7T- P-C-GN-ST-CA3D
Die Cast, RG 179 Cable
BNC7T-P-C-GN-ST-CA6D
Supplied with pins, washers,
nuts, gaskets and ferrules.
See website for dimensions.
**Add ”–B” to the end of the part number for bulk packaging
*Designed to meet SMPTE 2082 12G-SDI specifications.
(21.70) .854
(21.62) .851
(14.48)
.570
(6.85)
.270
DIA
(2.70) .106 DIA
–CA3D
(29.80) 1.173
(14.50)
.571
C
(17.50)
.689
Hex.
(9.65)
.380
–P–ST–CA3 & –P–ST –CA6
–CA6D
–J–ST–BH3
MACHINED
DIE CAST
Note:
Additional plating options available
on Cable Assemblies, Cable
Connectors and Board Connectors.
Contact RFGroup@samtec.com
F-224
P-C = Cable Plug
J-C = Cable Jack
GN = Plating (10 µ" Gold on contact,
Nickel on outer contact and shell)
ST = Straight
RA = Right-angle
TERMINATION
C (DIA)
–CA3
(2.70) .106
–CA6
(6.85) .207
samtec.com/BNC
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
0.15)
.400
(13.90)
.547
75 Ω DIE CAST BNC TO 12 GHz
BNC
Board Connectors
BNC7T-TH, BNC7T-BH,
BNC7T-BM, BNC7T-EM
BNC7T
GENDER
TYPE
–J
–P
= Jack
Cable Mates:
(15.40)
.606
ORIENTATION
–GN
= PCB
Mount
RF179, RFA6T, RFB6T,
RFC6T, GRF7H-C
PLATING
= Straight
–RA
= Right-angle
Bulkhead/Panel
Mount
(34.29) 1.350
(10.15)
.400
(13.90)
.547
(15.40)
.606
.380
DIA
(9.65)
.380
DIA
(10.80)
.425
(10.80)
.425
available on Board Connectors.
(9.65)
.380
DIA
(9.65)
.380
DIA
BNC
Board Connectors
BNC7T-TH, BNC7T-BH,
BNC7T-EM
BNC7T
(23.50)
.925
GENDER
–J
Cable Mates:
= Jack
RFC6T, GRF7H-C
TYPE
(12.70)
.500
–P
PLATING
= 10 µ"
(0.25
µm) Gold
contact,
100 µ"
(2.54 µm)
Nickel Shell
*Lock washers & knurled nuts supplied
with bulkhead/panel mount options
ORIENTATION
–GN
= PCB
Mount
(10.92)
.430
–ST
= Straight
–RA
= Right-angle
Bulkhead/Panel
Mount
(9.65)
.380
DIA
(25.48) 1.003
(9.65)
.380
DIA
–ST–EM1 & –ST–EM2
Notes:
for 12G-SDI PCB mount launch
characteristics.
–EM2D*
–ST–TH2D
(13.41)
.528
(32.75) 1.289
–BM2D*
= Low Profile
Die Cast Bulkhead
Mixed Technology
for(13.41)
(3.18 mm) .125" PCB
.528 (-RA only)
= Edge Mount Die Cast
Bulkhead/Panel Mount
for (2.40 mm) .093" PCB
(–ST only)
–ST–EM1D & –ST–EM2D
75 Ω MACHINED BNC TO 12 GHz
–B
–EM1D*
(13.41)
.528
(23.50)
.925
(9.65)
.380
DIA
= Bulk
packaged
(–BH2D only)
for (1.60 mm) .062" PCB
(–ST only)
(9.65)
.380
DIA
(9.65)
.380
DIA
(29.00) 1.142
(10.80)
.425
(9.65)
.380
DIA
(23.50)
.925
(25.48) 1.003
(29.00) 1.142
–BH2D*
–BM1D*
(9.65)
.380
DIA
(9.65)
.380
DIA
Leave blank
for individually
bagged.
= Low Profile
Die Cast Bulkhead
Mixed Technology
(-RA only)
–RA–BH2D
Notes:
(34.29) 1.350
(9.65)
characteristics.
(13.90)
.547
(25.48) 1.003
(29.00) 1.142
PACKAGING
–TH2D
= Low Profile
Die Cast Bulkhead
Through-hole
(25.48) 1.003 (–RA only)
(9.65)
.380
DIA
(34.29) 1.350
= Tall Through-hole
Die Cast
(–ST only)
–RA–BM1D
(BALANCED FOR PICK-AND-PLACE)
(15.40)
.606
TERMINATION
–ST
= 10 µ"
(0.25
µm) Gold
contact,
100 µ"
(2.54 µm)
Nickel Shell
(9.65)
.380
DIA
(10.15)
.400
(18.00)
.709
–ST–TH1
TERMINATION
PACKAGING
–TH1
Leave blank
for individually
bagged.
–BH1*
= Bulk
packaged
(–BH1 only)
= Standard
Through-hole
(–ST only)
= Standard Bulkhead
Through-hole
(–RA only)
–B
–EM1*
= Edge Mount
(–ST only)
–EM2*
= Edge Mount
(–ST only)
(21.00)
.827
–RA–BH1
samtec.com/BNC
F-224
BNC7T-J-P-GN-ST-EM1D 价格&库存
很抱歉,暂时无法提供与“BNC7T-J-P-GN-ST-EM1D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+34.13880
- 10+29.05200
- 30+25.95240
