LOW PROFILE
DUAL WIPE SOCKET 8
(1.27 mm) .050" PITCH • CLP SERIES
CLP
Mates:
FTSH, FTS, FW
CLP
-1
- 02 -
NO. PINS
PER ROW
02 thru 50
SPECIFICATIONS
G b p s
PLATING
OPTION
ROW
OPTION
–F
–D
= Gold flash
on contact,
Matte Tin
on tail
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (CLP/FTSH):
3.4 A per pin
(2 pins powered)
Voltage Rating:
280 VAC/395 VDC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
Top Entry =
(1.40 mm) .055" minimum
Bottom Entry =
(2.41 mm) .095" minimum
plus board thickness
DH Entry =
(2.31 mm) .091" to (2.67 mm) .105"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
–BE
= Double
Row
= Bottom Entry
(Required for bottom
entry applications)
–DH
–A
= Double
Horizontal
(Requires
FTSH–04
lead style)
–L
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
OTHER
OPTIONS
= Alignment Pin
(Not available with –PA option)
(05, 06, 07, 08, 10, 12, 15,
20, 25, 30, 40 positions only)
(–DH option and other sizes.
Contact Samtec.)
–K
–G
= (4.00 mm) .157" DIA
Polyimide film Pick & Place Pad
= 10 µ"
(0.25 µm)
Gold
(–D only)
–P
= Pick & Place Pad
(5 positions min. –D only)
(Not always necessary
for auto placement.
See Flex Processing.)
–PA
= Pick & Place Pad
with Alignment Pin
(–D only)
(Not available with –A option)
PROCESSING
–TR
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-35)
(0.15 mm) .006" max (36-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
= Tape & Reel
1RRI3RVLWLRQV[
–FR
= Full Reel Tape & Reel
(must order maximum
quantity per reel;
contact Samtec for
quantity breaks)
ALSO AVAILABLE
MOQ Required
Single row
Other platings
—DH
—D
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Notes:
Severe Environment
Testing qualified; aligns
with MIL-DTL-55302.
Visit samtec.com/set
PIN/ROW
A
04-15
(3.56) .140
16-50
(7.11) .280
If odd pins/row, alignment pins are on
middle position on centerline of the part.
If even pins/row, then alignment pins are
between middle two positions.
—PA OPTION
—P OPTION
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
samtec.com?CLP
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
CLP-136-02-F-D-P-TR 价格&库存
很抱歉,暂时无法提供与“CLP-136-02-F-D-P-TR”相匹配的价格&库存,您可以联系我们找货
