Recommended configuration of plated through holes
har-bus® HM
male connector
CompactPCI
In addition to the hot-air-level (HAL), other PCB surfaces are getting more
important. Due to their different properties - such as mechanical strength
and coefficient of friction - we recommend the following configuration of
PCB through holes.
Drilled hole Ø
Tin plated PCB
(HAL) acc. to EN
60352-5
General information
Design
Chemical tin plated
PCB
IEC 61076-4-101
0,7±0,02 mm
Cu
min. 25µm
Sn
max. 15µm
plated hole Ø
0,60 – 0,65mm
Drilled hole Ø
0,7±0,02 mm
Cu
min. 25µm
Sn
min. 0,8µm
No. of contacts
55 - 220 signal (77 - 308 fully shielded); or customised
plated hole Ø
0,60 – 0,65mm
Contact spacing
2,0mm
Drilled hole Ø
0,7±0,02 mm
Test voltage
750V AC
Cu
min. 25µm
Contact resistance
20 mOhm max.
Insulation resistance
Gold /Nickel plated
PCB
10
Ni
3-7µm
Au
0,05-0,12µm
Working current
10 Ohm min.
1 A@70°C (see derating diagram)
plated hole Ø
0,60 – 0,65mm
Temperature range
-55°C … +125°C
Drilled hole Ø
0,7±0,02 mm
Termination technology
compliant press-in
Clearance & creepage distance
0,8 mm each for fixed connector
Insertion and withdrawal force
Mating cycles
Silver plated PCB
Cu
min. 25µm
Ag
0,1 – 0,3µm
insertion force per contact:
0,75N max.
plated hole Ø
0,60 – 0,65mm
withdrawal force per contact:
0,15N min.
Drilled hole Ø
0,7±0,02 mm
- PL1 acc. to IEC 61076-4-101 =>
500 mating cycles
- PL2 acc. to IEC 61076-4-101 =>
250 mating cycles
UL file
E102079
RoHS - compliant
Yes
Leadfree
Yes
Copper plated PCB
(OSP)
Cu
min. 25µm
plated hole Ø
0,60 – 0,65mm
Circuit density
Insulator material
Material
PC (Polycarbonate, glass fiber reinforcement 20%)
Color
RAL 7032 (grey)
UL classification
UL 94-V0
Material group acc. IEC 60664-1
IIIa (175 < CTI < 400)
NFF classification
I2, F1
When using the specified diameter of the finished through hole according
to IEC 61 076-4-101 (0.6 ± 0.05 mm) with an appropriate annular ring, the
remaining distance between the rings is about 1 mm.
Under the condition that the width of the track and the space between
should be equal, two tracks of 0.2 mm width or three tracks of 0.14 mm
width can be placed between two rings.
Typical designs are shown in the drawing on the right side.
Contact material
Copper alloy
Treatment contact zone
Bellcore recommended lubricant (PPE)
Plating press-in zone
Ni
Plating contact zone
Au over PdNi over Ni
- "S4" acc. to HARTING internal PL =>
min. 0,06µm Au / 0,7µm PdNi / 1,3µm Ni
Derating diagram acc. to IEC 60512-5 (Current carrying capacity)
The current carrying capacity is limited by maximum temperature of
materials for inserts and contacts including terminals.
The current capacity curve is valid for continuous, non interrupted current
loaded contacts of connectors when simultaneous power on all contacts is
given, without exceeding the maximum temperature.
Control and test procedures according to DIN IEC 60512-5
Electrical load [A]
Released / Freigegeben 2012-05-31-09:53:39:571 UTC
Contact material
Curve 1 shows raise in temperature
Curve 2 shows nominal derating
Date
Curve 3 shows reduced values as per IEC512
Temperature [°C]
EC01567
Mod.
Subject to change without prior notice, all rights reserved
Name
Detail.
22/05/12 mte
Inspec.
22/05/12 TD
Stand.
Date
Name
HARTING Electronics GmbH & Co. KG
Technical data sheet
har-bus® HM male connector
DS 17 00 110 0101
Page 1 of 1
很抱歉,暂时无法提供与“17011542201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+87.199491+11.31691
- 10+74.1339310+9.62123
- 30+68.6026130+8.90337
- 50+66.1726650+8.58801
- 100+63.01454100+8.17814
- 250+59.07122250+7.66637
- 500+56.25371500+7.30071
- 1000+53.571851000+6.95265
- 国内价格
- 10+59.50670
- 20+56.71583
- 30+55.03891
- 50+53.08650
- 100+50.47529
- 200+48.33123
- 国内价格
- 1+64.84320
- 10+56.95920
- 30+52.16400
