2002-3208
2002-3208
    WAGO(万可电子)
    端子块连接器 6 位置 馈通式 灰色 12-18 AWG
2002-3208 数据手册
Printview: Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications - Item No.: 2002-3208 . Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications Item No.: 2002-3208 . Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications . Marking . Business data Supplier WAGO Item no. 2002-3208 GTIN / EAN 4044918691246 Content 1 Order amount 50 Customer item number . Notes Technical data Miscellaneous Total number of connection points 6 Total number of potentials 1 Potentialkennzeichnung L Number of levels 3 Color gray Ratings according to 1 IEC/EN 60947-7-1 Pollution degree (1) 3 Rated voltage EN (1) [V] 500 [V] WAGO Kontakttechnik GmbH & Co. KG 1 Printview: Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications - Item No.: 2002-3208 Technical data Rated surge voltage (1) [kV] 6 [kV] Nominal current [A] 24 [A] Nominal current (2) [A] 28 [A] Rated voltage EN (Ex e II) [V] 440 [V] Nominal current (Ex e II) [A] 19 [A] Nominal current (Ex e II) with jumper [A] 17 [A] Connection technology (1) Push-in CAGE CLAMP® Nominal cross section 1 2.5 mm² Solid sizes 1 0.25 … 4 mm² / 22 … 12 AWG solid, directly pluggable 1 0.75 … 4 mm² / 18 … 12 AWG Fine-stranded wires 1 0.25 … 4 mm² / 22 … 12 AWG min. fine-stranded with insulated ferrule, push-in terminati 0.75 mm² / 18 AWG Strip length 1 10 … 12 mm / 0.39 … 0.47 in Type of wiring Front-entry wiring Design horizontal Marking level Center/Side marking Insulating material Polyamide 66 (PA 66) Fire load [MJ] 0.321 [MJ] Weight [g] 17.745 [g] Width 5.2 mm / 0.205 in Height from upper-edge of DIN-rail [mm] 69.5 [mm] Height from upper-edge of DIN-rail 69.5 mm / 2.736 in Length 93.3 mm / 3.673 in Type of mounting DIN 35 rail WAGO Kontakttechnik GmbH & Co. KG 2 Printview: Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications - Item No.: 2002-3208 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 3 Printview: Triple-deck terminal block; 6-conductor through terminal block; L; without marker carrier; gray housing; internal commoning; conductor entry with violet marking; suitable for Ex e II applications - Item No.: 2002-3208 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 4
2002-3208 价格&库存
很抱歉,暂时无法提供与“2002-3208”相匹配的价格&库存,您可以联系我们找货
  • 1+170.737321+22.20056
  • 10+121.8516310+15.84407
  • 25+108.6320225+14.12516
  • 50+100.7478250+13.09999
  • 100+94.42638100+12.27803
  • 250+88.04709250+11.44855
  • 500+84.42038500+10.97698
  • 1000+81.602281000+10.61055
库存:764
2002-3208
    • 5+34.51771
    库存:1515
    2002-3208
      库存:25
      2002-3208
      • 1+174.85451
      • 10+40.91052
      • 100+40.10370
      • 250+39.28502
      • 500+38.46633
      • 1000+37.64765
