21032121305
21032121305
    HARTING(浩亭)
    CIRCULAR CONN W/HARAX M12 L4 M
21032121305 数据手册
Product data sheet 21 03 212 1305 circular Connector w. Harax M12 L4 M circular Connector w. Harax M12 L4 M Part number 21 03 212 1305 Specification circular Connector w. Harax M12 L4 M HARTING eCatalogue https://b2b.harting.com/21032121305 Identification Category Connector Series Circular connectors M12 Identification M12-L Element Cable connector Specification Straight Version Termination method HARAX® connection technology Gender Male Locking type Screw locking Shielding Unshielded Number of contacts 4 Coding A-coding Technical characteristics Conductor cross-section 0.34 ... 0.75 mm² Conductor cross-section AWG 22 ... AWG 18 Wire outer diameter ≤2.6 mm Rated current 6 A Rated voltage 50 V Rated impulse voltage 1.5 kV Pollution degree 3 Insulation resistance > 108 Ω Contact resistance ≤10 mΩ Page 1 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 212 1305 circular Connector w. Harax M12 L4 M Technical characteristics Ambient temperature -40 ... +85 °C Tightening torque 0.6 Nm Wrench size A/F 17 Knurled screw / knurled nut Mating cycles ≥100 Degree of protection acc. to IEC 60529 IP65 when mated IP67 when mated Cable diameter 6 ... 8 mm Overvoltage category III Isolation group I (600 ≤ CTI) Material properties Material (insert) Polyamide Material (contacts) Brass Surface (contacts) Gold plated Material (hood/housing) Polyamide Zinc die-cast RoHS compliant with exemption RoHS exemptions 6c: Copper alloy containing up to 4 % lead by weight ELV status compliant with exemption China RoHS 50 REACH Annex XVII substances No REACH ANNEX XIV substances No REACH SVHC substances Yes REACH SVHC substances Lead Specifications and approvals Specifications IEC 61076-2-101 UL / CSA UL 1977 ECBT2.E102079 CSA-C22.2 No. 182.3 ECBT8.E102079 Commercial data Packaging size 1 Net weight 36.3 g Country of origin Germany European customs tariff number 85366990 Page 2 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 21 03 212 1305 circular Connector w. Harax M12 L4 M Commercial data eCl@ss 27440102 Circular connector (for field assembly) Page 3 / 3 | Creation date 2019-04-17 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com
21032121305 价格&库存
很抱歉,暂时无法提供与“21032121305”相匹配的价格&库存,您可以联系我们找货
  • 1+145.50214
  • 10+141.13874
  • 50+136.75451
  • 100+133.83864
  • 250+130.93318
库存:37
21032121305
    • 1+237.758631+29.81539
    • 3+199.433393+25.00933
    • 4+194.639524+24.40817
    • 5+191.771765+24.04855
    • 9+186.661169+23.40767
    • 10+186.0191210+23.32716
    • 20+183.1513620+22.96754
    库存:5
