Data sheet | Item number: 282-907
2-conductor ground terminal block; 6 mm²; center marking; for DIN-rail 35 x
15 and 35 x 7.5; CAGE CLAMP®; 6,00 mm²; green-yellow
www.wago.com/282-907
Color:
Data
Electrical data
Ratings
per IEC/EN 60664-1
Subject to changes. Please also observe the further product documentation!
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
01.06.2020 Page 1/12
Ratings per IEC/EN 60664-1
Ratings per
IEC/EN 60947-7-2
Connection data
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0,2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor
Strip length
12 … 13 mm / 0.47 … 0.51 inch
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Wiring type
Front-entry wiring
Geometrical Data
Width
8 mm / 0.315 inch
Height from upper-edge of DIN-rail
32,5 mm / 1.28 inch
Depth
74,5 mm / 2.933 inch
Mechanical data
Design
horizontal type
Mounting type
DIN-35 rail
Marking level
Center marking
Material Data
Color
green-yellow
Insulation material
Polyamide 66 (PA 66)
Fire load
0.247 MJ
Weight
22 g
Commercial data
Product Group
1 (Rail Mounted Terminal Blocks)
Packaging type
BOX
Country of origin
DE
GTIN
4044918471794
Hansastr. 27
32423 Minden
01.06.2020 Page 2/12
GTIN
4044918471794
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Approval
Additional Approval Text
Certificate
name
CCA
DEKRA Certification B.V.
EN 60947
2195540.01
CCA
EN 60947
NTR NL7522
CSA
C22.2 No. 158
1505033
Approval
ABS
American Bureau of Shipping
EN 60947
20HG1941090PDA
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
UL
UL 1059
Hansastr. 27
32423 Minden
Certificate
name
20190731-
01.06.2020 Page 3/12
UL
UL International Germany GmbH
UL 1059
20190731E45172
Counterpart
Compatible products
General accessories
Item no.: 209-143
Group marker carrier; gray
www.wago.com/209-143
Item no.: 209-144
www.wago.com/209-144
Item no.: 709-310
B-type test plug module; modular; suitable for all WAGO 282 Series rail-mounted terminal blocks with www.wago.com/709-310
jumper slots; 6,00 mm²; gray
Item no.: 709-311
B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/709-311
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 709-153
Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent
www.wago.com/709-153
Item no.: 209-170
Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray
www.wago.com/209-170
Item no.: 216-262
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-262
assembling
check
ferrule
Item no.: 216-263
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight
Hansastr. 27
32423 Minden
www.wago.com/216-263
01.06.2020 Page 4/12
crimped; acc. to DIN 46228, Part 4/09.90; red
Item no.: 216-264
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-264
Item no.: 216-266
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; blue
www.wago.com/216-266
Item no.: 216-267
Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight
www.wago.com/216-267
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25
mm
www.wago.com/210-112
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18
mm
www.wago.com/210-115
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Carrier rail
Jumper
Item no.: 210-103
Hansastr. 27
32423 Minden
www.wago.com/210-103
01.06.2020 Page 5/12
Item no.: 210-103
Wire commoning chain; insulated; 50 connections; black
Item no.: 210-123
www.wago.com/210-123
Item no.: 282-402
Adjacent jumper; insulated; Nominal current 41 A
www.wago.com/282-402
Item no.: 282-409
Alternate jumper; insulated; Nominal current 41 A; gray
www.wago.com/282-409
Item no.: 282-422
Adjacent jumper; insulated; Nominal current 41 A; yellow-green
www.wago.com/282-422
Item no.: 282-424
Adjacent jumper; insulated; Nominal current 41 A; orange
www.wago.com/282-424
Item no.: 709-110
Wire commoning chain; insulated; 4 connections; 3 x 110 mm; black
www.wago.com/709-110
Item no.: 709-111
Wire commoning chain; insulated; 3 connections; 2 x 120 mm; black
www.wago.com/709-111
Item no.: 709-112
Wire commoning chain; insulated; 3 connections; 2 x 170 mm; black
www.wago.com/709-112
Item no.: 282-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/282-415
Item no.: 210-721
Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft
www.wago.com/210-721
protection
tools
Marking accessories
Item no.: 2009-115
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; yellow /000-002
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; orange /000-012
Hansastr. 27
32423 Minden
01.06.2020 Page 6/12
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; light
green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; green /000-023
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; 1500 pieces on roll; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 209-185
Adaptor; gray
www.wago.com/209-185
Item no.: 210-612
Marking strips; for self-marking; plain; Self-adhesive; transparent
www.wago.com/210-612
Item no.: 249-105
www.wago.com/249-105
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
Hansastr. 27
32423 Minden
01.06.2020 Page 7/12
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501
on type; white
Item no.: 793-5501/000-002
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002
on type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-005
on type; red
Item no.: 793-5501/000-006
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-006
on type; blue
Item no.: 793-5501/000-007
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-007
on type; gray
Item no.: 793-5501/000-012
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-012
on type; orange
Item no.: 793-5501/000-014
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-014
on type; brown
Item no.: 793-5501/000-017
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-017
on type; green
Item no.: 793-5501/000-023
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-024
on type; violet
End plate
Item no.: 282-326
Separator plate; 2 mm thick; oversized; gray
www.wago.com/282-326
Item no.: 282-329
Separator plate; 2 mm thick; oversized; orange
www.wago.com/282-329
Hansastr. 27
32423 Minden
01.06.2020 Page 8/12
Downloads
Documentation
Bid Text
282-907
Feb 19, 2019
xml
3.1 kB
Download
Feb 28, 2017
doc
24.6 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
EPLAN Data Portal 282-907
URL
Download
WSCAD Universe 282-907
URL
Download
GAEB X81 - Datei
282-907
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 282-907
CAE data
Handling Instructions
Assembly
Hansastr. 27
32423 Minden
01.06.2020 Page 9/12
By snapping a ground conductor terminal
block onto the carrier rail, a direct electrical
connection is automatically made to the rail.
Quick assembly keys prevent reverse
mounting.
Removing a terminal block from the
assembly.
CAGE CLAMP® connection
Removing a conductor.
Inserting a conductor.
With ferruled conductors, it is necessary to
use a terminal block one size larger than the
conductor’s nominal cross-section.
Jumpered
Hansastr. 27
32423 Minden
01.06.2020 Page 10/12
Commoning ground conductor terminal
blocks with through terminal blocks is
possible in one direction only (via rear side
of terminal block) using adjacent jumpers. In
addition to the required marking of these
blocks, use yellow-green adjacent jumpers.
Testing
Testing with a test plug
(picture shows 209‑170 Test Plug Adapter).
Marking
Hansastr. 27
32423 Minden
01.06.2020 Page 11/12
Marking via WMB Multi Marking System.
Hansastr. 27
32423 Minden
01.06.2020 Page 12/12
很抱歉,暂时无法提供与“282-907”相匹配的价格&库存,您可以联系我们找货
