434163025816
434163025816
    OTHER
434163025816 数据手册
Recommended Land Pattern: [mm] 6,0 4,0 3 2 4 2,7 1,7 1 0,7 4 2 4x 0,6 Dimensions: [mm] 3 1 O 2,0 ,0 ±0 5 Schematic: 1,65 +0,15 -0,1 0 ,2 2,5 Scale - 6:1 1 3 2 4 5,5 ±0,2 3,5 4,7 Scale - 7:1 Dimensions: Properties Height H Value Unit 2.5 mm CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE ELin 001.001 2021-01-25 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WS-TASV J-Bend SMT Tact Switch Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com ORDER CODE 434163025816 SIZE/TYPE BUSINESS UNIT STATUS PAGE 4.7 x 3.5 mm eiCan Valid 1/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Material Properties: General Information: Cover Material Stainless Steel Actuator Material Operating Temperature LCP Actuator Flammability Rating -40 up to +85 °C Storage Conditions (in original packaging) UL94 V-0 < 40 °C ; < 75 % RH Actuator Color Black Moisture Sensitivity Level (MSL) 1 Frame Material LCP Washable No Frame Flammability Rating UL94 V-0 Frame Color Certification: White Contact Material Stainless Steel RoHS Approval Compliant [2011/65/EU&2015/863] Contact Plating Silver REACh Approval Conform or declared [(EC)1907/2006] Terminal Material Terminal Plating Tape Material Copper Alloy Halogen Free Conform [IEC 61249-2-21] Silver Halogen Free Conform [JEDEC JS709B] Polyimide Electrical Properties: Properties Test conditions Value Unit 20 mA VR 15 V (DC) R 100 mΩ max. R 2 Ω max. min. Rated Current IR Rated Voltage Contact Resistance Initial Contact Resistance After Life Test Insulation Resistance RISO 500 V (DC) 100 MΩ Withstanding Voltage 1 min 250 V (AC) 10 ms Bounce Tol. max. Mechanical Properties: Properties Test conditions Value 20 mA/ 15 V (DC) 0.25 mm Operation Force Electrical Life 1) Stroke 1) Unit Tol. 160 g ±50 300000 Cycles +0.05/-0.15 Cycle - Return to the original position CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE ELin 001.001 2021-01-25 DIN ISO 2768-1m PROJECTION METHOD DESCRIPTION WS-TASV J-Bend SMT Tact Switch Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com ORDER CODE 434163025816 SIZE/TYPE BUSINESS UNIT STATUS PAGE 4.7 x 3.5 mm eiCan Valid 2/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Packaging Specification - Tape and Reel: [mm] P0 D0 T W1 close to center E1 A W3 K0 P2 W A N C D B0 E2 F B Top Cover Tape A0 A P1 T1 W2 T2 Feeding direction End Start detail B Carrier Tape Cover Tape B Cover Tape Chip Cavity Sprocket Hole No Component min. 160mm Components No Component min. 100mm Embossment Cover Tape min. 400mm Tape Type 2a A0 (mm) typ. 6,70 B0 (mm) typ. 3,60 W (mm) ±0,3 12,00 T (mm) ref. 0,35 T1 (mm) ref. 0,10 T2 (mm) typ. 3,66 K0 (mm) typ. 3,30 P0 (mm) ±0,1 4,00 P1 (mm) ±0,1 8,00 P2 (mm) ±0,1 2,00 D0 (mm) +0,1/ -0,0 1,50 E1 (mm) ±0,1 1,75 E2 (mm) min. 10,25 F (mm) ±0,1 5,50 Material Qty. (pcs.) Polystyrene 2500 A (mm) ± 2,0 330,00 B (mm) min. 1,50 C (mm) min. 12,80 D (mm) min. 20,20 N (mm) min. 60,00 W1 (mm) + 2,0 12,40 W2 (mm) max. 18,40 CHECKED REVISION DATE (YYYY-MM-DD) GENERAL TOLERANCE ELin 001.001 2021-01-25 DIN ISO 2768-1m W3 (mm) min. 11,90 W3 (mm) max. 15,40 Material Polystyrene PROJECTION METHOD DESCRIPTION WS-TASV J-Bend SMT Tact Switch Würth Elektronik eiSos GmbH & Co. KG EMC & Inductive Solutions Max-Eyth-Str. 1 74638 Waldenburg Germany Tel. +49 (0) 79 42 945 - 0 www.we-online.com eiSos@we-online.com ORDER CODE 434163025816 SIZE/TYPE BUSINESS UNIT STATUS PAGE 4.7 x 3.5 mm eiCan Valid 3/7 This electronic component has been designed and developed for usage in general electronic equipment only. This product is not authorized for use in equipment where a higher safety standard and reliability standard is especially required or where a failure of the product is reasonably expected to cause severe personal injury or death, unless the parties have executed an agreement specifically governing such use. Moreover Würth Elektronik eiSos GmbH & Co KG products are neither designed nor intended for use in areas such as military, aerospace, aviation, nuclear control, submarine, transportation (automotive control, train control, ship control), transportation signal, disaster prevention, medical, public information network etc.. Würth Elektronik eiSos GmbH & Co KG must be informed about the intent of such usage before the design-in stage. In addition, sufficient reliability evaluation checks for safety must be performed on every electronic component which is used in electrical circuits that require high safety and reliability functions or performance. Classification Reflow Profile for SMT components: Classification Reflow Soldering Profile: Profile Feature Tp tp Max. Ramp Up Rate Max. Ramp Down Rate TL Temperature Ts max Ts min Ts min 150 °C Preheat Temperature Max Ts max 200 °C Preheat Time ts from Ts min to Ts max ts Ramp-up Rate (TL to TP) Liquidous Temperature tL Preheat Area TC –5°C Value Preheat Temperature Min 60 - 120 seconds 3 °C/ second max. TL 217 °C Time tL maintained above TL tL 60 - 150 seconds Peak package body temperature Tp Tp ≤ Tc, see Table below Time within 5°C of actual peak temperature tp 20 - 30 seconds Ramp-down Rate (TP to TL) 6 °C/ second max. Time 25°C to peak temperature 8 minutes max. refer to IPC/ JEDEC J-STD-020E tS Package Classification Reflow Temperature (Tc): Volume mm³ 350-2000 Volume mm³ >2000 PB-Free Assembly | Package Thickness 260 °C < 1.6 mm 260 °C 260 °C PB-Free Assembly | Package Thickness 260 °C 1.6 mm - 2.5 mm 250 °C 245 °C PB-Free Assembly | Package Thickness 250 °C > 2.5 mm 245 °C 245 °C Properties 25 Time 25°C to Peak Time Applied cycles Volume mm³
434163025816 价格&库存
很抱歉,暂时无法提供与“434163025816”相匹配的价格&库存,您可以联系我们找货
