Printview: Terminal strip with jumper slot; 2 solder pins/pole; 4-pole; pin spacing 7.5 mm / 0.295 in; without
fixing flange - Item No.: 745-304
spacing 7.5 mm / 0.295 in; without fixing flange
Item No.: 745-304
Terminal strip with jumper slot; 2 solder pins/pole; 4-pole; pin spacing 7.5 mm / 0.295 in; without fixing flange
Marking
Business data
Supplier
WAGO
Item no.
745-304
GTIN / EAN
4044918302135
Content
1
Order amount
64
Customer item number
Notes
Terminal strips with screwdriver-actuated CAGE CLAMP®Also available with Ex e approvalComb-style jumper bars
for commoning and distributing potentialsCustom color combinationsDouble solder pins for high mechanical
stabilitySaves spaces thanks to positioning of terminal strips behind one anotherIntegrated testing tapMarker slot for
miniature WSB and WMB markers
Technical data
Miscellaneous
No. of poles
4
Pin Spacing
7.5 mm / 0.295 in %
Total number of connection points
4
Total number of potentials
4
Color
gray
Ratings according to 1
IEC/EN 60664-1
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Overvoltage category EN 1
III
Pollution degree (1)
2
Rated voltage EN (1) [V]
630 [V]
Rated surge voltage (1) [kV]
6 [kV]
Nominal current [A]
41 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
1000 [V]
Rated surge voltage (2) [kV]
6 [kV]
Nominal current (2) [A]
41 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
500 [V]
Rated surge voltage (3) [kV]
6 [kV]
Nominal current (3) [A]
41 [A]
Number of individual connection objects at the product
1
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 … 4 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 4 mm² / …
Strip length 1
11 … 12 mm / 0.43 … 0.47 in
Conductor entry angle to the PCB 1 [°]
45 [°]
Solder pin arrangement
in-line solder pin
Solder pin length [mm]
4.5 [mm]
Solder pin width A [mm]
1 [mm]
Solder pin width B [mm]
1.4 [mm]
Tolerance of drilled hole [mm]
1.8(+ 0.1) [mm]
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 105 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Electrolytic copper (Ecu)
2
Technical data
Contact plating
tin-plated
Fire load [MJ]
0.313 [MJ]
Weight [g]
19.731 [g]
Width
31.6 mm / 1.244 in
Height
27.5 mm / 1.083 in
Height from the surface
23 mm / 0.906 in
Length
29.1 mm / 1.146 in
3
Images & drawings
4
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
5
很抱歉,暂时无法提供与“745-304”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+73.996831+9.57262
