8000-099/000-1764
8000-099/000-1764
    WAGO(万可电子)
    8000-099/000-1764
8000-099/000-1764 数据手册
TECHNICAL DATA SHEET Cat 6A Panel Connector PN 8000-099/000-1764 DIMENSIONS (mm) Part Number: 8000-099/000-1764 Description General RJ45 panel connector for front installation 22.5 mm Female/female 1:1 Form male 1 RJ45 Insulation resistance > 100 MΩ Degree of polution Contact resistance Flammability according to UL 94 Protection class Housing material Cover Contact material Mounting Installation depth Operating temperature range Storage temperature range Temperature range connector Mechanical service life Weight MOUNTING 3 Rated volatge UN 24 VAC Rated current 1.5 A Rated voltage max. < 30 mΩ V0 Technical Data Pole number cULus NEMA Type 2, 3R, 4, 4X, 12, 13: IEC IP65 with cap closed, IP20 when connected Transfer rate 50 V 8 10 Gbit/s Category Cat 6 A PA, PBT, Contact type 1:1 CuSn, gold-plated Approvals cULus TPU Front installation Shielding 70 mm -20 °C ... +70 °C -20 °C ... +80 °C -20 °C ... +70 °C > 750 insertion cycles 0.84 oz / piece CIRCUIT DIAGRAM Connected through
8000-099/000-1764 价格&库存
很抱歉,暂时无法提供与“8000-099/000-1764”相匹配的价格&库存,您可以联系我们找货
8000-099/000-1764
