B26B-PUDSS-1
B26B-PUDSS-1
    JST
    CONN-26P_28X8.3MM_TM
B26B-PUDSS-1 数据手册
PUD CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors • High reliability contact • Superior operability • Secure locking structure • Polarizing key for mounting on PC board Specifications ––––––––––––––––––– This is a board-to-wire connector with secure locking device that has been designed to 2.0mm pitch, crimping style and double-row. In spite of realizing low insertion force, the stable electric connection is demonstrated against the condition such as vibration, pinching and dry circuit. It is possible to unfasten the locking even if the header is surrounded with a case wall within height of header because the tip of locking device in receptacle does not protrude from its area. • Current rating: 3A AC, DC (AWG#22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/10m Ω max. After environmental testing/20m Ω max. • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 800V AC/minute • Applicable wire: 001 type/AWG #26 to #22 002 type/AWG #28 to #24 * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E 60389 PC board layout (viewed from component side) and Assembly layout Connector outline (0.4) 8.3 φ1.6 +0.1 0 φ0.7 8.5 2 ±0.05 Even number circuits Circuit No.1 2 Connector outline φ0.7 +0.1 0 2 Note: 1.Tolerances are non-cumulative: ±0.05mm for all centers. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. SMT type A±0.1 2±0.05 1min 8.8 (1.6) 1min (12.3) (0.8) 3min 5.7±0.1 3min Even number circuits Odd number circuits Connector outline Circuit No.1 A ±0.05 2 ±0.05 7.7 ±0.05 0.9 ±0.05 Odd number circuits +0.1 0 φ1.3+0.1 0 Note: 1.Tolerances are non-cumulative: ±0.05mm for all centers. 2.The dimensions above should serve as a guideline. Contact JST for details. 1 (14.1) 2±0.05 Even number circuits 11 3.4±0.05 (2) 1.2±0.05 2±0.05 (2.4) A±0.05 Odd number circuits Circuit No.1 (2) (0.4) Side entry type (2.4) Top entry type 10.1 PUD CONNECTOR Contact Applicable wire AWG# mm2 Model No. 7.5 SPUD-001T-P0.5 SPUD-002T-P0.5 2.85 Insulation O.D. (mm) Q’ty / reel 0.13∼0.33 26∼22 0.95∼1.5 8,000 0.08∼0.22 28∼24 0.8 ∼1.5 8,000 1.35 Material and Finish 1.45 Copper alloy, tin-plated (reflow treatment) RoHS compliance 1.65 Applicator Dies Crimping machine Crimp applicator Contact MKS-L SPUD-001T-P0.5 AP-K2N ー ー ー MK/SPUD-002-05 APLMK SPUD002-05 MKS-L SPUD-002T-P0.5 AP-K2N Crimp applicator with dies MK/SPUD-001-05 APLMK SPUD001-05 ー ー ー Housing 〈8, 10 circuits〉 〈12, 14 circuits〉 B A Circuit No.1 mark Circuit No.1 mark 9.1 2 9.1 2 8.3 B A 8.3 〈16, 18 circuits〉 〈20, 22 circuits〉 B A B A 8.3 Circuit No.1 mark 9.1 2 9.1 2 8.3 Circuit No.1 mark 〈24 to 28 circuits〉 B A 8.3 Circuit No.1 mark 9.1 2 〈30 to 40 circuits〉 8.3 2 Circuit No.1 mark Model No. 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 PUDP-08V-S PUDP-10V-S PUDP-12V-S PUDP-14V-S PUDP-16V-S PUDP-18V-S PUDP-20V-S PUDP-22V-S PUDP-24V-S PUDP-26V-S PUDP-28V-S PUDP-30V-S PUDP-32V-S PUDP-34V-S PUDP-36V-S PUDP-38V-S PUDP-40V-S Dimensions (mm) A B 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 36.0 38.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 36.0 38.0 40.0 42.0 Q’ty / bag 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 1,000 500 500 500 500 500 500 500 Material PBT, UL94V-0, natural 9.1 B A Circuits RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PUDP-08V-S S...natural Z...ivory E...blue K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange 2 PUD CONNECTOR Through-hole type shrouded header Top entry type Circuits 8.3 3.1 0.8 9.6 A 2 Circuit No.1 3.4 2 〈12 to 18 circuits〉 8.3 3.1 0.8 9.6 B A Circuit No.1 2 3.4 2 Dimensions (mm) A B 6.0 10.0 3,300 10 B10B-PUDSS B10B-PUDSS-1 S10B-PUDSS-1 8.0 12.0 2,750 12 B12B-PUDSS B12B-PUDSS-1 S12B-PUDSS-1 10.0 14.0 2,310 14 B14B-PUDSS B14B-PUDSS-1 S14B-PUDSS-1 12.0 16.0 1,980 16 B16B-PUDSS B16B-PUDSS-1 S16B-PUDSS-1 14.0 18.0 1,760 18 B18B-PUDSS B18B-PUDSS-1 S18B-PUDSS-1 16.0 20.0 1,650 20 B20B-PUDSS B20B-PUDSS-1 S20B-PUDSS-1 18.0 22.0 1,430 22 B22B-PUDSS B22B-PUDSS-1 S22B-PUDSS-1 20.0 24.0 1,320 24 B24B-PUDSS B24B-PUDSS-1 S24B-PUDSS-1 22.0 26.0 1,210 26 B26B-PUDSS B26B-PUDSS-1 S26B-PUDSS-1 24.0 28.0 1,100 28 B28B-PUDSS B28B-PUDSS-1 S28B-PUDSS-1 26.0 30.0 1,100 30 B30B-PUDSS B30B-PUDSS-1 S30B-PUDSS-1 28.0 32.0 990 32 B32B-PUDSS B32B-PUDSS-1 S32B-PUDSS-1 30.0 34.0 880 34 B34B-PUDSS B34B-PUDSS-1 S34B-PUDSS-1 32.0 36.0 880 36 B36B-PUDSS B36B-PUDSS-1 S36B-PUDSS-1 34.0 38.0 770 38 B38B-PUDSS B38B-PUDSS-1 S38B-PUDSS-1 36.0 40.0 770 40 B40B-PUDSS B40B-PUDSS-1 S40B-PUDSS-1 38.0 42.0 770 Material and Finish B 8.3 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural A 3.1 0.8 9.6 RoHS compliance This product displays (LF)(SN) on a label. Note: Color indication was changed. Berofe change; S...natural (ivory) → After change; S...natural Circuit No.1 2 3.4 2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. Side entry type 〈8, 10 circuits〉 B A 0.8 2 12.7 7.7 10.1 8.5 3 Circuit No.1 2 〈12 to 18 circuits〉 B 8.5 0.8 2 12.7 7.7 10.1 A Circuit No.1 2 3 〈20 to 40 circuits〉 0.8 2 12.7 7.7 10.1 8.5 B A 2 Circuit No.1 3 Q’ty / box Without boss With boss With boss B08B-PUDSS B08B-PUDSS-1 S08B-PUDSS-1 〈20 to 40 circuits〉 3 Side entry type 8 〈8, 10 circuits〉 B Model No. Top entry type B08B-PUDSS-1 S...natural Z...ivory E...blue K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange PUD CONNECTOR SMT type shrouded header Dimensions (mm) A B Circuits Model No. 10 BM10B-PUDSS-TFC BM12B-PUDSS-TFC BM14B-PUDSS-TFC BM16B-PUDSS-TFC BM18B-PUDSS-TFC BM20B-PUDSS-TFC BM24B-PUDSS-TFC BM26B-PUDSS-TFC BM28B-PUDSS-TFC BM30B-PUDSS-TFC 〈10 circuits〉 B A 12 8.8 14 2 16 18 10.8 20 24 26 28 30 Circuit No.1 Q’ty / reel 8.0 14.0 400 10.0 16.0 400 12.0 18.0 400 14.0 20.0 400 16.0 22.0 400 18.0 24.0 400 22.0 28.0 400 24.0 30.0 400 26.0 32.0 400 28.0 34.0 400 Material and Finish 〈12, 14, 16, 18 circuits〉 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: polyamide, UL94V-0, natural B RoHS compliance This product displays (LF)(SN) on a label. A 8.8 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 10.8 ex. BM-10B-PUDSS-TFC S...natural Z...ivory K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange Circuit No.1 〈20, 24 circuits〉 B A 8.8 10.8 2 Circuit No.1 〈26, 28 circuits〉 B A 8.8 10.8 2 Circuit No.1 4
B26B-PUDSS-1 价格&库存
很抱歉,暂时无法提供与“B26B-PUDSS-1”相匹配的价格&库存,您可以联系我们找货
