F-218 (Rev 14DEC17)
CLP–115–02–L–D
CLP–107–02–F–D–P
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
CLP–130–02–L–D
CLP–116–02–F–DH
HIGH MATING
CYCLES
(1.27 mm) .050"
CLP SERIES
LOW-PROFILE DUAL WIPE SOCKET
High-reliability
Tiger Claw™
contacts
Mates with:
FTSH, FTS, FW
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?CLP
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating (CLP/FTSH):
3.4 A per pin
(2 pins powered)
Voltage Rating:
280 VAC/395 VDC
Operating Temp Range:
-55 °C to +125 °C
Insertion Depth:
Top Entry = (1.40 mm) .055"
minimum, Bottom Entry =
(2.41 mm) .095" minimum
plus board thickness
DH Entry = (2.31 mm) .091"
to (2.67 mm) .105"
Normal Force:
60 grams (0.59 N) average
Max Cycles:
100 with 10 µ" (0.25 µm) Au
RoHS Compliant:
Yes
(1.27 mm x 1.27 mm)
.050" x .050"
micro pitch
APPLICATIONS
CLP
Low-profile
(2.21 mm)
.087"
FTSH
HORIZONTAL
Surface
mount
Suitable for pass-through
applications
PASS-THRU
CLP
NO. PINS
PER ROW
1
PLATING
OPTION
02
ROW
OPTION
OTHER
OPTION
PROCESSING
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-35)
(0.15 mm) .006" max (36-50)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
–F
= Gold flash on
contact, Matte
Tin on tail
02 thru 50
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
For complete scope of
recognitions see
www.samtec.com/quality
–G
No. of Positions
x (1.27) .050 + (0.43) .017
FILE NO. E111594
100
(1.27)
.050
02
01
99
(MOQ Required)
= Double
Horizontal
(Requires
FTSH–01
and
FTSH–04
lead styles)
–A
= Alignment Pin
(Not available with –PA option)
(05, 06, 07, 08, 10, 12, 15,
20, 25, 30, 40 positions only)
(–DH option and other sizes.
Contact Samtec.)
–K
= (4.00 mm) .157" DIA
Polyimide film Pick & Place Pad
(5 positions min.)
(6.35)
.250
x
(3.18)
.125
(4.32)
.170
(4.57) (3.05)
.180 .120
ALSO AVAILABLE
= 10 µ" (0.25 µm)
Gold
(–D only)
(0.41)
.016
= Bottom Entry
(Required for bottom entry
applications)
–DH
–L
RECOGNITIONS
–BE
–D
= Double
Row
(1.27)
.050
–P
= Pick & Place Pad
(5 positions min. –D only)
(Not always necessary
for auto placement.
See Flex Processing.)
(2.54)
.100
–P OPTION
• Single row
• Other platings
Contact Samtec.
(3.43)
.135
(2.29)
.090
–D
–DH
A
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
PIN/ROW
A
04-15
(3.56) .140
16-50
(7.11) .280
If odd pins/row, alignment
pins are on middle position
on centerline of the part.
If even pins/row, then
alignment pins are between
middle two positions.
(1.40)
.055
–PA
(8.25)
.325
(3.07)
.121
(0.89)
.035 DIA
(7.00)
.275
–PA OPTION
= Pick & Place Pad
with Alignment Pin
(–D only)
(Not Available with –A option)
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
–TR
= Tape & Reel
很抱歉,暂时无法提供与“CLP-137-02-F-DH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+110.893571+14.37392
