DF51K-4S-2C(800)
DF51K-4S-2C(800)
    HRS(广濑)
    P=2mm
    1X4P 2MM
DF51K-4S-2C(800) 数据手册
DF51K Series Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2mm Pitch, Center Lock, Wire-to-Board Connector​ (UL/C-UL Listed)​ ​ Product Page​ https://www.hirose.com/en/product/series/DF51K​ Mar.2024 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Features 1. Wide-Ranging ‌ Options to Meet Diverse Customer Needs​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. - THT/SMT, Straight/Right Angle, Single/Double row,​ Gold/Tin Plating, etc.​ 2. Center ‌ Lock Design for HighDensity Mounting and Easy Operation​ Center lock lever with various widths enables​ user-friendly operation.​ Extra spacing not required​ High density mounting contributes to​ space saving.​ 3. S  ecure Mating with Clear Tactile​ Click​ A clear tactile click prevents incomplete insertion​ Prevents incomplete insertion, featuring a design​ where the lock and contact insertion force peaks align​to produce a noticeable click.​ Insertion force 4. High ‌ contact reliability with long effective mating length and 2-point contact design ​ Lock ​ Insertion force curve​ Stroke Matches the peak​ Insertion force Contact​ Insertion force curve​ Stroke 2 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) 5. P  revents Incorrect Mating Visual and mechanical polarized design prevents reverse and incorrect mating between different numbers of positions. Secure Center​ Lock Design​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. S  uitable for Potting​ Guide Key​ Designed to support potting up to 3mm​ (applicable only to the straight THT header). Prevents Incorrect Mating​ Resin Sealing 3mm Max.​ Guide key enables user to recognize incorrect mating.​ 7. C  ompatible Crimping Tools Utilizes the same crimp tools as the DF11 Series, accommodating a wide cable range of 22 to 30 AWG.​ (Note : The crimp contacts of DF51K and DF11 are not interchangeable.)​ 8. U  L, C-UL certified​ - THT & SMT Type​ Applications​ Office equipment, Industrial machinery, Industrial robots, Amusement equipment, Medical equipment, etc.​ 3 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Product Specifications Rated​ Current​ (Note 1) THT​& SMT​ Type No. of​ Pos. 22​ AWG 24​ AWG 2 3A 2.5A 4 3A 2.5A Single-row Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Double-row Rated Voltage THT Type SMT Type UL/C-UL​ 3-6 6-30 Single-row Double-row Single-row Double-row Safety Standard Approved Specification​ (THT & SMT Type)​ 2A 2A Straight 26 AWG 2A 2A 2A 1.5A 28​ AWG 1A Right Angle​ 250V AC/DC Straight 30​ AWG 0.5A Operating Temperature​ -55 to +105° C (Note 2)​ Operating Humidity Range​ 20 to 80% (Note 3)​ Storage Temperature -10 to +60° C (Note 4) Storage Humidity Range 40 to 70% (Note 4) Right Angle 250V AC/DC 250V AC/DC 100V AC/DC 22 AWG Rated Current ​ (Note 1)​ 24 to 28 AWG 2A Rated Voltage 30 AWG 1A 0.5A 30V AC/DC UL/C-UL File No. and Recognition No. E132750​ Items Specifications Insulation Resistance​ No less than 1,000MΩ​ Withstanding Voltage​ No insulation breakdown​ Contact Resistance​ No more than 30mΩ Mating Durability​ Contact resistance : no more than 30mΩ Vibration Resistance​ No electrical discontinuity of 1μs or greater Shock Resistance No electrical discontinuity of 1μs or greater Moisture Resistance​ (Steady State) Contact resistance : no more than 30mΩ​ Insulation resistance : no less than 500MΩ Temperature Cycle Note 1 : Note 2 : Note 3 : Note 4 : Measured at 500V DC Conditions 650V AC is applied for 1 minute​ (*Double-row Right Angle SMT Header : 500V AC for 1min.) Measured at 1mA and no higher than 20mV Tin plated : 30 mating cycles, ​ Gold plated : 50 mating cycles Frequency : 10 to 55Hz, half amplitude 0.75mm,​ 10 times in each of the 3 directions Acceleration velocity : 490m/s2 for 11ms, ​ half-sine wave in 3 directions, 3 times for each directions Temperature : 40±2°C, humidity : 90 to 95%,​ left as it is for 96 hours Contact resistance : no more than 30mΩ​ Insulation resistance : no less than 1,000MΩ -55℃ : 30 minutes → +105℃ : 30 minutes, 5 cycles The rated current varies based on the cable size used. ​ Includes temperature rise caused by current flow.​ Use without condensation on parts.​ The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping.​ 4 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Materials / Finish Product​ Component​ Insulator​ THT Header​ Contact​ Insulator​ Contact​ SMT Header Retention Tab Crimp Socket Socket Contact Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material Straight : PA66​ Right Angle : PBT (Glass-reinforced)​ Black LCP​ Black Tin Plated or Gold Plated Brass​ Tin Plated or Gold Plated PBT (Glass-reinforced) Contact​ Phosphor Bronze Tin Plated Black Tin Plated or Gold Plated Product Number Structure​ Refer to the chart below when determining the product specifications from the product number. ​ Please select from the product numbers listed in this catalog when placing orders.​ Connector DF51K B - # P - 2 DSA 1 2 3 4 5 6 Crimp Contact​ DF51K - 2428 SCF A 1 7 8 9 1 Series Name DF51K 2 Form Type​ Blank : Without Guide-boss ​ B : With Guide-boss​ 3 No. of Pos.​ Single-row : 2 to 6​ Double-row : 4 to 30​ 4 Connector Type P : Single-row Pin Header​ S : Single-row Crimp Socket ​ DP : Double-row Pin Header ​ DS : Double-row Crimp Socket 5 Contact Pitch 2mm 6 Type of Housing​ 7 Applicable Wire 8 Packaging 9 Plating Specifications 5 UL Regulation UL94V-0 Brass​ Brass Insulator​ Color / Finish​ DSA : Straight THT​ DS : Right Angle THT​ V : Straight SMT​ H : Right Angle SMT​ C : Crimp Socket 22 : 22 AWG​ 2428 : 24 to 28 AWG​ 30 : 30 AWG SC : Socket Contacts, Bag​ SCF : Socket Contacts, Reel Blank : Tin plated​ A : Gold plated - UL94V-0 - UL94V-0 - DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Diagram of Connector Mating Combinations​ Single-row​ Crimp Socket​ Straight THT Header​ DF51K-22SC(F)(A)​ DF51K-#P-2DSA​ DF51K-2428SC(F)(A) DF51K-30SC(F)(A)​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF51K-#S-2C​ Socket Contact​ Right Angle THT Header​ DF51K(B)-#P-2DS​ Straight SMT Header​ DF51K-#P-2V​ Right Angle SMT Header​ DF51K-#P-2H​ 6 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Double-row​ Crimp Socket​ Straight THT Header​ DF51K-22SC(F)(A)​ DF51K-#DP-2DSA​ DF51K-2428SC(F)(A)​ DF51K-30SC(F)(A)​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF51K-#DS-2C​ Socket Contact​ Right Angle THT Header​ DF51K(B)-#DP-2DS​ Straight SMT Header​ DF51K-#DP-2V​ Right Angle SMT Header​ DF51K-#DP-2H​ 7 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Single-row THT Header Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated Part No. HRS No. DF51K-2P-2DSA(8##) CL0480-0542-0-## DF51K-4P-2DSA(8##) CL0480-0544-0-## DF51K-3P-2DSA(8##) CL0480-0543-0-## DF51K-5P-2DSA(8##) CL0480-0545-0-## DF51K-6P-2DSA(8##) CL0480-0546-0-## No. of Pos. A B 2 7.2 2.0 4 11.2 6.0 6 15.2 3 9.2 5 Unit : mm Purchase Unit 4.0 13.2 100pcs per bag 8.0 10.0 Right Angle Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated *The above drawing is of guide-boss type. Part No. HRS No. Guide-Boss No. of Pos. With boss 3 DF51KB-2P-2DS(8##) CL0480-0587-0-## DF51K-4P-2DS(8##) CL0480-0589-0-## Without boss CL0480-0591-0-## Without boss DF51KB-3P-2DS(8##) DF51K-5P-2DS(8##) DF51K-6P-2DS(8##) CL0480-0588-0-## CL0480-0590-0-## With boss Without boss A B C Unit : mm Purchase Unit 2 7.2 2.0 5.14 420pcs per tray 4 11.2 6.0 - 270pcs per tray 6 15.2 5 8 9.2 13.2 4.0 8.0 10.0 7.14 - 330pcs per tray 230pcs per tray 200pcs per tray DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Double-row THT Header​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated Part No. HRS No. DF51K-4DP-2DSA(8##) CL0480-0547-0-## DF51K-8DP-2DSA(8##) CL0480-0549-0-## DF51K-6DP-2DSA(8##) DF51K-10DP-2DSA(8##) DF51K-12DP-2DSA(8##) DF51K-14DP-2DSA(8##) DF51K-16DP-2DSA(8##) DF51K-18DP-2DSA(8##) DF51K-20DP-2DSA(8##) DF51K-22DP-2DSA(8##) DF51K-24DP-2DSA(8##) DF51K-26DP-2DSA(8##) DF51K-28DP-2DSA(8##) DF51K-30DP-2DSA(8##) CL0480-0548-0-## No. of Pos. 7.2 2.0 8 11.2 6.0 12 15.2 10.0 19.2 14.0 6 10 CL0480-0552-0-## 14 CL0480-0553-0-## CL0480-0554-0-## CL0480-0555-0-## CL0480-0556-0-## CL0480-0557-0-## CL0480-0558-0-## CL0480-0559-0-## CL0480-0560-0-## B 4 CL0480-0550-0-## CL0480-0551-0-## A 9.2 13.2 17.2 16 18 21.2 20 23.2 22 25.2 24 27.2 26 29.2 28 31.2 30 33.2 9 Unit : mm Purchase Unit 4.0 8.0 12.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 100pcs per bag DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right Angle Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated *The above drawing is of guide-boss type. Part No. HRS No. Guide-Boss No. of Pos. With boss 6 DF51KB-4DP-2DS(8##) CL0480-0592-0-## DF51K-8DP-2DS(8##) CL0480-0594-0-## Without boss CL0480-0596-0-## Without boss DF51KB-6DP-2DS(8##) DF51K-10DP-2DS(8##) DF51K-12DP-2DS(8##) DF51K-14DP-2DS(8##) DF51K-16DP-2DS(8##) DF51K-18DP-2DS(8##) DF51K-20DP-2DS(8##) DF51K-22DP-2DS(8##) DF51K-24DP-2DS(8##) DF51K-26DP-2DS(8##) DF51K-28DP-2DS(8##) DF51K-30DP-2DS(8##) CL0480-0593-0-## CL0480-0595-0-## CL0480-0597-0-## CL0480-0598-0-## CL0480-0599-0-## CL0480-0600-0-## CL0480-0601-0-## CL0480-0602-0-## CL0480-0603-0-## CL0480-0604-0-## CL0480-0605-0-## With boss 5.14 420pcs per tray 8 11.2 6.0 - 270pcs per tray 12 15.2 10.0 19.2 14.0 14 Without boss Without boss Without boss Without boss Without boss Purchase Unit 2.0 Without boss Without boss C 7.2 10 Without boss B 4 Without boss Without boss A Unit : mm 16 18 20 22 24 26 28 30 10 9.2 13.2 17.2 21.2 23.2 25.2 27.2 29.2 31.2 33.2 4.0 8.0 12.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 7.14 - 330pcs per tray 230pcs per tray 200pcs per tray 170pcs per tray 150pcs per tray 140pcs per tray 130pcs per tray 120pcs per tray 110pcs per tray 100pcs per tray 90pcs per tray 90pcs per tray DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Single-row SMT Header​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Recommended PCB Layout (t=1.6mm)​ [Specification number] - ##, (8##) ​ 00 : Tin plated​ 05 : Gold plated​ Part No. HRS No. No. of Pos. Under Planning (Note)​ 3 11.4 5 15.4 DF51K-2P-2V(8##)​ CL0480-0949-0-##​ DF51K-4P-2V(8##)​ CL0480-1027-0-## DF51K-3P-2V(8##)​ DF51K-5P-2V(8##)​ DF51K-6P-2V(8##)​ Under Planning (Note)​ CL0480-0950-0-##​ A 2 4 6 B Unit : mm Purchase Unit 9.4​ 2.0 350pcs per reel​ 13.4 6.0 350pcs per reel 10.0 350pcs per reel 17.4 4.0 8.0 - Note : Products without HRS No. are currently being planned for development. Please contact a Hirose representative regarding questions on pin count variation development.​ Right Angle Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated Part No. HRS No. No. of Pos. Under Planning (Note)​ 3 11.4 5 15.4 DF51K-2P-2H(8##)​ CL0480-0944-0-##​ DF51K-4P-2H(8##)​ CL0480-1024-0-## DF51K-3P-2H(8##)​ DF51K-5P-2H(8##)​ DF51K-6P-2H(8##)​ Under Planning (Note)​ CL0480-0945-0-##​ A 2 4 6 B Unit : mm Purchase Unit 9.4​ 2.0 530pcs per reel​ 13.4 6.0 530pcs per reel 10.0 530pcs per reel​ 17.4 4.0 8.0 - Note : Products without HRS No. are currently being planned for development. Please contact a Hirose representative regarding questions on pin count variation development.​ 11 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Double-row SMT Header​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Straight Recommended PCB Layout (t=1.6mm)​ [Specification number] - ##, (8##) ​ 00 : Tin plated​ 05 : Gold plated​ Part No. HRS No. DF51K-4DP-2V(8##)​ CL0480-0951-0-##​ DF51K-30DP-2V(8##)​ CL0480-0953-0-##​ DF51K-16DP-2V(8##)​ CL0480-0952-0-##​ No. of Pos. A 4 9.4​ 16 21.4 30 35.4 Right Angle Unit : mm B Purchase Unit 14.0 350pcs per reel​ 2.0 28.0 Recommended PCB Layout (t=1.6mm) [Specification number] - ##, (8##) 00 : Tin plated 05 : Gold plated Part No. HRS No. DF51K-4DP-2H(8##)​ CL0480-0946-0-##​ DF51K-30DP-2H(8##)​ CL0480-0948-0-##​ DF51K-16DP-2H(8##)​ CL0480-0947-0-##​ No. of Pos. A 4 9.4​ 16 21.4 30 35.4 12 Unit : mm B Purchase Unit 14.0 300pcs per reel​ 2.0 28.0 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Crimp Socket Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Single-row Shown with crimp contact inserted. Part No. HRS No. DF51K-2S-2C(800)​ CL0480-0561-0-00 DF51K-4S-2C(800)​ CL0480-0563-0-00 DF51K-3S-2C(800)​ DF51K-5S-2C(800)​ DF51K-6S-2C(800)​ CL0480-0562-0-00 CL0480-0564-0-00 CL0480-0565-0-00 No. of Pos. A B 2 6.8 2.0 4 10.8 6.0 6 14.8 3 8.8 5 12.8 4.0 8.0 Unit : mm Purchase Unit 100pcs per bag 10.0 Double-row Shown with crimp contact inserted. Part No. HRS No. DF51K-4DS-2C(800)​ CL0480-0567-0-00 DF51K-8DS-2C(800)​ CL0480-0569-0-00 DF51K-6DS-2C(800)​ DF51K-10DS-2C(800)​ DF51K-12DS-2C(800)​ DF51K-14DS-2C(800)​ DF51K-16DS-2C(800)​ DF51K-18DS-2C(800)​ DF51K-20DS-2C(800)​ DF51K-22DS-2C(800)​ DF51K-24DS-2C(800)​ DF51K-26DS-2C(800)​ DF51K-28DS-2C(800)​ DF51K-30DS-2C(800)​ CL0480-0568-0-00 No. of Pos. 6.8 2.0 8 10.8 6.0 12 14.8 10.0 18.8 14.0 6 10 CL0480-0572-0-00 14 CL0480-0573-0-00 CL0480-0574-0-00 CL0480-0575-0-00 CL0480-0576-0-00 CL0480-0577-0-00 CL0480-0578-0-00 CL0480-0579-0-00 CL0480-0580-0-00 B 4 CL0480-0570-0-00 CL0480-0571-0-00 A 8.8 12.8 16.8 16 18 20.8 20 22.8 22 24.8 24 26.8 26 28.8 28 30.8 30 32.8 13 Unit : mm Purchase Unit 4.0 8.0 12.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 100pcs per bag DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Socket Contact Part No. HRS No. DF51K-22SCF(800) CL0480-0581-0-00​ DF51K-2428SCF(800) CL0480-0583-0-00​ DF51K-22SC(800) Finish CL0480-0582-0-00​ DF51K-2428SC(800) DF51K-30SC(800) Tin plated DF51K-22SCA(800) CL0480-0612-0-00 10,000pcs per reel 100pcs per bag 100pcs per bag CL0480-0614-0-00 DF51K-2428SCA(800) Gold plated CL0480-0615-0-00 DF51K-30SCFA(800) CL0480-0616-0-00 DF51K-30SCA(800) 1007 1061 100pcs per bag 100pcs per bag Applicable Wire (Tin Plated Annealed Copper Wire) 1061 10,000pcs per reel 10,000pcs per reel CL0480-0617-0-00 UL 100pcs per bag 10,000pcs per reel CL0480-0613-0-00 DF51K-2428SCFA(800) 10,000pcs per reel CL0480-0585-0-00 CL0480-0586-0-00 DF51K-22SCFA(800) 10,000pcs per reel​ 100pcs per bag CL0480-0584-0-00 DF51K-30SCF(800) Purchase Unit Wire Size (Stranded Wire Structure) Jacket Diameter 22 AWG (17 pieces / 0.16mm) Ø1.2 to Ø1.45mm 26 AWG (7 pieces / 0.16mm) Ø0.9 to Ø1.45mm 30 AWG (7 pieces / 0.1mm) Ø0.8mm 24 AWG (11 pieces / 0.16mm) 28 AWG (7 pieces / 0.127mm) Note 1 : Applicable Tool : Applicator Note 2 : Contact your Hirose representative when considering usage of non-applicable wires. 14 Unit : mm DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Mated Dimensions Wire-to-Board Connection Using the Straight THT Header Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [Single-row] [Double-row] Wire-to-Board Connection Using the Right Angle THT Header [Single-row] [Double-row] Wire-to-Board Connection Using the Straight SMT Header [Single-row] [Double-row] Wire-to-Board Connection Using the Right Angle SMT Header [Single-row] [Double-row] 15 DF51K Series / 2mm Pitch, Center Lock, Wire-to-Board Connector (UL/C-UL Listed) Applicable Crimping Tools Type​ Applicator​ Automatic Crimp Press​ Hand Tool​ Apr.1.2024 Copyright 2024 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact Extraction Tool​ Part No.​ HRS No.​ Applicable Contacts​ AP105-DF11-22S​ CL0901-4529-7-00​ DF51K-22SCF/SCFA​ AP105-DF11-30S​ CL0901-4532-1-00​ DF51K-30SCF/SCFA​ AP105-DF11-2428S​ CL0901-4511-1-00​ CM-105C​ CL0901-0001-0-00​ HT801/DF11-22S(A)​ HT801/DF11-2428S(A)​ CL0550-0407-5-00​ DF51K-22SC/SCA​ CL0550-0408-8-00​ DF51K-30SC/SCA​ CL0550-0403-4-00​ HT801/DF11-30S(A)​ DF-C-PO(B)​ DF51K-2428SCF/SCFA​ CL0550-0179-2-00​ Note 1 : Please conduct crimping work according to the "Crimp Quality Standard" and "Crimp Condition Table". ​ - DF51K-2428SC/SCA​ DF51K-22SC(F)(A)​ DF51K-2428SC(F)(A)​ DF51K-30SC(F)(A) Note 2 : Any problems that occur from using tools other than those specified by Hirose are not covered by warranty. ​ Note 3 : Please contact Hirose for information about hand tooling.​ Precautions for use 1. T  he connector could be damaged if pulled out forcibly. When it is hard to pull out, push it in slightly first and​ then depress the lock and un- mate. ​ Please refer to “ DF51K mating and unmating Procedure Document ( DOC180208- 010) ” for points in handling ​ regarding mating operations. ​ ​2. W  hen mating a crimped contact into a socket, please refrain from inserting it diagonally in order to maintain ​ performance reliability. Please refer to the " Harness procedure manual ( DOC180330- 002) " for points in ​ harness operations. ​ Operating Environment​ Please contact a Hirose representative if you are designing this connector into environmental conditions where high and low temperatures are repeated. ​ While taking into consideration​ Specifications mentioned in this catalog are reference values. ​ When considering to order or use this product, please review the Drawing and Product Specifications sheets. ​ Use an appropriate cable when using the connector in combination with cables. ​ If considering usage of a non- specified cable, please contact your sales representative. ​ If assembly process is done by jigs & tools which are not identified by Hirose, the warranty of the product may be affected. ​ If considering usage for below mentioned applications, please contact your sales representative. ​ In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public​ infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. ​ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ ※ The contents of this catalog are current as of date of 03/ 2024. Contents are subject to change without notice for the purpose of improvements. ※ The HRS logo and " HIROSE" are trademarks of HIROSE ELECTRIC CO. , LTD. 16
DF51K-4S-2C(800) 价格&库存
很抱歉,暂时无法提供与“DF51K-4S-2C(800)”相匹配的价格&库存,您可以联系我们找货
DF51K-4S-2C(800)
    库存:3455
    DF51K-4S-2C(800)
      • 3000+0.71500
      库存:19980
