DF62W-ep2226pcfA
DF62W-ep2226pcfA
    HRS(广濑)
DF62W-ep2226pcfA 数据手册
2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces DF62 Series / DF62W Series (UL, C-UL Listed) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Non-waterproof type (DF62B, DF62C, DF62P) ■Features Waterproof type (DF62W) Compact shape due to 2 × 2.2 grid layout of pins *Both are 7 contacts with 3A current rating 1. The slim, sleek design and smooth contour combine to complete connections in tight spaces. These connectors were designed to take full advantage of small/narrow spaces. The contacts are arranged in a grid pattern which shortens the diagonal distances and the body was slimmed down by creating smooth outer surfaces. This design helps to save precious space and makes these connectors virtually tangle free. There is no visible or exposed metal which would eliminate the possibility of electrical arcing between the connector and the inside of a metal conduit. (Please refer to Fig. 1 and 2) 16 16 Existing products DF62 Fig.1 Grid Arrangement Smooth external shape No exposed metal 2. Secure lock mechanism The locking structure emits a clear tactile click upon lock completion. After completion, a second indicator can be utilized. The socket lock can be visually checked through the plug window after mating. These indicators function together to prevent incomplete mating. (Please refer to Fig. 3) 3. Reliable contact structure The structure utilizes two contact points to provide a reliable contact that resists damage from vibration and rough operation. 4. Robust contact structure The unique structure provides protection to the contacts and lance areas, it prevents any bending or deformity that might occur during mating, the assembly procedure or while in transportation. (Please refer to Fig. 4) Fig.2 Visual check for complete mating 1.Visual check area 2. Locking is confirmed by an audible click. Image of the outward appearance of the contact Fig.3 (Water-resistant type (DF62W)) Robust box-shaped contact structure (For non-water-proof type) 5. Multiple variations available There are several different wire counts available, giving the designer the variety needed to complete the application. Protected lock type, panel mount type and pin header type are also available. 6. Applicator sharing The applicators for the DF11 and DF59 series (existing products) can be adapted to accommodate the DF62 series applicators. *Some modifications are required. Please contact Hirose for additional details. 7. Condensation prevention measure (Water-resistant type DF62W) (Non-water-resistant type (DF62) contacts) Designed for easy contact insertion. Fig.4 Condensation prevention measure (IP67 level Water-resistance) Housing seal Wire seal Wire seal IP67 level water-resistance in mated condition. (Fig. 5) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. Fig.5 2019.5⑤ 1 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ■Product Specifications DF62 22 AWG : 4A/pin (2 pos.) 3A/pin (3 to 13 pos.) Current 2.5A/pin (24 pos.) Rating (Note 1) 24 AWG : 2A/pin 26 to 30 AWG : 1A/pin Operating Temperature Range -35 to 105ç (Note 2) UL/C-UL -35 to 75ç(Note 2) Operating Humidity Range 20 ∼ 80% (Note 3) 20 AWG : 5A (2 pos.), 3.5A/pin (3 to 9 pos) Operating Temperature Range Current 22 AWG : 4A (2 pos.), 3A/pin (3 to 9 pos) Ratings DF62W Rating 24 AWG : 3.5A (2 pos.), 2A/pin (3 to 9 pos) (Note 1) 26 AWG : 3A (2 pos.), 1A/pin (3 to 9 pos) Operating Humidity Range Common Voltage Rating Specifications AC/DC 250V Storage Temperature Range UL File name UL:E52653 C-UL : E52653 Storage Humidity Range Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. UL/C-UL AC/DC 29.9V Items Specifications -40 to 105ç(Note 2) UL/C-UL -40 to 75ç(Note 2) 20 to 80%(Note 3) -10 to 60ç (Note 4) 40 to 70% (Note 4) Conditions 1. Insulation Resistance Minimum of 1,000Mø Measured with DC 500V 2. Withstanding Voltage No flashover or breakdown Apply AC 650V for 1minute 3. Contact Resistance Maximum of 30mø Measured at a maximum of 20mV and 100mA (DC or 1000Hz) 4. Vibration Resistance No electrical discontinuity of 1µs or longer 10 cycles in each of three directions at frequency 10-55Hz, half amplitude 0.75mm 5. Shock Resistance No electrical discontinuity of 1µs or longer Acceleration : 490m/s2, 11ms, Semi-sinusoidal 3 axle direction 3 times each. 6. Humidity Resistance Contact Resistance Maximum of 30mø Insulation Resistance : Minimum of 1,000Mø Left at temperature 40 ±2ç, humidity 90 to 95%, 96 hours 7. Temperature Cycles Contact Resistance : Maximum of 30mø Insulation Resistance : Minimum of 1,000Mø -55ç : 30 minutes → 5 to 35ç : 2 to 3 minutes → 85ç : 30 minutes → 5 to 35ç : 2 to 3 minutes, 5 cycles 8. Durability Contact Resistance : Maximum of 30mø 9. Solder heat resistnace There should be no melting of the resin part which will influence the performance. Mating/unmating : 30 mating cycles Flow : 260ç, 10sec Hand soldering : temperature of soldering iron at 300ç for 3sec. Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple circuits, current ratings may go above the stated current ratings. Please consult Hirose for specific details before doing this. Note 2 : Includes the temperature rise of power lines Note 3 : The connector should be completely dry (no condensation present) Note 4 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. The operating temperature and humidity ranges are applied while in a non-energized state, while in transport or after PCB mounting. ■Materials / Finish Item Socket crimping contact Plug crimping contact Crimping socket Crimping plug Crimping socket * Crimping plug * Component Material Finish UL Flammability rating Contact Phosphorous bronze Gold plating or tin plating − Contact Phosphorous bronze Gold plating or tin plating − Insulator Insulator PBT PBT White Black UL94V-0 UL94V-0 Seal Silicone rubber Bengala − Insulator Header DF62W Contact Metal fitting Seal * *Waterproof type (DF62W) only 2 DF62 Straight pin header : Polyamide Right angle pin header : PBT Black PBT Copper alloy Gold plating or tin plating Brass Silicone rubber Tin plating Bengala UL94V-0 − − − DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Note : The water-proof type and a non-water-proof type are not intermateable. ◆Non-water-resistant type ●Connector DF 62B - * S - 2.2 C (**) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶Series Name:DF ❻Connection part shape C : Crimping housing ❷Series No. : 62B (regular type) 62C (Protected lock type ) 62P (Panel mount type ) ❼Color Socket None : White 11 : Black 18 : Red Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❸No. of Contacts : 2, 3, 4, 5, 6, 7, 13, 24 ❹Connector type S : Socket, EP : Extension plug ❺Contact pitch : 2.2mm Extension plug None : Black 10 : White 18 : Red ●Contact DF 62 - EP 2428 PCF A ❶ ❷ ❸ ❹ ❺ ❶Series Name:DF ❻ ❺Contact type /packaging type SCF : Socket crimping contact, reel SC : Socket crimping contact, pieces PCF : Plug crimping contact, reel PC : Plug crimping contact, pieces ❷Series No. : 62 ❸Terminal type EP : Extension plug ❹Applicable wire size 22 :22 AWG 2428:24 to 28 AWG 30 :30 AWG ❻Plating type A : Gold plating None : Tin plating ●Connector DF 62 - * P - 2.2 DSA (**) ❶ ❷ ❸ ❹ ❶Series Name:DF ❷Series No. : 62 ❸No. of Contacts : 13, 24 ❹Connector type P : Header ❺Contact pitch : 2.2mm ❺ ❻ ❼ ❻Connection part shape DSA : Straight pin header DS : Right angle pin header ❼Plating type None : Tin plating 01 : Gold plating 3 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ◆IP67 Water-resistant type ●Connector DF 62W - * S - 2.2 C ❶ ❷ ❸ ❹ ❺ ❻ ❶Series Name:DF ❺Contact pitch : 2.2mm ❷Series No. : 62W ❸No. of Contacts : 2, 3, 4, 6, 9 ❻Connection part shape C : Crimping housing ❹Connector type S : Socket, EP : Extension plug ●Contact DF 62W - EP 2226 PCF A Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❶Series Name:DF ❸Terminal type EP : Extension plug ❺Contact type /packaging type SCF : Socket crimping contact, reel SC : Socket crimping contact, pieces PCF : Plug crimping contact, reel PC : Plug crimping contact, pieces ❹Applicable wire size 2022:20 to 22 AWG 2226:22 to 26 AWG ❻Plating type A : Gold plating None : Tin plating ❷Series No. : 62W ●Water-proof pin DF 62W - WP ❶ ❷ ❸ ❶Series Name:DF ❸For each use type WP : ◆IP67 Water-resistant type ❷Series No. : 62W ●Connector DF 62WZ - * P - 2.2 DSA (**) ❶ ❷ ❸ ❹ ❶Series Name:DF ❷Series No. : 62WZ ❸No. of Contacts : 9 ❹Connector type P : Header ❺Contact pitch : 2.2mm 4 ❺ ❻ ❼ ❻Connection part shape DSA : Straight pin header ❼Plating type 20 : Tin plating 50 : Gold plating DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ■Socket (standard type) 9.55 A *7 pos. shown as an example. Cavity No. P=2 B [Specification No.] ** None : White (11) : Black (18) : Red P=2.2 Contact No. marking Unit : mm No. of Contacts Part No. HRS No. A B Part No. HRS No. DF62B-2S-2.2C(**) 544-0551-0 ** 2 5.08 DF62B-6S-2.2C(**) 544-0555-0 ** DF62B-3S-2.2C(**) 544-0552-2 ** 3 4.9 DF62B-7S-2.2C(**) 544-0556-3 ** DF62B-4S-2.2C(**) 544-0553-5 ** 4 7.08 DF62B-13S-2.2C(**) 544-0557-6 ** DF62B-5S-2.2C(**) 544-0554-8 ** 5 7.1 DF62B-24S-2.2C(**) 544-0539-4 ** Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. 6 7 13 24 ■Socket (Protected lock type) A 7.1 9.3 12.3 B 7.08 9.08 11.08 13.08 A *7 pos. shown as an example. Cavity No. P=2 B [Specification No.] ** None : White (11) : Black (18) : Red P=2.2 Contact No. marking Unit : mm No. of Part No. HRS No. A B Part No. HRS No. Contacts DF62C-2S-2.2C(**) 544-0565-4 ** 2 5.65 DF62C-6S-2.2C(**) 544-0569-5 ** DF62C-3S-2.2C(**) 544-0566-7 ** 3 4.9 DF62C-7S-2.2C(**) 544-0570-4 ** DF62C-4S-2.2C(**) 544-0567-0 ** 4 7.65 DF62C-13S-2.2C(**) 544-0571-7 ** DF62C-5S-2.2C(**) 544-0568-2 ** 5 7.1 DF62C-24S-2.2C(**) 544-0541-6 ** Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. No. of Contacts 6 7 13 24 Contact No. ■Socket (Water proof type) A 7.1 9.3 12.3 B 7.65 9.65 11.65 13.65 *9 pos. shown as an example. A Cavity No. B 14.05 P=2.2 No. of Contacts HRS No. 544-1002-7 544-1004-2 544-1006-8 Part No. DF62W-2S-2.2C DF62W-3S-2.2C DF62W-4S-2.2C A 2 3 4 7.5 B 7.55 P=2.2 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of Contacts Unit : mm HRS No. 544-1008-3 544-1010-5 Part No. DF62W-6S-2.2C DF62W-9S-2.2C 9.75 No. of Contacts A 6 9 9.7 B 9.75 11.95 Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. Note 2 : The Water-proof type and a non-water-proof type are not intermateable. Pin configuration of the contact numbers. (Shown from the mating side.) 2 pos. 3 pos. 1 2 4 pos. 1 2 3 Ø9.2mm Ø10.4mm Ø10.8mm Note : Applicable jacket outer diameter : Ø1.4 to 1.6mm 6 pos. 9 pos. 1 2 1 2 3 1 2 3 3 4 4 5 6 4 5 6 7 8 9 Ø11.6mm Ø13.3mm 5 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) A ■Plug (standard type) *7 pos. shown as an example. 16.05 Cavity No. P=2 B [Specification No.] ** None : Black (10) : White (18) : Red P=2.2 Contact No. marking Unit : mm No. of Contacts No. of Contacts Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. A B Part No. HRS No. DF62B-2EP-2.2C(**) 544-0558-9 ** 2 5.3 DF62B-6EP-2.2C(**) 544-0562-6 ** DF62B-3EP-2.2C(**) 544-0559-1 ** 3 6.0 DF62B-7EP-2.2C(**) 544-0563-9 ** DF62B-4EP-2.2C(**) 544-0560-0 ** 4 7.3 DF62B-13EP-2.2C(**) 544-0564-1 ** DF62B-5EP-2.2C(**) 544-0561-3 ** 5 8.2 DF62B-24EP-2.2C(**) 544-0540-3 ** Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. 6 7 13 24 A 8.2 10.4 13.4 B 7.3 9.3 11.3 13.3 A ■Plug (Panel mount type ) 16.05 Cavity No. P=2 B [Specification No.] ** None : Black (10) : White (18) : Red P=2.2 Contact No. marking Unit : mm No. of Part No. HRS No. A B Part No. HRS No. Contacts DF62P-2EP-2.2C(**) 544-0543-1 ** 2 5.3 DF62P-6EP-2.2C(**) 544-0547-2 ** DF62P-3EP-2.2C(**) 544-0544-4 ** 3 11.3 DF62P-7EP-2.2C(**) 544-0548-5 ** DF62P-4EP-2.2C(**) 544-0545-7 ** 4 7.3 DF62P-13EP-2.2C(**) 544-0549-8 ** DF62P-5EP-2.2C(**) 544-0546-0 ** 5 13.5 DF62P-24EP-2.2C(**) 544-0550-7 ** Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. No. of Contacts 6 7 13 24 P=2.2 13.5 15.7 18.7 B 7.3 9.3 11.3 13.3 *9 pos. shown as an example. P=2.2 ■Plug (Water proof type) A B 23.05 A Cavity No. Contact No. Unit : mm Part No. DF62W-2EP-2.2C DF62W-3EP-2.2C DF62W-4EP-2.2C HRS No. 544-1003-0 544-1005-5 544-1007-0 No. of Contacts A 7.5 8.0 9.1 2 3 4 B 6.7 Part No. DF62W-6EP-2.2C DF62W-9EP-2.2C 9.15 HRS No. 544-1009-6 544-1011-8 No. of Contacts A 6 9 11.3 B 9.15 11.35 Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack increments. Note 2 : The Water-proof type and a non-water-proof type are not intermateable. Pin configuration of the contact numbers. (Shown from the mating side.) 2 pos. 3 pos. 2 1 4 pos. 2 1 3 Ø8.5mm Ø9.7mm Ø10.2mm Note : Applicable jacket outer diameter : Ø1.4 to 1.6mm 6 6 pos. 9 pos. 2 1 3 2 1 3 2 1 4 3 6 5 4 6 5 4 9 8 7 Ø11.5mm Ø12.8mm DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) BSocket contact No. Summary diagram (from the mating section side) 2 pos. 1 2 3 pos. 2 1 3 4 pos. 1 3 2 4 5 pos. 2 1 4 6 pos. 3 5 1 4 2 5 7 pos. 3 6 2 1 4 3 6 13 pos. 1 5 7 4 8 2 3 5 6 7 9 10 11 12 13 24 pos. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BPlug contact No. Summary diagram (from the mating section side) 2 pos. 3 pos. 4 pos. 2 1 2 1 3 2 1 4 3 5 pos. 3 5 2 1 4 6 pos. 3 6 2 1 5 4 5 7 pos. 13 pos. 24 pos. 2 1 4 3 7 6 3 2 1 7 6 5 4 11 10 9 8 13 12 5 4 3 2 1 10 9 8 7 6 15 14 13 12 11 20 19 18 17 16 24 23 22 21 BContact No. diagram No.1 No.2 No.3 No.4 No.5 No.6 No.8 No.10 No.11 No.12 No.13 No.15 No.16 No.20 No.21 No.22 No.23 No.24 No.7 7 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) (11.15) ■Socket crimping contact 3 1.83 1.5 7.45 ●Reel Contact (1Reel, 15,000 reel contacts)  *Applicable tool : Applicator Part No. Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF62-22SCF DF62-22SCFA DF62-2428SCF DF62-2428SCFA HRS No. Finish UL 544-0520-6 Tin plated 1061 544-0506-5 Gold plated 544-0521-9 Tin plated 1007 544-0500-9 Gold plated Applicable wire (tin plated annealed copper) (Note 1) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 22 AWG 24 AWG 26 AWG 28 AWG 17/0.16mm 0.342mm2 11/0.16mm 7/0.16mm 7/0.127mm 2 0.221mm 0.141mm2 0.089mm2 Ø1.2 to Ø1.45mm Ø0.9 to Ø1.45mm DF62-30SCF 544-0522-1 Tin plated Ø0.75 to Ø1.2mm 1007 30 AWG 7/0.1mm 0.055mm2 DF62-30SCFA 544-0508-0 Gold plated Note 1 : When using wires that are not recommended by Hirose, please contact one of our sales representatives for clarification. ●Loose piece (1pack, 100)  *Applicable tool : hand crimping tool Part No. DF62-22SC DF62-22SCA DF62-2428SC DF62-2428SCA HRS No. Finish UL 544-0572-0 Tin plated 1061 544-0526-2 Gold plated 544-0573-2 Tin plated 1007 544-0527-5 Gold plated Applicable wire (tin plated annealed copper) (Note 2) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 22 AWG 24 AWG 26 AWG 28 AWG 17/0.16mm 0.342mm2 Ø1.26mm 11/0.16mm 7/0.16mm 7/0.127mm 2 0.221mm 0.141mm2 0.089mm2 Ø1.42mm Ø1.28mm Ø1.18mm 7/0.1mm 0.055mm2 Ø0.82mm DF62-30SC 544-0574-5 Tin plated 1007 30 AWG DF62-30SCA 544-0528-8 Gold plated Note 2 : The applicable cables include only those listed above. ■Socket crimp contact (for water-proof version) (11.5) 3 1.37 1.6 7.8 ●Reel Contact (1Reel, 15,000 reel contacts)  *Applicable tool : Applicator Applicable wire (tin plated annealed copper) (Note 1) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 20 AWG 7/0.32mm 0.563mm2 DF62W-2022SCF DF62W-2022SCFA 22 AWG 17/0.16mm 0.342mm2 22 AWG 17/0.16mm 0.342mm2 Ø1.4 to Ø1.6mm 1007 0.221mm2 24 AWG 11/0.16mm DF62W-2226SCF 544-1000-1 Tin plated DF62W-2226SCFA 544-1025-0 Gold plated 24 AWG 11/0.16mm 0.221mm2 1430 0.141mm2 26 AWG 7/0.16mm Note 1 : When using wires that are not recommended by Hirose, please contact one of our sales representatives for clarification. Note 2 : In case of hard to insert crimped contact to socket as like using low stiffness wire which consists of thinner stranded conductor or insulation with soft material, please contact to Hirose representative. Note 3 : The Water-proof type and non-water-proof type are a not intermateable. Part No. HRS No. Finish UL 544-1015-9 Tin plated 3443 544-1027-0 Gold plated 1007   ●Loose piece (1pack, 100)  *Applicable tool : hand crimping tool Part No. DF62W-2022SC DF62W-2022SCA HRS No. Finish UL 544-1017-4 Tin plated 3443 544-1045-0 Gold plated 1007 544-1012-0 Tin plated 1007 544-1044-0 Gold plated 1430 Note 4 : The applicable cables include only those listed above. DF62W-2226SC DF62W-2226SCA 8 Applicable wire (tin plated annealed copper) (Note 4) Wire size Stranded wire structure Calculated cross-section Jacket Diameter Ø1.53mm 20 AWG 7/0.32mm 0.563mm2 Ø1.58mm 22 AWG 17/0.16mm 0.342mm2 Ø1.58mm 22 AWG 17/0.16mm 0.342mm2 Ø1.42mm 0.221mm2 24 AWG 11/0.16mm Ø1.48mm 26 AWG 7/0.16mm 0.141mm2 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ■Plug crimping contact &*#)* ( &#,- &#* &&#,* ●Reel Contact (1Reel, 15,000 reel contacts)  *Applicable tool : Applicator Part No. DF62-EP2428PCF DF62-EP2428PCFA Finish UL 544-0523-4 Tin plated 1061 544-0507-8 Gold plated 544-0524-7 Tin plated 1007 544-0501-1 Gold plated Applicable wire (tin plated annealed copper) (Note 1) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 22 AWG 24 AWG 26 AWG 28 AWG 17/0.16mm 0.342mm2 11/0.16mm 7/0.16mm 7/0.127mm 2 Ø1.2 to Ø1.45mm 0.221mm 0.141mm2 0.089mm2 Ø0.9 to Ø1.45mm DF62-EP30PCF 544-0525-0 Tin plated Ø0.75 to Ø1.2mm 1007 30 AWG 7/0.1mm 0.055mm2 DF62-EP30PCFA 544-0509-3 Gold plated Note 1 : When using wires that are not recommended by Hirose, please contact one of our sales representatives for clarification. ●Loose piece (1pack, 100)  *Applicable tool : hand crimping tool Part No. DF62-EP22PC DF62-EP22PCA DF62-EP2428PC DF62-EP2428PCA HRS No. 544-0575-8 544-0529-0 544-0576-0 544-0530-0 Finish UL Tin plated 1061 Gold plated Tin plated 1007 Gold plated Applicable wire (tin plated annealed copper) (Note 2) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 22 AWG 24 AWG 26 AWG 28 AWG DF62-EP30PC 544-0577-3 Tin plated 1007 30 AWG DF62-EP30PCA 544-0529-0 Gold plated Note 2 : The applicable cables include only those listed above. 17/0.16mm 0.342mm2 Ø1.26mm 11/0.16mm 7/0.16mm 7/0.127mm 2 0.221mm 0.141mm2 0.089mm2 Ø1.42mm Ø1.28mm Ø1.18mm 7/0.1mm 0.055mm2 Ø0.82mm ■Plug crimping contact (for water-proof version) (15.3) 3 1.6 11.6 1.37 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF62-EP22PCF DF62-EP22PCFA HRS No. ●Reel Contact (1Reel, 15,000 reel contacts)  *Applicable tool : Applicator Applicable wire (tin plated annealed copper) (Note 1) Wire size Stranded wire structure Calculated cross-section Jacket Diameter 20 AWG 7/0.32mm 0.563mm2 DF62W-EP2022PCF DF62W-EP2022PCFA 22 AWG 17/0.16mm 0.342mm2 22 AWG 17/0.16mm 0.342mm2 Ø1.4 to Ø1.6mm 1007 0.221mm2 24 AWG 11/0.16mm DF62W-EP2226PCF 544-1001-4 Tin plated DF62W-EP2226PCFA 544-1026-0 Gold plated 24 AWG 11/0.16mm 0.221mm2 1430 0.141mm2 26 AWG 7/0.16mm Note 1 : When using wires that are not recommended by Hirose, please contact one of our sales representatives for clarification. Note 2 : In case of hard to insert crimped contact to socket as like using low stiffness wire which consists of thinner stranded conductor or insulation with soft material, please contact to Hirose representative. Note 3 : The Water-proof type and non-water-proof type are a not intermateable. Part No. HRS No. Finish UL 544-1016-1 Tin plated 3443 544-1028-0 Gold plated 1007   ●Loose piece (1pack, 100)  *Applicable tool : hand crimping tool Part No. DF62W-EP2022PC DF62W-EP2022PCA HRS No. Finish UL 544-1018-7 Tin plated 3443 544-1043-0 Gold plated 1007 544-1013-3 Tin plated 1007 544-1042-0 Gold plated 1430 Note 4 : The applicable cables include only those listed above. DF62W-EP2226PC DF62W-EP2226PCA Applicable wire (tin plated annealed copper) (Note 4) Wire size Stranded wire structure Calculated cross-section Jacket Diameter Ø1.53mm 20 AWG 7/0.32mm 0.563mm2 Ø1.58mm 22 AWG 17/0.16mm 0.342mm2 Ø1.58mm 22 AWG 17/0.16mm 0.342mm2 Ø1.42mm 0.221mm2 24 AWG 11/0.16mm Ø1.48mm 26 AWG 7/0.16mm 0.141mm2 9 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) BApplicable Crimping Tool ●DF62 Type Applicator Press body Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Hand tool Extraction tool Part No. HRS No. AP105-DF62-22 901-4626-3 AP105-DF62-2428 901-4625-0 AP105-DF62-30 901-4627-6 CM-105C 901-0001-0 HT801/DF62-22(10) (Note 3) 550-0401-9 10 HT801/DF62-2428(10) (Note 4) 550-0400-6 10 HT801/DF62-30(10) (Note 5) 550-0402-1 10 DF62/RE-MD 902-4645-4 Applicable Contact DF62-22SCFA/SCF DF62-EP22PCFA/PCF DF62-2428SCFA/SCF DF62-EP2428PCFA/PCF DF62-30SCFA/SCF DF62-EP30PCFA/PCF − DF62-22SCA/SC DF62-EP22PCA/PC DF62-2428SCA/SC DF62-EP2428PCA/PC DF62-30SCA/SC DF62-EP30PCA/PC DF62-**SCFA/SCF/SCA/SC DF62-EP**PCFA/PCF/PCA/PC Note 1 : Hirose does not warranty problems that arise from the use of unapproved tools on Hirose products. Note 2 : Please conduct crimping work according to the "Crimping quality control statement of standards (ETAD-H0642, ETAD-H0643)" and "Crimping condition table". Note 3 : The compatible wire is limited to UL1061 (22 AWG). Note 4 : The compatible wire is limited to UL1007 (24 to 28 AWG). Note 5 : The compatible wire is limited to UL1061 (30 AWG). ●DF62W Type Applicator Press body Part No. HRS No. AP105-DF62W-2022 EHS899800H-UP (Note 2) AP105-DF62W-2226 EHS888400H-UP (Note 2) CM-105C 901-4500-0 − 901-4637-0 − 901-0001-0 HT802/DF62W-2022 (Note 4) 550-0431-0 HT802/DF62W-2226 (Note 5) 550-0416-6 DF62W/RE-MD 902-4666-4 Hand tool Extraction tool Applicable Contact DF62W-2022SCF(A) DF62W-EP2022PCF(A) DF62W-2226SCF(A) DF62W-EP2226PCF(A) − DF62W-2022SC(A) DF62W-EP2022PC(A) DF62W-2226SC(A) DF62W-EP2226PC(A) DF62W-2022SC(F)(A) DF62W-EP2022PC(F)(A) DF62W-2226SC(F)(A) DF62W-EP2226PC(F)(A) Note 1 : Hirose does not warranty problems that arise from the use of unapproved tools on Hirose products. Note 2 : Applicator manufactured by JAPAN AUTOMATIC MACHINE(J.A.M.). Please access to HP of J.A.M., if you make inquiries about the applicator or crimp defect. (URL : http://www.jam-net.co.jp) Note 3 : Please conduct crimping work according to the "Crimping quality control statement of standards (ETAD-H0762-00, ETAD-H0763-00)" and "Crimping condition table". Note 4 : The compatible wire is limited to UL3443 (20 AWG) or UL1007 (22 AWG). Note 5 : The compatible wire is limited to UL1007 (22 to 24 AWG) or UL1430 (24 to 26 AWG). 10 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) BCrimping ■Items required prior to start crimping The work-related documents shown below are required before starting the harness connections. (The ● mark shows the document required.) When the documents shown below are not available, ask our sales personnel to provide them. Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Description Automatic Hand Crimping Crimping Machine Tool Remarks When purchasing main press machine unit, it is bundled. (1) Main unit of crimping machine Explanation of main press instruction manual machine unit ● − (2) Applicator Spare Parts Identification Explanation for Applicator installation ● − (3) Crimp Conditions Standard values of : Crimp height ; Tensile strength ● − (4) Crimp Quality Standards Various standards for crimping conditions ● − (5) Operating lnstructions for Hand Tool Inspection items of : Crimp height ; Tensile strength ; and others − ● When purchasing Hand Tool, it is bundled. ● ● Ask our sales personal to provide them. (6) Harness Procedure Manual DF62 series : ETAD-H0593 Harness procedure DF62W series : ETAD-H0760 When purchasing Applicator, it is bundled. ■Tools When crimping work is applied to our contacts, the tool designated by Hirose should be used. Crimping work by using tools other than as designated must not be done because it may result in contact failure, disconnection of cable, etc. *The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual befor implementing the work. ■Applicable electric wires Check that the electric wire to be used is in the range of application. If you intend to use an electric wire other than the recommended one, ask our sales personnel. [Precautions] ・Electric wires that are applicable for crimping connectors shall, principally, be the tin-plated stranded softcopper wire. ・Crimping of electric wires wherein single wires, polyester yarns, etc., exist and crimping of tin-coated wires should be avoided. ・Avoid crimping two electric wires together. ・The setting values of crimp height (Note 1) may vary between tin-plated and gold-plated terminals even if the same electric wires are used. ・The setting values of crimp height (Note 1) may vary depending on the difference in the core wire configuration even if the computed cross-sectional area is the same. Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 11 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) ■Straight pin Header B 2.6 A □0.5 *13 pos. shown as an example. Cavity No. C P=2 Contact No.1 marking Contact No. marking P=2.2 Unit : mm Part No. HRS No. No. of Contacts A B 13 24 11.5 14.5 8.8 10.8 DF62-13P-2.2DSA(**) 544-0582-0 ** DF62-24P-2.2DSA(**) 544-0584-0 ** [Specification No.] ** None : Tin plating (01) : Gold plating C Tin plating Gold plating 11.8 ✓ ―― 13.8 ✓ ―― Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 1 : This product is sold per tray (13pos : 100pcs/tray, 24pos : 80pcs/tray), please place orders by tray unit. Note 2 : Please contact to Hirose representative if you have request for Gold plating type of unreleased pin-pos. ●Recommended PCB layout (Recommended thickness t=1.6mm) [13 pos] [24 pos] 4.4±0.05 8.8±0.05 P=2.2±0.05 13 0.8 +0 − 0 .1 P=2.2±0.05 24 ∞Ø P=2±0.05 P=2±0.05 ∞Ø P=2.2±0.05 Outline of the connector 8±0.05 6±0.05 Outline of the connector 6.6±0.05 0.8 +0 − 0 .1 P=2.2±0.05 6.6±0.05 ■Right Angle pin Header C *13 pos. shown as an example. A Cavity No. Contact No.1 marking P=2.2 t=0.47 2.4 3.6 B P=2 Contact No. marking □0.5 Unit : mm Part No. DF62-13P-2.2DS(**) DF62-24P-2.2DS(**) HRS No. No. of Contacts A B 544-0581-0 ** 544-0583-0 ** 13 24 11.5 15.4 12.9 14.9 C Tin plating Gold plating 19.5 ✓ ―― 23.5 ✓ ✓ [Specification No.] ** None : Tin plating (01) : Gold plating Note 1 : This product is sold per tray (100pcs/tray), please place orders by tray unit. Note 2 : Please contact to Hirose representative if you have request for Gold plating type of unreleased pin-pos. [13 pos] [24 pos] 4.4±0.05 8.8±0.05 P=2.2±0.05 4.145±0.05 1.945±0.05 P=2.2±0.05 P=2.2±0.05 3.045±0.05 6.6±0.05 Ø3± 0.05 24∞ Ø0.9 +0.1 −0 P=2±0.05 −0 8±0.05 Ø0.9 +0.1 9.45±0.05 13∞ P=2±0.05 7.45±0.05 6±0.05 ●Recommended PCB layout (Recommended thickness t=1.6mm) Ø3± 0.05 Outline of the connector Outline of the connector 12 P=2.2±0.05 3.045±0.05 6.6±0.05 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) P=2.2 ■Straight pin Header (Water proof type) Cavity No. *9 pos. shown as an example. P=2.2 Contact No1. marking B 2.85 15.5 A □0.5 Unit : mm Unit : pcs Part No. DF62WZ-9P-2.2DSA(**) HRS No. 544-1050-0 ** No. of Contacts 9 B Tray packaging Tin plating Gold plating 12.1 200 ✓ ✓ A 12 ●Recommended PCB layout (Recommended thickness t=1.6mm) [9 pos] Ø1. 8 −+00.1 .1 +0 −0 0.8 Ø 9∞ Outline of the connector P=2.2±0.05 P=2.2±0.05 P=2.2±0.05 P=2.2±0.05 5.05±0.05 4.5±0.05 ■Waterproof pin Ø17 CAV No. Ø16.5 Part No. HRS No. DF62W-WP 544-1014-6 29 (Waterproof surface) 30 Ø16.5 30 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 1 : Please place orders by tray unit. [Specification No.] ** (20) : Tin plating (50) : Gold plating HRS Logo Note 1 : This product is sold per pack (100pcs/pack), please place orders in full pack. Note 2 : In case of using without inserting crimp contact, fill the terminal hole of socket and plug with a waterproof pin. 13 DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Precautions 14 1. Recommended soldering conditions ■ Soldering profile when using an automatic soldering device Soldering temperature : 260℃ ; Soldering time: no more than 10 seconds ■ Hand soldering conditions Temperature of soldering iron : 300℃ , soldering time : no more than 3 seconds 2. Cleaning Conditions Please refer to the "Wire-to-Board Connector Guide". Cleaning with IPA is allowed. (Other cleaning agents are not recommended due to the fact that it may change the push/pull feeling. Please contact us when you use other cleaning agents. ) 3. Important notes 1. Caution is required for mating and un-mating the connector without it being mounting on a PCB. Doing so can damage or deform the contacts. 2. During hand soldering, do not apply excess amounts flux which can migrate on to the connector. 3. This product may have a slight differences in color depending on the production lot. This difference does not have any influence on the performance. 4. Please refer to “DF62 Series mating and unmating Procedure Document (ETAD-H0599)” and “DF62W Series mating and unmating Procedure Document (ETAD-H0761)” for points in handling regarding mating operations. 4. Handling instructions Please refer to the “Wire-to-Board Connector Guide”. DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 15 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF62 Series / DF62W Series●2 × 2.2mm Pitch, Wire-to-Wire Connectors for Small Spaces (UL, C-UL Listed) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 05/2019. Contents are subject to change without notice for the purpose of improvements.
DF62W-ep2226pcfA 价格&库存
很抱歉,暂时无法提供与“DF62W-ep2226pcfA”相匹配的价格&库存,您可以联系我们找货
