EBDM-6-06-2.0-S-RA-1
    SAMTEC(申泰)
EBDM-6-06-2.0-S-RA-1 数据手册
HIGH-SPEED BACKPLANE CONNECTOR & CABLE SYSTEMS (2.00 mm) .0787" PITCH 64 FEATURES & BENEFITS ExaMAX® High-Speed Backplane System ExaMAX® High-Speed Backplane Cable Assemblies • Meets a variety of industry specifications • 30 & 34 AWG Eye Speed® Ultra Low Skew Twinax Cable offers improved signal integrity, increased flexibility and routability • Exceeds OIF CEI-28G-LR specification for 28 Gbps standards • 24 - 72 pair designs (4 and 6 pairs; 6, 8, 10 and 12 columns) • Wafer design includes one sideband signal per column • Press-fit tails provide a reliable electrical connection • PCIe® 6.0/CXL™ 3.1 capable Staggered Differential Pair Design Two Reliable Points of Contact with a 2.4 mm Wipe • Highly customizable with modular flexibility • Reduce costs due to lower layer counts • PCIe® 6.0/CXL™ 3.1 capable • Eye Speed® Thinax™ ultra performance twinax cable version in development Shielded Wafer Design Reduces Crosstalk Traditional, Coplanar and Direct Mate Orthogonal In Development: 8 Pairs for Greater Design Flexibility KEY SPECIFICATIONS SERIES INSULATOR MATERIAL CONTACT MATERIAL EBTM/EBTF/EBDM Liquid Crystal Polymer Copper Alloy EPTT/EPTS High Temperature Thermoplastic Copper Alloy EBCM/EBCF Liquid Crystal Polymer Copper Alloy PLATING Sn or Au over 50 µ" (1.27 µm) Ni Sn or Au over 50 µ" (1.27 µm) Ni Au over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE CURRENT RATING VOLTAGE RATING LEAD-FREE SOLDERABLE -55 °C to +105 °C 4 A per pin 150 VAC Yes -55 °C to +105 °C 14.1 A per pin 150 VAC Yes -40 °C to +105 °C 3.6 A per pin 125 VAC N/A PCI-SIG®, PCI Express® and the PCIe® design marks are registered trademarks and/or service marks of PCI-SIG. F-224 (Rev 20DEC23) samtec.com/ExaMAX Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 64 (2.00 mm) .0787" PITCH • RIGHT-ANGLE SOCKET & DIRECT-MATE ORTHOGONAL EBTF - NO. OF PAIRS PER COLUMN - –4 - COLUMNS –06, –08, –10, –12 = 4 Pairs - –2.0 EBTF-RA - RA - 1 - PLATING - GUIDANCE –S = (2.0 mm) .0787" (-12 column only available in -6 pairs) –6 = 6 Pairs COLUMN PITCH (Leave Blank for no Guidance) = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on tails KEYING (Only with –L or –R Guidance; Leave Blank for no Keying) –L –A thru –H = Left Guidance = Position of Flat on Key (See Table) –R = Right Guidance D A Board Mates: EBTM, EBDM-RA (3.95) .156 DIA E B Cable Mates: EBCM (10.40) .409 (4.60) .181 (7.30) .287 C KEYING (-RA) –L / –R B –A –B A A H C B –C H G C D E F B A H G C D E F B –D –E –F –G A A A A H G C D E F B H G C D E F B H G C D E F B –H H G C D E F B A H G C D E F G D E F B D E (18.85) .742 NO. OF PAIRS PER COLUMN –4 (22.50) .886 (28.40) 1.118 (17.90) .705 –6 (29.70) 1.169 (35.60) 1.402 (25.10) .988 NO. OF COLUMNS A C –06 (12.90) .508 –08 (16.90) .665 (22.85) .900 –10 (20.90) .823 (26.85) 1.057 –12 (24.90) .980 (30.85) 1.215 View complete specifications at: samtec.com?EBTF-RA EBDM - PAIRS –6 = 6 Pairs - COLUMNS –06, –08, –10, –12 - 2.0 - - RA - 1 - PLATING –S –G = Guide Pin (15.00) .591 (32.40) 1.276 Board Mates: EBTF-RA ExaMAX is a registered trademark of AFCI. ® SCREW MOUNT (Leave Blank for no Screw Mount) –S = Screw Mount A (4.00) .157 (2.20) .087 E D C (2.60) .102 (10.00) .394 (39.30) 1.547 Notes: Some lengths, styles and options are non-standard, non-returnable. - (Leave Blank for no Pin) = 30 µ" (0.76 µm) Gold on contact area, Matte Tin on tails EBDM-RA Cable Mates: EBCF GUIDANCE B COLUMNS A B C (without – G) D (with – G) E –06 (16.15) .636 (10.00) .394 (15.00) .591 (20.65) .813 (8.00) .315 –08 (20.15) .793 (14.00) .551 (19.00) .748 (24.65) .970 (12.00) .472 –10 (24.15) .951 (18.00) .709 (23.00) .906 (28.65) 1.128 (16.00) .630 –12 (28.15) 1.108 (22.00) .866 (27.00) 1.063 (32.65) 1.285 (20.00) .787 View complete specifications at: samtec.com?EBDM-RA samtec.com/ExaMAX F-224 (Rev 20DEC23) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
EBDM-6-06-2.0-S-RA-1 价格&库存
很抱歉,暂时无法提供与“EBDM-6-06-2.0-S-RA-1”相匹配的价格&库存,您可以联系我们找货
  • 30+508.8005130+66.14242
