F31FSS-03V-KX
F31FSS-03V-KX
    JST
    P=3.81mm
    1X3P 3.81MM
F31FSS-03V-KX 数据手册
JFA CONNECTOR J300 SERIES 3.81, 5.08, 5.4 mm pitch/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ・Current rating : AC/DC JFA CONNECTOR/J300 SERIES No. of circuits 1 2 3 4 5 6 8 9 10 12 16 20 40 #14 15.0 13.5 12.25 11.25 10.5 9.75 9.0 8.5 8.5 8.25 8.0 8.0 7.5 #16 14.0 13.5 12.25 11.25 10.5 9.75 9.0 8.5 8.5 8.25 8.0 8.0 7.5 #18 11.5 11.25 10.5 10.0 9.5 9.0 8.25 8.0 8.0 7.75 7.5 7.25 6.25 Wire size (AWG) #20 #22 9.5 8.0 9.25 7.5 8.5 7.0 8.0 6.5 7.5 6.25 7.0 6.0 6.5 5.5 6.25 5.25 6.25 5.25 6.0 5.0 6.0 4.75 6.0 4.5 5.25 4.0 Unit: A #24 6.5 6.25 5.75 5.5 5.25 5.0 4.5 4.5 4.5 4.0 4.0 4.0 3.5 #26 5.75 5.5 5.0 4.75 4.5 4.25 3.75 3.75 3.75 3.5 3.5 3.5 3.0 #28 4.75 4.5 4.1 4.0 4.0 3.75 3.25 3.25 3.25 3.0 3.0 2.75 2.5 ・ Voltage rating: J310/J340/J380 series(3.81 mm pitch)250 V AC/DC J320/J350 series(5.08 mm pitch)600 V AC/DC ・ Temperature range: -55℃ to + 105℃ (including temperature rise in applying electrical current) ・ Contact resistance: Initial value/ 5 mΩ max. After environmental tests/ 10 mΩ max. ・ Insulation resistance: 1,000 mΩ min. ・ Withstanding voltage: J310/J340/J380 series(3.81 mm pitch)1,500 VAC/minute J320/J350 series(5.08 mm pitch)2,200 VAC/minute ・ Applicable wire: AWG #28 to #14 ・ Applicable PC board thickness: 1.6 to 2.4 mm J300 SERIES/J310S Connectors for signal circuit or power supply circuit, applicable to the factory automation, heavy electric machinery, and other industrial equipment in general. In spite of the various kinds of housings available, their contacts are designed to be common. The applicable tooling can be standardized. J300 SERIES/J310D* Refer to the page of each product for the specifications of the ・D  ouble-spring construction ・ Housing lances ・ Clear click feeling J330 series and common type(J350D, J360T). * In using the products,refer to “Handling Precautions for Terminals and Connectors” described on our website (Technical documents of Product information page). * Dimensional unit: mm * RoHS2 Compliance * Contact JST for details. Standards J300 SERIES/J310M ® ® :Recognized E60389 :R50133261 ® ® ® ® ® ® ® ® J300 SERIES/J320S 1 J300 SERIES/J320M JFA CONNECTOR/J300 SERIES J300 series products line - up 3.81 mm pitch , Voltage rating 250 V AC/DC Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type Panel mounting type Screw type JFA CONNECTOR/J300 SERIES J310S Single-row type No. of circuits 3, 4, 5, 6, 8,10 3, 4, 5, 6, 8,10 3, 4, 5, 8,10 3, 4, 5, 8,10 B A J310D Dual-row type B B B J300 SERIES/J310S B A 6, 8,10,12,16, 20 B A A 6, 8,10,12,16, 20 6, 8,10,12,16, 20 6, 8,10,12,16, 20 B B A [Line pitch 7.62 mm] B J300 SERIES/J310D A J-3 10 A B No. of circuits 6 6 J340F Four-row type J-3 40 [Line pitch 5.08 mm] D C B J300 SERIES/J310M A No. of circuits 5.4 mm pitch , Voltage rating 600 V AC/DC Panel mounting type A X 1 B 3 Y 2 5 1 2 3 4 5 6 18 19 20 21 22 23 13 7 6 22 J-3 80 J-3 4 23 Wire-to-wire Type 17 12 No. of circuits 12, 20 11 [Line pitch 5.08 mm] (Thin type) 6,12, 20 A J310M Dual-row module type A A B No. of circuits B A A [Line pitch 5.08 mm] J380 Dual-row type Housing lock type 7 Screw type 11 21 12 20 19 18 17 13 17 J-38 0 13 12 18 19 20 21 22 Housing lock type 23 11 7 40 6 5 4 3 2 1 J330 A B 20, 40 [Line pitch 7.7 mm] No. of circuits J300 SERIES/J320S 30, 40 2 J300 SERIES/J320M JFA CONNECTOR/J300 SERIES J300 series products line - up 5.08 mm pitch , Voltage rating 600 V AC/DC Type Wire-to-board Top entry type Wire-to-wire Side entry type Free hanging type Panel mounting type Screw type J-3 20 J-3 20 Single-row type J-3 20 J300 SERIES/J310S J320S Housing lock type J-3 20 2, 3, 4, 5, 6 2, 3, 4, 5, 6 1, 2, 3, 4 1, 2, 3, 4 12 12 4 1 No. of circuits 10 9 8 7 6 5 3 4 2 1 1 2 2 3 J-35 0 J350D Dual-row SERIES/J310D type J300 A 3 4 B J-3 4 A 5 5 B J-3 1 3 4 5 1 2 3 10 4 9 8 7 5 J-3 50 6 5 4 3 2 B 1 A 12, 20 J320M Dual-row module type 4,12, 20 B J-3 20 [Line pitch 7.62 mm] A J300 SERIES/J310M J-3 20 No. of circuits 2 J-3 20 [Line pitch 5.08 mm] B B A J-3 20 B A A A B No. of circuits 6,10,12 6, 8,10,12 J320T J300 SERIES/J320S Triple-row 6,12 6,12, 20 J-3 20 module type [Line pitch 7.62 mm] No. of circuits 9 Dual-row common type (J350D) J300 SERIES/J320M Triple-row common type (J360T) Common type (Line pitch 5.08 mm) No. of circuits J300 SERIES/J320T 3 12 (Line pitch 6.5 mm) 9,18, 24 JFA CONNECTOR/J300 SERIES Receptacle contact Model Strip contact SF3F-002 (*) -P2.0 SF3F-01 (*) -P2.0 SF3F-41 (*) -P2.0 SF3F-71 (*) -P2.0 17.9 (18.4/2L) 3,700 1,000 3,700 1,000 3,200 1,000 3,200 1,000 Material and Finish (9.3) (2.5 3.0/2L) Q’ty reel box (Loose piece) JFA CONNECTOR/J300 SERIES 17.9 (18.4/2L) (5.3 5.8/2L) Applicable wire No. Insulation O.D. (mm) Loose piece Size mm2 AWG# 0.8~1.4 BF3F-002 (*) -P2.0 S 0.08~0.20 28~24 M 0.20~0.50 24~20 1.2~2.6 BF3F-01 (*) -P2.0 L 0.50~1.25 20~16 1.8~2.8 LF3F-41 (*) -P2.0 2L 1.25~2.0 16~14 2.4~3.4 BF3F-71 (*) -P2.0 Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) RoHS2 compliance Note: Finish (*) : GF.....Nickel-undercoated, 0.38 µm selective gold-plated GFA...Nickel-undercoated, 0.38 µm selective gold-plated (A type) GI.......Nickel-undercoated, 0.76 µm selective gold-plated GIA.....Nickel-undercoated, 0.76 µm selective gold-plated (A type) T.........Tin-plated (reflow treatment) Tab contact Applicable wire Model No. Insulation O.D. (mm) Strip contact Loose piece Size mm2 AWG# 0.8~1.4 SF3M-002 (*) -M2.0N BF3M-002 (*) -M2.0N S 0.08~0.20 28~24 1.2~2.6 SF3M-01 (*) -M2.0N BF3M-01 (*) -M2.0N M 0.20~0.50 24~20 1.8~2.8 0.50~1.25 20~16 SF3M-41 (*) -M2.0N LF3M-41 (*) -M2.0N L 2.4~3.4 16~14 SF3M-71 (*) -M2.0N BF3M-71 (*) -M2.0N 2L 1.25~2.0 24.7 (25.2/2L) 3,500 1,000 3,500 1,000 3,300 1,000 3,200 1,000 J300 SERIES/J310S 24.7 (25.2/2L) Material and Finish (5.3 5.8/2L) (2.5 3.0/2L) Q’ty reel box (Loose piece) Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated tin-plated (reflow treatment) (11.4) RoHS2 compliance Note: 1. Finish (*):GF...Nickel-undercoated, 0.38 µm selective gold-plated GI ....Nickel-undercoated, 0.76 µm selective gold-plated T......Tin-plated (reflow treatment) Crimping machine, Applicator Strip contact Model No. SF3F-002 (*) -P2.0 SF3M-002 (*) -M2.0N SF3F-01 (*) -P2.0 SF3M-01 (*) -M2.0N SF3F-41 (*) -P2.0 SF3M-41 (*) -M2.0N Applicator Crimping machine Crimp applicator Dies Crimp applicator with dies Loose piece Hand tools J300 SERIES/J310D MK/SF3F/M-002-20 APLMK SF3F/M002-20 YRK-8821 AP-K2N MKS-L SF3F-71 (*) -P2.0 SF3M-71 (*) -M2.0N ・Extraction tool for J300 series: EJ-JFAJ3 selective selective selective selective gold-plated gold-plated (A type) gold-plated gold-plated (A type) YRF-881 LF3F-41 (*) -P2.0 LF3M-41 (*) -M2.0N MK/SF3F/M-41-20 APLMK SF3F/M41-20 YRK-8801 Note: Finish (*) : GF .....Nickel-undercoated, 0.38 µm GFA...Nickel-undercoated, 0.38 µm GI ......Nickel-undercoated, 0.76 µm GIA....Nickel-undercoated, 0.76 µm T........Tin-plated (reflow treatment) YRF-882 BF3F-01 (*) -P2.0 BF3M-01 (*) -M2.0N MK/SF3F/M-01-20 APLMK SF3F/M01-20 YRK-8811 MK/SF3F/M-71-20 APLMK SF3F/M71-20 YRK-1071 Hand tools BF3F-002 (*) -P2.0 BF3M-002 (*) -M2.0N YRF-880 BF3F-71 (*) -P2.0 BF3M-71 (*) -M2.0N YRF-1070 YRF-1071 Note: Finish (*): GF......Nickel-undercoated, 0.38 µm selective gold-plated GFA ...Nickel-undercoated, 0.38 µm selective gold-plated (A type) GI .......Nickel-undercoated, 0.76 µm selective gold-plated GIA ....Nickel-undercoated, 0.76 µm selective gold-plated (A type) T ........Tin-plated (reflow treatment) J300 SERIES/J310M ・ Special extraction tool for J300 series: For receptacle only ...EJ-JFAJ3R, For tab only ...EJ-JFAJ3T ・ Refer to the page of "Crimping tools " for details of YRK series hand crimping tools that uses a strip contact. Recognition mark • Plating of the contact Each contact has a marking on its side so that the type or thickness of the plating is recognized. 2 ... gold-plated 0.38 µm thickness 2 ... gold-plated 0.38 µm thickness (A type) 3 ... gold-plated 0.76 µm thickness 3 ... gold-plated 0.76 µm thickness (A type) 5 ... tin-plated (reflow treatment) • Common marking on the contact and its application tools In order to avoid incorrect combination of the hand crimp tools or extraction tools and the contacts, the series name (for example J-3) and wire range mark (S, M, L, 2L) are shown on both the tools and the contacts. J-3 S.....AWG #28 ~ #24 M....AWG #24 ~ #20 L.....AWG #20 ~ #16 2L...AWG #16 ~ #14 Receptacle contact ST J Tab contact T2 JS 2 Indication of the plating J300 SERIES/J320S Indication of the plating Receptacle contact Tab contact J-3 L Wire range mark J3 L Wire range mark Series name Series name 4 J300 SERIES/J320M JFA CONNECTOR/J300 SERIES Keying plug Model No. J3KP-VS 3.6 RoHS2 compliance 2.5 4.5 25 Material and Finish Glass-filled PBT, UL94V-0, white 2.9 J300 SERIES/J310S Tab contact (Cutting jig) Model No. J300 SERIES/J310D J300 SERIES/J310M J300 SERIES/J320S J300 SERIES/J320M J300 SERIES/J320T 5 CT-JFAJ3A Note: Unlisted in UL/TÜV J300 SERIES/J310S Assembly layout < Top entry type > < Side entry type > (8.6) J300 SERIES/J310D (28.9) (28.4) (10.1) Wire-to-board < Free hanging type / Panel mounting type > J300 SERIES/J310M (40.6) (8.6) Wire-to-wire J300 SERIES/J320S Receptacle housing No. of Keying circuits A 3.81 7.15 6.55 3 4 5 B 6 16.4 Series name X JST J-3 1 2 Circuit No. 3 4 8 22.8 Keying No. 10 X Y X Y X Y X Y X Y X Y 5 Model No. F31FSS-03V-KX F31FSS-03V-KY F31FSS-04V-KX F31FSS-04V-KY F31FSS-05V-KX F31FSS-05V-KY F31FSS-06V-KX F31FSS-06V-KY F31FSS-08V-KX F31FSS-08V-KY F31FSS-10V-KX F31FSS-10V-KY Dimensions (mm) A B C Q’ty /bag 7.62 16.70 26.62 200 7.62 16.70 26.62 200 11.43 20.51 30.43 200 11.43 20.51 30.43 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 19.05 28.13 38.05 200 19.05 28.13 38.05 200 26.67 35.75 45.67 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 34.29 43.37 53.29 100 J300 SERIES/J320M Material and Finish J300 SERIES/J320T C Glass-filled PBT, UL94V-0, black RoHS2 compliance J300 SERIES/J330 6 J300 SERIES/J310S Tab housing (Free hanging type) No. of Keying circuits C 8.78 9.35 12.7 9.35 X X J300 SERIES/J310D 3.81 X 4 Y X Y X 8 B 5.0 Y 5 Keying No. A F31MSF-03V-KX F31MSF-03V-KY F31MSF-04V-KX F31MSF-04V-KY F31MSF-05V-KX F31MSF-05V-KY F31MSF-08V-KX F31MSF-08V-KY F31MSF-10V-KX F31MSF-10V-KY X 3 Y X 10 Model No. Y Dimensions (mm) A B C Q’ty /bag 7.62 21.62 25.57 200 7.62 21.62 25.57 200 11.43 25.43 29.38 200 11.43 25.43 29.38 200 15.24 29.24 33.19 200 15.24 29.24 33.19 200 26.67 40.67 44.62 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 34.29 48.29 52.24 100 33.6 4.0 Material and Finish Series name J-310 Glass-filled PBT, UL94V-0, black Circuit No. RoHS2 compliance 3 2 1 J300 SERIES/J310M Tab housing (Panel mounting type) No. of circuits Keying E -φ 2 3.81 8.78 9.35 12.7 9.35 3 X 5 3. X D 5 5.0 J300 SERIES/J320S A Keying No. 8 B 3 2 1 Circuit No. Connector outline 4-R0.5(MAX) J300 SERIES/J320M Panel layout J300 SERIES/J320T J300 SERIES/J330 7 10 Y X Y X Y X Y X Y F31MSP-03V-KX F31MSP-03V-KY F31MSP-04V-KX F31MSP-04V-KY F31MSP-05V-KX F31MSP-05V-KY F31MSP-08V-KX F31MSP-08V-KY F31MSP-10V-KX F31MSP-10V-KY A Dimensions (mm) B C D E Q’ty /bag 7.62 21.62 22.60 31.00 40.00 200 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 200 11.43 25.43 26.40 34.50 43.50 200 15.24 29.24 30.20 38.00 47.00 200 15.24 29.24 30.20 38.00 47.00 200 26.67 40.67 41.60 50.00 59.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 34.29 48.29 49.20 58.00 67.00 100 Material and Finish Glass-filled PBT, UL94V-0, black 10.3 ±0.3 J-310 D ±0.05 C ±0.3 5.15 ±0.3 4.0 33.6 φ3.6 ±0.1 Series name 4 X Model No. RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. J300 SERIES/J310S Header (Top entry type) No. of Keying circuits X 3.81 4 (1.27) Keying No. 3 9.35 X C A Series name 5 Circuit No. 21.6 6 J-310 8 5 4 3 2 1 (3.175) X Y X Y X Y X Y X Y B03B-F31SK-GGXR B03B-F31SK-GGYR B04B-F31SK-GGXR B04B-F31SK-GGYR B05B-F31SK-GGXR B05B-F31SK-GGYR B06B-F31SK-GGXR B06B-F31SK-GGYR B08B-F31SK-GGXR B08B-F31SK-GGYR B10B-F31SK-GGXR B10B-F31SK-GGYR Dimensions (mm) A B C Q’ty/box 7.62 13.97 21.62 220 7.62 13.97 21.62 220 11.43 17.78 25.43 180 11.43 17.78 25.43 180 15.24 21.59 29.24 160 15.24 21.59 29.24 160 19.05 25.40 33.05 140 19.05 25.40 33.05 140 26.67 33.02 40.67 120 26.67 33.02 40.67 120 34.29 40.64 48.29 100 34.29 40.64 48.29 100 J300 SERIES/J310D Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated J300 SERIES/J310M ±0.05 φ1.1 ±0.1 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. 1.27 Copper foil land 2-φ3.0 (MIN) Through-hole 2-φ2.0 ±0.1 3.175 Y 3.8 10 X Model No. 3.81±0.05 Connector outline ±0.05 B ±0.05 PC board layout Connector mounting side J300 SERIES/J320S Header (Side entry type) 3.8 X Keying No. Series name 7.62 0.82 3 4 5 6 J-310 22.1 8 Circuit No. 10 5 4 3 2 1 Connector outline 7.62±0.05 Copper foil land 2-φ4.0 (MIN) Through-hole 2-φ3.0 ±0.1 3.81 ±0.05 3.81±0.05 X Y X Y X Y X Y X Y X Y Model No. S03B-F31SK-GGXR S03B-F31SK-GGYR S04B-F31SK-GGXR S04B-F31SK-GGYR S05B-F31SK-GGXR S05B-F31SK-GGYR S06B-F31SK-GGXR S06B-F31SK-GGYR S08B-F31SK-GGXR S08B-F31SK-GGYR S10B-F31SK-GGXR S10B-F31SK-GGYR Dimensions (mm) Q’ty/box B C 7.62 15.24 21.62 165 7.62 15.24 21.62 165 11.43 19.05 25.43 135 11.43 19.05 25.43 135 15.24 22.86 29.24 120 15.24 22.86 29.24 120 19.05 26.67 33.05 105 19.05 26.67 33.05 105 26.67 34.29 40.67 90 26.67 34.29 40.67 90 34.29 41.91 48.29 75 34.29 41.91 48.29 75 A J300 SERIES/J320M Material and Finish C 0.82 No. of Keying circuits (3.81) 9.35 10.85 X 3.34 A 3.81 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated J300 SERIES/J320T RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. φ1.1 ±0.1 B ±0.05 PC board layout Connector mounting side J300 SERIES/J330 8 J300 SERIES/J310D Assembly layout 〈 Side entry type 〉 〈 Top entry type 〉 (13.7) J300 SERIES/J310M B A (32.8) B B A (28.4) A B (15.2) Wire-to-board A J300 SERIES/J320S 〈 Free hanging type / Panel mounting type (Screw type, Housing lock type) 〉 Wire-to-wire B B A A J300 SERIES/J320M (13.7) (40.6) Receptacle housing A Line No. 12.23 11.63 5.08 3.81 B A J300 SERIES/J320T B No. of Keying circuits 6 ̶ 8 ̶ 10 ̶ 12 ̶ 16 ̶ 20 ̶ Model No. F31FDS-06V-K F31FDS-08V-K F31FDS-10V-K F31FDS-12V-K F31FDS-16V-K F31FDS-20V-K Dimensions (mm) A B C Q’ty/bag 7.62 16.70 26.62 200 11.43 20.51 30.43 100 15.24 24.32 34.24 100 19.05 28.13 38.05 100 26.67 35.75 45.67 100 34.29 43.37 53.29 100 16.4 22.8 Material and Finish Series name J-3 1 Glass-filled PBT, UL94V-0, black RoHS2 compliance JST 2 Circuit No. 3 4 5 C J300 SERIES/J330 Tab housing (Free hanging type) C Line No. 5.0 14.43 B A A 17.78 5.08 3.81 No. of circuits Keying 6 ̶ 8 ̶ 10 ̶ 12 ̶ 16 ̶ 20 ̶ B Model No. F31MDF-06V-K F31MDF-08V-K F31MDF-10V-K F31MDF-12V-K F31MDF-16V-K F31MDF-20V-K A Dimensions (mm) B C 7.62 21.62 25.57 200 11.43 25.43 29.38 100 15.24 29.24 33.19 100 19.05 33.05 37.00 100 26.67 40.67 44.62 100 34.29 48.29 52.24 100 Material and Finish 4.0 33.6 Glass-filled PBT, UL94V-0, black Series name J-310 3 2 1 9 Circuit No. RoHS2 compliance Q’ty/bag J300 SERIES/J310D Tab housing (Panel mounting type) E Line No. 5.08 D 6 8 B -φ 10 14.43 17.78 A 3.5 2 No. of Keying circuits 12 16 20 3.81 ̶ ̶ ̶ ̶ ̶ ̶ A Dimensions (mm) B C D E Q’ty /bag 7.62 21.62 22.60 31.00 40.00 200 11.43 25.43 26.40 34.50 43.50 100 15.24 29.24 30.20 38.00 47.00 100 19.05 33.05 34.00 42.00 51.00 100 26.67 40.67 41.60 50.00 59.00 100 34.29 48.29 49.20 58.00 67.00 100 J300 SERIES/J310M Glass-filled PBT, UL94V-0, black B 5.0 F31MDP-06V-K F31MDP-08V-K F31MDP-10V-K F31MDP-12V-K F31MDP-16V-K F31MDP-20V-K A Material and Finish 4.0 33.6 Model No. RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Series name J300 SERIES/J320S Circuit No. J-310 3 2 1 15.3 ±0.3 7.65 ±0.3 D ±0.05 C ±0.3 φ 3.6 4R0 Connector outline ± 0.1 .5 ( J300 SERIES/J320M MA X) Panel layout Tab housing (Panel mounting Housing lock type) No. of Keying circuits E 5.08 6 14.43 17.5 14.43 7 B 3.81 A 10.3 12 Line No. A B 12.7 10.5 5 4 3 2 1 2.25 ±0.1 C D E Q’ty /bag 7.62 21.62 22.15 26.65 26.33 100 19.05 33.05 33.55 38.05 37.76 100 34.29 48.29 48.80 53.30 53.00 80 J300 SERIES/J320T Material and Finish D ±0.1 C ±0.1 J300 SERIES/J330 14.7 ±0.1 6 B 4-R 0.3max. 4-R 0.8max. 10.8 ±0.1 7 1.95 ±0.1 33.6 8 ̶ F31MDPL-06V-K F31MDPL-12V-K F31MDPL-20V-K Dimensions (mm) RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Unlisted in UL/TÜV. Series name J-310 9 ̶ A Glass-filled PBT, UL94V-0, black Circuit No. 10 20 ̶ Model No. Panel layout (Panel thickness : 1.6~2.5 mm) 10 J300 SERIES/J310D Header (Top entry type) A 5.08 3.81 B 14.43 J300 SERIES/J310M (1.27) Line No. 5.08 C A Series name No. of circuits Keying 6 ̶ 8 ̶ 10 ̶ 12 ̶ 16 ̶ 20 ̶ Model No. B06B-F31DK-GGR B08B-F31DK-GGR B10B-F31DK-GGR B12B-F31DK-GGR B16B-F31DK-GGR B20B-F31DK-GGR Dimensions (mm) A C B Q’ty/box 7.62 13.97 21.62 132 11.43 17.78 25.43 108 15.24 21.59 29.24 96 19.05 25.40 33.05 84 26.67 33.02 40.67 72 34.29 40.64 48.29 60 Material and Finish 21.6 Circuit No. Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated J-310 5 4 3 2 1 RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. 3.8 3.81 (3.175) J300 SERIES/J320S φ1.1 ±0.1 1.27 ±0.05 5.08 ±0.05 Copper foil land 2-φ3.0(MIN) Through-hole 2-φ2.0 ± 0.1 3.175 3.81±0.05 Connector outline ±0.05 B ±0.05 J300 SERIES/J320M PC board layout Connector mounting side Header (Side entry type) 3.8 7.62 3.81 0.82 5.08 14.43 15.93 J300 SERIES/J320T Circuit No. J-310 25.91 Series name J300 SERIES/J330 5 4 3 2 1 C Connector outline Through-hole 2-φ3.0 ±0.1 0.82 3.81±0.05 7.62±0.05 Copper foil land 2-φ4.0 (MIN) 3.81±0.05 3.81±0.05 B±0.05 φ1.1±0.1 PC board layout Connector mounting side 11 No. of circuits Keying 6 ̶ 8 ̶ 10 ̶ 12 ̶ B 3.34 (3.81) A A 3.81 16 ̶ 20 ̶ Line No. Model No. S06B-F31DK-GGR S08B-F31DK-GGR S10B-F31DK-GGR S12B-F31DK-GGR S16B-F31DK-GGR S20B-F31DK-GGR Dimensions (mm) A B C Q’ty/box 7.62 15.24 21.62 88 11.43 19.05 25.43 72 15.24 22.86 29.24 64 19.05 26.67 33.05 56 26.67 34.29 40.67 48 34.29 41.91 48.29 40 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. J300 SERIES/J310M Assembly layout When mating with J310M receptacle J300 SERIES/J320S (16.2) (16.2) A B When mating with J310S receptacle modular (28.4) (28.4) Top entry type B J300 SERIES/J320M B A A Wire-to-board (32.8) (32.8) A B A B J300 SERIES/J320T A (17.7) B (17.7) Side entry type J300 SERIES/J330 12 J300 SERIES/J310M Receptacle housing 7.62 Line No. 3.81 6 J300 SERIES/J320S Keying Model No. Q’ty/bag XX F31FMS-06V-KXX F31FMS-06V-KYY F31FMS-06V-KXY 100 YY XY 14.77 14.17 A B 7.62 No. of circuits 100 100 Material and Finish Glass-filled PBT, UL94V-0, black (16.7) 16.4 22.8 RoHS2 compliance Keying No. Series name XX J-3 JST 1 2 3 J300 SERIES/J320M Circuit No. (21.42) (26.62) A 16.97 X 7.62 X 21.62 3.81 B X X J300 SERIES/J320T Keying No. (1.27) 7.62 Header (Top entry type) No. of circuits Model No. Q’ty/box XX B06B-F31MK-GGXXR B06B-F31MK-GGYYR B06B-F31MK-GGXYR 132 YY 6 XY Line No. 7.62 Keying Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 21.6 J-310 1 3.8 φ1.1±0.1 (3.175) Copper foil land 2-φ3.0(MIN) 3.81 1.27 ±0.05 7.62 ±0.05 3 2 132 Material and Finish Series name Circuit No. 132 J300 SERIES/J330 Through-hole 2-φ2.0±0.1 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. Conector outline 3.81±0.05 3.175±0.05 13.97 ±0.05 PC board layout Connector mounting side Header (Side entry type) 18.47 16.97 X 7.62 X X X 25.91 Copper foil land 2-φ4.0 (MIN) 7.62 ±0.05 3 2 1 Through-hole 2-φ3.0 ±0.1 3.81 ±0.05 21.62 3.81 ±0.05 3.81 φ1.1 ±0.1 ±0.05 15.24 ±0.05 PC board layout Connector mounting side 13 Model No. Q’ty/box XX S06B-F31MK-GGXXR S06B-F31MK-GGYYR S06B-F31MK-GGXYR 88 YY 88 88 Material and Finish Line No. Connector outline J-310 Keying XY B 3.34 6 Series name Circuit No. No. of circuits 3.81 0.82 A Keying No. 7.62 3.8 (3.81) 3.81 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. J300 SERIES/J310M Keying J310M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) J300 SERIES/J320S XX-Keying Indication of keying Y Line B X Y Line A Y Line B Indication of keying Y Line A Y Indication of keying Y X X X Line B X Line A Key rib X Key rib Key rib J300 SERIES/J320M XY-Keying YY-Keying List of combinations With the combination of the J310M headers and the J310M/J310S (3 circuits) receptacle housings, the following modular combinations are possible. J300 SERIES/J320T Header Receptacle housing Top entry type X X F31FSS-03V-KX Single-row 3 circuits (J310S) J300 SERIES/J330 Single-row X-Keying B03B-F31SK-GGXR X-Keying 3 circuits (J310S) S03B-F31SK-GGXR Y-Keying F31FSS-03V-KY B03B-F31SK-GGYR S03B-F31SK-GGYR X X Dual-row 6 circuits (J310M) A XX-Keying B06B-F31MK-GGXXR Dual-row 6 circuits (J310M) XX-Keying S06B-F31MK-GGXXR YY-Keying Y F31FMS-06V-KYY B Y YY-Keying X F31FMS-06V-KXX X XX-Keying Y Y-Keying Y Y-Keying Y Dual-row 6 circuits (J310M) X-Keying Y Single-row 3 circuits (J310S) Side entry type B06B-F31MK-GGYYR J-3 10 YY-Keying B A S06B-F31MK-GGYYR A X Y F31FMS-06V-KXY X XY-Keying Y B XY-Keying XY-Keying B06B-F31MK-GGXYR S06B-F31MK-GGXYR 14 J300 SERIES/J320S Assembly layout • Normal type (8.6) (28.9) (10.1) J300 SERIES/J320M (28.4) Wire-to-board • Reverse type J300 SERIES/J320T (9.1) (28.9) J300 SERIES/J330 • Single circuit • 2 to 4 circuits (40.6) 15 (8.6) (10.2) Wire-to-wire (40.6) J300 SERIES/J320S Receptacle housing • Single circuit No. of Keying circuits (C) X 1 JST Keying No. 2 22.8 Circuit No. 1 3 4 B 8.9 5 6 X Y X Y X Y X Y X Y X Y Model No. F32FSS-01V-KX F32FSS-01V-KY F32FSS-02V-KX F32FSS-02V-KY F32FSS-03V-KX F32FSS-03V-KY F32FSS-04V-KX F32FSS-04V-KY F32FSS-05V-KX F32FSS-05V-KY F32FSS-06V-KX F32FSS-06V-KY Dimensions (mm) A B C ̶ Q’ty/bag 9.40 12.00 200 9.40 12.00 200 5.08 14.16 24.08 200 5.08 14.16 24.08 200 10.16 19.24 29.16 200 10.16 19.24 29.16 200 15.24 24.32 34.24 200 15.24 24.32 34.24 200 20.32 29.40 39.32 200 20.32 29.40 39.32 200 25.40 34.48 44.40 100 25.40 34.48 44.40 100 J300 SERIES/J320M ̶ J300 SERIES/J320T Material and Finish • 2 to 6 circuits A Glass-filled PBT, UL94V-0, black 7.15 6.55 5.08 RoHS2 compliance Keying No. Series name X J-3 JST 2 1 Circuit No. J300 SERIES/J330 22.8 16.4 B 3 4 5 C Tab housing (Free hanging type) • Single circuit No. of circuits Keying 1 7 11.6 Keying No. 2 3 5 C B J-320 4 Series name Y X Y X Y X Y (33.6) 4 X Model No. F32MSF-01V-KX F32MSF-01V-KY F32MSF-02V-KX F32MSF-02V-KY F32MSF-03V-KX F32MSF-03V-KY F32MSF-04V-KX F32MSF-04V-KY Dimensions (mm) A B C ̶ Q’ty/bag 13.60 15.60 150 13.60 15.60 150 5.08 19.08 23.03 200 5.08 19.08 23.03 200 10.16 24.16 28.11 200 10.16 24.16 28.11 200 15.24 29.24 33.19 200 15.24 29.24 33.19 200 ̶ Material and Finish Circuit No. Glass-filled PBT, UL94V-0, black 6.4 RoHS2 compliance 11.6 • 2 to 4 circuits 4 Series name J-320 2 8.78 5 B 3 9.35 Keying No. A 33.6 5.08 9.35 12.7 X X C Circuit No. 1 16 J300 SERIES/J320S Tab housing (Panel mounting type) No. of circuits Keying • Single circuit E D X 1 7 X 2 11.6 15.6 11.6 J300 SERIES/J320M Y Y X 3 Keying No. B 5 Y X 4 Y Series name J-320 6.4 4- Connector outline 6.3 ±0.05 1 11.6 Dimensions (mm) B C D A ̶ E Q’ty /bag 11.60 12.60 21.00 28.60 150 11.60 12.60 21.00 28.60 150 5.08 19.08 20.00 28.00 36.83 200 5.08 19.08 20.00 28.00 36.83 200 10.16 24.16 25.00 33.00 41.91 200 10.16 24.16 25.00 33.00 41.91 200 15.24 29.24 30.00 38.00 46.99 200 15.24 29.24 30.00 38.00 46.99 200 ̶ Material and Finish  J300 SERIES/J320T Circuit No. F32MSP-01V-KX F32MSP-01V-KY F32MSP-02V-KX F32MSP-02V-KY F32MSP-03V-KX F32MSP-03V-KY F32MSP-04V-KX F32MSP-04V-KY 2-φ3.6 ±0.1 12.6 ±0.05 (33.6) 4 D ±0.05 C ±0.05 Model No. R0 .5 (M AX ) Panel layout Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. • 2 to 4 circuits E D 5.08 Keying No. A D ±0.05 C ±0.3 10.22 ±0.3 5.11 ±0.3 5 B 4 33.6 8.78 9.35 12.7 3.5 2-φ X X J300 SERIES/J330 Series name Circuit No. J-320 3 2 3.6 1 0.1 (M 0.5 R 4- ) AX ± φ Connector outline Panel layout Tab housing (Panel mounting type Housing lock type) (37.04) 33.95 No. of circuits Keying Model No. Q’ty/bag 4 X F32MSPL-04V-KX 90 Keying No. 8.78 12.4 6 9.35 X X Material and Finish RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Unlisted in TÜV. 5.08 10.5 Series name J-320 4 3 2 22.24 29.24 17 1 4-R 0.4 ) 9.65±0.1 34.25 ±0.1 33.6 12.7 15.24 Circuit No. AX (M Glass-filled PBT, UL94V-0, black Panel layout (Panel thickness:1.6~2.5 mm) J300 SERIES/J320S Header (Top entry type) (1.27) X Keying No. 9.35 X C No. of circuits Keying 2 3 5.08 4 Series name Circuit No. 21.6 5 J-320 4 3 2 X Y X Y X Y X Y B02B-F32SK-GGXR B02B-F32SK-GGYR B03B-F32SK-GGXR B03B-F32SK-GGYR B04B-F32SK-GGXR B04B-F32SK-GGYR B05B-F32SK-GGXR B05B-F32SK-GGYR B06B-F32SK-GGXR B06B-F32SK-GGYR Dimensions (mm) A B C Q’ty/box 5.08 11.43 19.08 240 5.08 11.43 19.08 240 10.16 16.51 24.16 200 10.16 16.51 24.16 200 15.24 21.59 29.24 160 15.24 21.59 29.24 160 20.32 26.67 34.32 140 20.32 26.67 34.32 140 25.40 31.75 39.40 120 25.40 31.75 39.40 120 J300 SERIES/J320M Material and Finish J300 SERIES/J320T Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated (3.175) A φ1.1 ±0.1 Through-hole 2-φ2.0 ±0.1 3.175 RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. 1.27 Copper foil land 2-φ3.0(MIN) ±0.05 5.08 Y 1 3.8 5 6 X Model No. Connector outline 5.08 ±0.05 ±0.05 B J300 SERIES/J330 ±0.05 PC board layout Connector mounting side Header (Side entry type) 7.62 0.82 2 3 10.85 X Keying No. 9.35 X 3.8 5.08 3.34 No. of Keying circuits (3.81) A 4 5 Series name 22.1 6 Circuit No. J-320 3 2 Y X Y X Y X Y X Y S02B-F32SK-GGXR S02B-F32SK-GGYR S03B-F32SK-GGXR S03B-F32SK-GGYR S04B-F32SK-GGXR S04B-F32SK-GGYR S05B-F32SK-GGXR S05B-F32SK-GGYR S06B-F32SK-GGXR S06B-F32SK-GGYR Dimensions (mm) A C B Q’ty/box 5.08 12.70 19.08 180 5.08 12.70 19.08 180 10.16 17.78 24.16 150 10.16 17.78 24.16 150 15.24 22.86 29.24 120 15.24 22.86 29.24 120 20.32 27.94 34.32 105 20.32 27.94 34.32 105 25.40 33.02 39.40 90 25.40 33.02 39.40 90 Material and Finish 1 C Connector outline ±0.05 Copper foil land 2-φ4.0 (MIN) 7.62 4 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. Through-hole 2-φ3.0 ±0.1 0.82 5 X Model No. 3.81 ±0.05 5.08 B ±0.05 φ1.1 ±0.1 ±0.05 PC board layout Connector mounting side 18 J300 SERIES/J320S Header (Side entry type Reverse type) No. of Keying circuits (3.81) A J300 SERIES/J320M 3.8 7.62 (0.82) Series name Connector outline Cooper foil land 2-φ4 (MIN) 7.62 ±0.05 22.1 Type J-320 2 3 C 4 5 0.82 J300 SERIES/J320T R 1 5.08±0.05 Through-hole 2-φ3 ±0.1 φ1.1±0.1 3.81±0.05 B ±0.05 PC board layout Connector mounting side J300 SERIES/J330 19 X 6 X SR05B-F32SK-GGXR SR06B-F32SK-GGXR Q’ty /box 20.32 27.94 34.32 105 25.40 33.02 39.40 90 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Keying No. Circuit No. 5 Dimensions (mm) A C B Material and Finish 10.85 X 9.35 X 3.34 5.08 Model No. RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product 3. Unlisted in TÜV.           J300 SERIES/J320M Assembly layout When mating with J320M receptacle J300 SERIES/J320T (16.2) (16.2) A B When mating with J320S receptacle modular (28.4) (28.2) Top entry type J300 SERIES/J330 B (34) (33.8) A A Wire-to-wire Free hanging type / Panel mounting type B B A A (40.4) B (17.7) B A (16.2) B Side entry type A (17.7) Wire-to-board A B (16.2) B A (40.6) 20 J300 SERIES/J320M Receptacle housing A Line No. 14.17 A B 7.62 J300 SERIES/J320T XX YY XY B XX 12 XX YY XY 16.4 22.8 Keying No. Series name YY XY 10 20 XX 2 3 Circuit No. JST 4 Dimensions (mm) A B C Q’ty /bag 10.16 19.24 29.16 100 10.16 19.24 29.16 100 10.16 19.24 29.16 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 20.32 29.40 39.32 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 25.40 34.48 44.40 100 45.72 54.80 64.72 84(box) Material and Finish J300 SERIES/J330 J-3 1 Model No. F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY F32FMS-10V-KXX F32FMS-10V-KYY F32FMS-10V-KXY F32FMS-12V-KXX F32FMS-12V-KYY F32FMS-12V-KXY F32FMS-20V-KXX XX 6 14.77 5.08 No. of Keying circuits 5 Glass-filled PBT, UL94V-0, black C RoHS2 compliance Tab housing (Free hanging type) C No. of Keying circuits Line No. F32MDF-06V-KXX F32MDF-06V-KYY F32MDF-06V-KXY F32MDF-12V-KXX F32MDF-12V-KYY F32MDF-12V-KXY YY 16.4 16.97 20.32 7.62 X X B X A X XX 6 XY XX 12 5.08 YY XY Keying No. A Model No. Dimensions (mm) A B C Q’ty /bag 10.16 24.16 28.11 100 10.16 24.16 28.11 100 10.16 24.16 28.11 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 25.40 39.40 43.35 100 Material and Finish B 4.0 5.0 Glass-filled PBT, UL94V-0, black RoHS2 compliance 33.6 Series name Circuit No. J-320 3 2 1 Tab housing (Panel mounting type) E D Line No. No. of circuits Keying 5.08 16.4 16.97 20.32 7.62 X X X 2-φ B 3.5 A X XX XY 12 YY XY 20 B XX F32MDP-06V-KXX F32MDP-06V-KYY F32MDP-06V-KXY F32MDP-12V-KXX F32MDP-12V-KYY F32MDP-12V-KXY F32MDP-20V-KXX A Dimensions (mm) B C D E Q’ty /bag 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 10.16 24.16 25.00 33.00 41.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 25.40 39.40 41.00 49.00 57.91 100 45.72 59.72 61.00 70.00 78.23 42(box) 4.0 5.0 Material and Finish 33.6 Glass-filled PBT, UL94V-0, black Series name 2 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. Circuit No. J-320 3 1 D ±0.05 8.95 ±0.3 17.9 ±0.3 C ±0.3 Connector outline 21 YY XX Keying No. A 6 Model No. φ3 .6 4-R Panel layout 0.5 ±0 (M .1 AX ) J300 SERIES/J320M Header (Top entry type) Line No. (1.27) No. of circuits Keying XX 6 A 7.62 16.97 Keying No. XX 10 XX 12 4 3 2 5.08 Through-hole 2-φ2.0 ±0.1 5.08 3.175 ±0.05 B ±0.05 Q’ty /box 10.16 16.51 24.16 120 10.16 16.51 24.16 120 10.16 16.51 24.16 120 20.32 26.67 34.32 84 20.32 26.67 34.32 84 20.32 26.67 34.32 84 25.40 31.75 39.40 72 25.40 31.75 39.40 72 25.40 31.75 39.40 72 J300 SERIES/J320T J300 SERIES/J330 ±0.05 ±0.05 1.27 7.62 Copper foil land 2-φ3.0(MIN) B06B-F32MK-GGXXR B06B-F32MK-GGYYR B06B-F32MK-GGXYR B10B-F32MK-GGXXR B10B-F32MK-GGYYR B10B-F32MK-GGXYR B12B-F32MK-GGXXR B12B-F32MK-GGYYR B12B-F32MK-GGXYR Dimensions (mm) A B C Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated (3.175) A φ1.1 ±0.1 Model No. Material and Finish 1 3.8 5 YY XY 21.6 J-320 YY XY Series name Circuit No. YY XY B X X 7.62 X X C RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. Connector outline ±0.05 PC board layout Connector mounting side Header (Side entry type) (3.81) A 7.62 5.08 0.82 3.8 YY 18.47 16.97 X 7.62 X X X XY 8 Line No. Series name XY XX B Keying No. XX 6 A 3.34 5.08 No. of circuits Keying 10 YY XY XX 12 YY J-320 27.18 XY Circuit No. Model No. S06B-F32MK-GGXXR S06B-F32MK-GGYYR S06B-F32MK-GGXYR S08B-F32MK-GGXYR S10B-F32MK-GGXXR S10B-F32MK-GGYYR S10B-F32MK-GGXYR S12B-F32MK-GGXXR S12B-F32MK-GGYYR S12B-F32MK-GGXYR Dimensions (mm) A B C Q’ty /box 10.16 17.78 24.16 80 10.16 17.78 24.16 80 10.16 17.78 24.16 80 15.24 22.86 29.24 64 20.32 27.94 34.32 56 20.32 27.94 34.32 56 20.32 27.94 34.32 56 25.40 33.02 39.40 48 25.40 33.02 39.40 48 25.40 33.02 39.40 48 Material and Finish 5 4 3 2 1 C Connector outline 7.62 ±0.05 Copper foil land 2-φ4.0 (MIN) Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note:1. Contact JST about the headers supplied in magazine stick. 2. Contact JST about 0.76 µm gold-plated product and tin-plated product. 5.08 ±0.05 Through-hole 2-φ3.0 ±0.1 5.08 ±0.05 3.81±0.05 φ1.1 ±0.1 B ±0.05 PC board layout Connector mounting side 22 J300 SERIES/J320M Keying J320M series have mis-insertion preventive keying. Available in 3 types - XX-Keying, YY-Keying and XY-Keying. (Headers viewed from the mating side are shown below.) J300 SERIES/J320T XX-Keying YY-Keying X Line B Y Line A X Indication of keying Y Line B Key rib Y X Line B X J300 SERIES/J330 Line A Y Indication of keying Y Key rib Y X Line A X Key rib Indication of keying XY-Keying List of combinations With the combination of the J320M headers and the J320M/J320S receptacle housings, the following modular combinations are possible. Tab housing Receptacle housing X V-KX Free hanging type Y-Keying J-3 20 Top entry type Free hanging type F32MSF- V-KY Panel mounting type Panel mounting type F32MSP- V-KY Side entry type 20 F32MDF- V-KXX Panel mounting type F32MDP- V-KXX Y X 20 J-3 YY-Keying Y Y Y Y V-KYY B A Free hanging type Free hanging type F32MDF- V-KYY Panel mounting type F32MDP- V-KYY J-3 20 A B Top entry type 20 J-3 Note: Number of circuits is indicated in ■■. 23 X X Y Y V-KXY XY-Keying 20 F32FMS- Top entry type B B-F32SK-GGYR Side entry type S B-F32SK-GGYR B B-F32MK-GGXXR Side entry type S B-F32MK-GGXXR J-3 XY-Keying Y-Keying Dual-row Dual-row XX-Keying XX-Keying 6,12,20 circuits 6, 8,10,12 circuits Free hanging type (J320M) Top entry type (J320M) X X X Y J-3 V-KXX YY-Keying F32FMS- Y-Keying B B-F32SK-GGXR Side entry type S B-F32SK-GGXR 20 V-KY XX-Keying F32FMS- F32MSF- V-KX Panel mounting type F32MSP- V-KX J-3 F32FSS- Dual-row 6,10,12,20 circuits (J320M) Single-row X-Keying Single-row X-Keying 3, 4 circuits 3, 4, 5, 6 circuits Free hanging type (J320S) Top entry type (J320S) 20 F32FSS- X X-Keying J-3 Single-row 3, 4, 5, 6 circuits (J320S) Header YY-Keying Top entry type B B-F32MK-GGYYR Side entry type S B-F32MK-GGYYR XY-Keying Free hanging type Top entry type Panel mounting type F32MDF- V-KXY Side entry type B B-F32MK-GGXYR Panel mounting type Side entry type F32MDP- V-KXY S B-F32MK-GGXYR J300 SERIES/J320T Assembly layout When mating with J320S receptacle J300 SERIES/J330 When mating with J320M receptacle (39.1) Side entry type C B B A (25.3) Wire-to-board C B A (25.3) (39.3) A 24 J300 SERIES/J320T Receptacle housing Single-row type • 3 circuits No. of circuits J300 SERIES/J330 3 10.16 Keying Model No. Q’ty/bag X F32FSS-03V-KX F32FSS-03V-KY 200 Y 5.08 7.15 6.55 Material Glass-filled PBT, UL94V-0, black RoHS2 compliance 16.4 Keying No. X J-3 1 2 Circuit No. 22.8 19.24 Series name 200 JST 3 29.16 No. of circuits Dual-row type • 6 circuits 6 10.16 5.08 Keying Model No. Q’ty/bag XX F32FMS-06V-KXX F32FMS-06V-KYY F32FMS-06V-KXY 100 YY XY Line No. 100 100 14.77 14.17 A B 7.62 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance 19.24 16.4 22.8 Keying No. Series name XX J-3 2 1 Circuit No. JST 3 29.16 No. of circuits 17.78 ±0.5 (0.82) 5.08 ±0.05 Header (Side entry type) 3.81 ±0.5 Circuit No. 5.08 ±0.5 φ1.1±0.1 1 7.62 32.26 J-320 ±0.05 2 5.08 Connector outline 24.16 X X A X X 5.08 (3.81) 26.09 B 7.62 X 7.62 X 24.59 Keying No. 3.34 XYX RoHS2 compliance This product displays (LF)(AU) on a label. Note:Contact JST about 0.76 µm gold-plated product and tin-plated product. C 7.62 42 XXY 42 42 42 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 3.8 (0.82) Q’ty/box S09B-F32TK-GGXAR S09B-F32TK-GGXBR S09B-F32TK-GGXCR S09B-F32TK-GGXDR YYX Series name Line No. Model No. XXX Material and Finish Through-hole 2-φ3 ±0.1 PC board layout Connector mounting side 25 3 Copper foil land 2-φ4 (MIN) 9 Keying J300 SERIES/J320T Keying J320T series have mis-insertion preventive keying. Available in 4 types - XXX-Keying, XXY-Keying, XYX-Keying and YYX-Keying. (Headers viewed from the mating side are shown below.) J300 SERIES/J330 Line A Line A Line A Line A Line B Indication Line B of keying Indication Line B of keying Indication Line B of keying Line C Line C Line C Line C Key rib XXX-Keying Key rib XXY-Keying Indication of keying Key rib XYX-Keying Key rib YYX-Keying List of combinations With the combination of the J320T headers and the J320S/J320M receptacle housings, the following modular combinations are possible. Receptacle housing Single-row 3 circuits (J320S) X-Keying F32FSS-03V-KX Header Triple-row 9 circuits (J320T) XXX-Keying S09B-F32TK-GGXAR Y-Keying XXY-Keying F32FSS-03V-KY S09B-F32TK-GGXBR F32FMS-06V-KXX 20 XX-Keying J-3 Dual-row 6 circuits (J320M) XYX-Keying S09B-F32TK -GGXCR YY-Keying F32FMS-06V-KYY B A YYX-Keying XY-Keying S09B-F32TK-GGXDR F32FMS-06V-KXY 26 J300 SERIES/J330 Assembly layout Specifications 11 1 (A) 11 Wire-to-board 1 21 21 ・ Current rating: AC/DC (47.7) * In using the products,refer to “Handling Precautions for Terminals and Connectors” described on our website (Technical documents of Product information page). * Dimensional unit : mm * RoHS2 Compliance * Contact JST for details. No. of circuits #14 30 8.5 40 8.5 Unit: A Wire size (AWG) #16 #18 7.0 5.5 7.0 5.5 #20 Dimensions (mm) A 4.0 27.2 4.0 34.9 ・ Voltage rating: 600 V AC/DC ・ Temperature range: -55℃ to + 105℃ (including temperature rise in applying electrical current) ・ Contact resistance: Initial value/ 5 mΩ max. After environmental tests/ 10 mΩ max. ・ Insulation resistance: 1,000 MΩ min. ・ Withstanding voltage: 2,200 VAC/minute ・ Applicable wire: AWG #28 to #14 Receptacle housing (Reverse type Panel mounting type) No. of Keying circuits 85.2 76 Keying No. X φ3 .5 40 11 1 1 2 3 4 5 6 7 8 9 10 X 4.4 7 6 5 4 3 2 1 1 11 21 E (F) 54.4 (59.4) φ 4 -±0 R1MAX Dimensions (mm) C D E F Q'ty /box G 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 22.0 15.4 31.9 29.5 23.3 28.3 30.3 56 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 29.7 23.1 39.6 37.2 310 36.0 38.0 12 29.7 23.1 39.6 37.2 31.0 36.0 38.0 12 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Unlisted in UL/TÜV. Connector outline G A ±0.1 ±0.3 0 .2 B Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) 40.6 (18.2) 21 8 A Material and Finish Series name 9 Z (D) J-330 10 Y W C (66.4) Circuit No. Y Z (B) 7.7 A 5.4 (48.6) Keying No. F33FRTPA-30V-KX F33FRTPA-30V-SY F33FRTPA-30V-EZ F33FRFPA-40V-KX F33FRFPA-40V-SY F33FRFPA-40V-EZ F33FRFPA-40V-MW X 30 Circuit No. Model No. 67.2 ±0.3 76 ±0.1 Panel layout Tab housing (Reverse type) No. of circuits (69.6) Circuit No. Series name (64.6) 30 1 2 3 4 5 6 7 8 10 28 38.6 9 JST Circuit No. 9 8 7 6 5 4 3 2 X F33MRTS-30V-KX F33MRTS-30V-SY F33MRTS-30V-EZ F33MRFS-40V-KX F33MRFS-40V-SY F33MRFS-40V-EZ F33MRFS-40V-MW Y X X 10 Model No. Z J -3 Keying No. Keying 1 1 11 A 56 21 40 Y Z W Dimensions (mm) A B Q’ty /box 24.9 15.4 64 24.9 15.4 64 24.9 15.4 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 32.6 23.1 64 7.7 (B) Material and Finish 5.4 (48.6) 27 Glass-filled PBT, UL94V-0, X-Keying (black), Y-Keying (white), Z-Keying (blue), W-Keying (green) RoHS2 compliance Note: Unlisted in UL/TÜV. J300 SERIES/J340F Assembly layout D (33.7) J300 SERIES/J350D D Side entry type C C B B A A J-3 Wire-to-board JST (40.4) Receptacle housing • 12 circuits No. of circuits Keying Model No. Q’ty/bag 12 ̶ F34FFC-12V-K F34FFC-20V-K 100 ̶ 20 Material and Finish Line No. 12.22 100 15.24 C J-3 B 5.08 3.81 D J300 SERIES COMMON TYPE/J350D RoHS2 compliance 30.1 (32.71) JST Glass-filled PBT, UL94V-0, black A 16.4 7.62 Series name 22.8 • 20 circuits Line No. 15.24 C J-3 B 5.08 3.81 D A 16.4 22.8 15.24 J300 SERIES COMMON TYPE/J360T 30.1 (32.71) JST 19.84 Series name Series name 7.62±0.05 Copper foil land φ4 (MIN) Model No. 12 ̶ SC12B-F34FK-GGR SC20B-F34FK-GGR ̶ Dimensions (mm) Q’ty/box A B 7.62 15.02 63 15.24 22.64 42 J300 SERIES/KEYING BLOCK Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated J-340 B 3.81 Keying Material and Finish Through-hole φ3 ±0.1 Connector outline PC board layout Connector mounting side No. of circuits 20 33.53 (0.82) RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 µm gold-plated product and tin-plated product. A 5.08 D C A (0.82) 3.81 7.62 3.8 3.34 B 31.59 Line No. 30.09 3.81 φ1.1±0.1 Circuit No. 1 3.81 ±0.05 2 A±0.5 3 ±0.05 Header (Side entry type) J300 SERIES/J380D (for keying block) 28 J300 SERIES/J350D Assembly layout (21.4) A B A A A B B (22.9) J300 SERIES COMMON TYPE/J350D J-3 B (28.6) J-3 Wire-to-board (34.2) (40.6) J300 SERIES COMMON TYPE/J360T B B A J-3 A (21.4) Wire-to-wire *When mating with receptacle housing (2-circuit) J300 SERIES/KEYING BLOCK J300 SERIES/J380D (for keying block) 29 J300 SERIES/J350D Receptacle housing • 4 circuits • 6 circuits 22.8 5.08 5.08 Line No. 16.4 Series name 22.8 5.08 J300 SERIES COMMON TYPE/J360T 24.9 22.8 Line No. 16.4 5.08 Series name 45.72 22.8 (19.98) B J-3 A 16.4 17.38 (19.98) 17.38 B A J-3 5.08 50.3 5.08 5.08 Series name 22.8 • 20 circuits • 10 circuits 20.32 Line No. 16.4 10.16 (19.98) A J-3 B (19.98) A Series name 17.38 Line No. 16.4 J300 SERIES COMMON TYPE/J350D B 5.08 (20.7) 14.74 J-3 4.88 17.38 J-3 A B 5.08 9.96 17.38 • 2 circuits Line No. Series name No. of circuits Keying Model No. Q’ty/bag 2 ̶ ̶ 6 ̶ F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K 200 4 10 200 200 J300 SERIES/KEYING BLOCK ̶ 100 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance J300 SERIES/J380D (for keying block) 30 J300 SERIES/J350D Tab housing (Free hanging type) Circuit No. 32.48 No. of circuits Keying Model No. Q’ty/box 12 ̶ F35MDF-12V-K 50 Material and Finish 6 5 4 3 2 1 J-350 Glass-filled PBT, UL94V-0, black 4 33.6 Series name 5 RoHS2 compliance Note: Unlisted in TÜV. 32.48 J300 SERIES COMMON TYPE/J350D 25.4 3 4 5 6 B A 18.17 2 Line No. 13.78 1 Circuit No. 21.52 18.17 5.08 5.08 36.43 Tab housing (Panel mounting type) Series name 2-φ3.6 43 ±0.1 No. of circuits ±0.05 12 ±0.3 J300 SERIES COMMON TYPE/J360T 33.4 ±0.3 5 4 3 2 1 4 19.2 J-350 33.6 Q’ty/box F35MDP-12V-K 41 ±0.3 6 Connector outline 32.48 5 Model No. ̶ 9.6 Circuit No. Keying 4-R0.5 (MAX) Panel layout RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Unlisted in TÜV. 25.4 5.08 3 4 5 6 B 18.17 2 13.78 1 2-φ3.5 21.52 18.17 5.08 Circuit No. J300 SERIES/KEYING BLOCK 43 A Line No. 52 J300 SERIES/J380D (for keying block) 31 Material and Finish Glass-filled PBT, UL94V-0, black J300 SERIES/J350D Header (Top entry type) No. of circuits Keying Model No. Connector outline 12 ̶ Copper foil land φ3(MIN) 20 ̶ BC12B-F35DK-GGR BC20B-F35DK-GGR 5 4 3 2 1 21.6 6 32.48 56 45.72 52.80 32 7 8 9 10 RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 µm gold-plated product and tin-plated product. J300 SERIES COMMON TYPE/J350D J-3 5 0 (4.78) 5.08 ±0.05 7 8 A Q’ty/box 25.40 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Series name 9 5.08 ±0.05 Dimensions (mm) A B Material and Finish Circuit No. 10 φ1.1±0.1 3.81±0.05 Through-hole φ2 ±0.1 (3.54) ±0.05 PC board layout Connector mounting side B A 5.08 B 18.17 5.08 3.81 3.8 2 3 4 5 6 A 5.08 1 3.8 Line No. J300 SERIES COMMON TYPE/J360T Header (Side entry type) Circuit No. No. of circuits Series name 10 9 8 7 27.18 Keying Model No. 4 ̶ 12 ̶ 20 ̶ SC04B-F35DK-GGR SC12B-F35DK-GGR SC20B-F35DK-GGR Dimensions (mm) A B Q’ty/box 5.08 12.16 152 25.40 32.48 56 45.72 52.80 32 6 5 4 3 2 1 J-3 5 0 Material and Finish B A A 5 6 7 B 5.08 7.62 12, 20 circuits (0.82) φ1.1±0.1 Copper foil land 2-φ4 (MIN) Through-hole 2-φ3 ±0.1 Connector outline PC board layout Connector mounting side 12, 20 circuits 10 1 (3.54) 5.08 ±0.05 7.62 ±0.05 5.08 ±0.05 A±0.05 9 2 4 circuits RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 µm gold-plated product and tin-plated product. J300 SERIES/KEYING BLOCK A±0.05 (3.54) 2.54 ±0.05 Copper foil land φ4 (MIN) Through-hole φ3 ±0.1 J300 SERIES/J380D (for keying block) (0.82) (0.82) 3.8 A 8 3.34 4 3.8 3 3.34 2 18.17 19.67 1 5.08 5.08 5.08 18.17 19.67 Line No. Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated Connector outline PC board layout Connector mounting side 4 circuits 32 J300 SERIES/KEYING BLOCK Keying block Keying Model No. Q'ty/bag X J3KF-VR-X J3KF-VY-Y J3KF-VE-Z J3KF-VS-W J3KM-VR-X J3KM-VY-Y J3KM-VE-Z J3KM-VS-W 1,000 Y For receptacle housing Z J300 SERIES/J380D (for keying block) W X Y For header housing Z Keying No. 10.4 W 22.4 1,000 1,000 1,000 1,000 1,000 1,000 1,000 Material and Finish 3.7 Glass-filled PBT, UL94V-0, X-Keying (red), Y-Keying (yellow), Z-Keying (blue), W-Keying (white) RoHS2 compliance Note: Unlisted in UL / TÜV. Keying No. JST 8.6 4.7 21.3 Features Mis-mating prevention keying block can be freely mounted to keying block space. Variation of keying Y-Keying (yellow) X-Keying (red) ・1  6 types of keying can be provided by mounting 4 types of keying block to 2 keying block spaces. ・ Since a color varies on each type of keying, the kind of keying is easy to recognize. Z-Keying (blue) W-Keying (white) For header housing For receptacle housing How to use keying block (When using J380D) Side entry type Header 1 Keying block (for header housing) Space for keying block 11 10 9 8 7 6 5 4 3 2 Space for keying block JS X T 23 22 21 20 19 18 17 16 80 J-3 Mounting 15 14 13 12 Keying block (for receptacle housing) X-Keying Mounting JS Y T Y-Keying Receptacle housing JS Z T Z-Keying 1 W-Keying T B JS Y T A Detachable keying block 22 JS 23 80 J-3 Space for keying block 3 23 18 10 Keying block 22 22 19 11 12 21 21 20 12 02 20 Space for keying block 33 13 19 14 17 18 18 19 2 17 15 13 17 16 Mounting 11 12 12 13 11 3 7 7 4 6 6 5 5 6 4 5 7 4 8 3 3 9 2 2 2 1 1 JS W T Mounting J-3 J300 SERIES/J380D (for keying block) Assembly layout (14) B A (34.6) Wire-to-board (14.4) (28.6) A B B A A B Receptacle housing No. of Keying circuits C B 11.3 A 5.08 20 ̶ 40 ̶ F38FDS-20V-KE F38FDS-40V-KE Dimensions (mm) A C B Q’ty /bag 68.3 58.9 45.72 100 106.4 97.0 83.82 60 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance This product displays (LF)(AU) on a label. Note: Unlisted in UL / TÜV. 16.4 Series name J-3 22.8 B JST 1 Circuit No. 13.45 Line No. 3.81 Model No. 2 3 4 5 6 7 11 12 13 17 18 19 20 21 22 23 (A) 34 J300 SERIES/J380D (for keying block) Header (Top entry type) 92 83.82 3.8 Model No. Q’ty/box 40 ̶ B04B-F38DK-GGER 24 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated 23 22 21 20 19 18 17 7 6 5 4 3 2 1 13 12 11 21.6 Keying 3.8 Series name 3.81 No. of circuits J-380 Circuit No. 99.6 Line No. 83.82 RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about 0.76 µm gold-plated product and tin-plated product. 2. Unlisted in UL / TÜV. (3.8) 92 ±0.05 83.82 (4.55) 22.86 ±0.05 ±0.05 ±0.05 4.09 ±0.05 15.24 ±0.05 ±0.05 ±0.1 φ1.1 22.86 15.24 2-φ2 3.81 ±0.05 5.08 ±0.05 ±0.05 ±0.1 Connector outline PC board layout Connector mounting side 2.54 5.08 5.08 (2.54) A B 13.6 3.81 Header (Side entry type) Circuit No. No. of Keying circuits Series name 27.54 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 J-380 (0.82) ±0.05 3.81 D±0.05 C B B±0.05 (2.85) C ±0.05 5.04 ±0.05 ±0.05 15.24 ±0.05 15.24 PC board layout Connector mounting side 35 D±0.05 φ1.1±0.1 2-φ3 ±0.1 9.9 ±0.05 3.81 ±0.05 3.81 3.4 9.9 3.81 3.34 A (0.82) 5.08 14 B ̶ S20B-F38DK-GGER S40B-F38DK-GGER 61.5 Dimensions (mm) B D C 99.6 55.8 45.72 3.81 93.9 83.82 22.86 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated C 3.81 ̶ 40 A Material and Finish A Line No. 20 Model No. Connector outline RoHS2 compliance This product displays (LF)(AU) on a label. Note: 1. Contact JST about 0.76 µm gold-plated product and tin-plated product. 2. Unlisted in UL / TÜV. Q’ty /box 120 72 J300 SERIES COMMON TYPE/J350D Dual-row Common type (J350D) Unit: A Wire size (AWG) #14 #16 #18 #20 Remark Contact for common connection Tab side J300 SERIES COMMON TYPE/J360T 1 2 3 J-3 50 4 5 6 12 - 13.0 11.5 9.5 7.5 12 - 13.0 11.5 9.5 7.5 4 11.25 11.25 11.25 10.0 8.0 12 8.25 8.25 8.25 7.75 6.0 Contact for common connection Tab side 1 2 J-3 50 3 4 5 6 J300 SERIES/KEYING BLOCK Contact for common connection Receptacle side Contact for common connection Receptacle side Header 6 5 J-3 4 Total input current on all circuits Total input current on single-row Contact for common connection Tab side Contact for common connection Tab side Circuit figure Circuit Note 1 - 50 3 2 1 J300 SERIES/J380D (for keying block) Tab contact 20 8.0 8.0 8.0 7.25 6.0 12 - 8.25 8.25 7.75 6.0 Tab contact 6 5 4 3 2 1 Tab housing Contact for common connection Receptacle side 35 Normal Receptacle hosuing Appearance J- Receptacle hosuing assembly with common connection Tab side J-3 Receptacle side Current rating ( AC, DC) 0 JS JS ・R  ationalization of wiring is realized by the common connection inside the connector Assembly layout (21.4) A A J-3 B B Direct mounting type (37) *When mating with receptacle housing (2-circuit) T2 T2 - Note: Use only receptacle housing assembly with common cnnection. Specifications ・ Current rating: Refer to the above table. ・ Voltage rating: 600 V AC/DC ・ Temperature range: -55℃ to +105℃ (including temperature rise in applying electrical current) ・ Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. ・ Insulation resistance: 1,000 MΩ min. ・ Withstanding voltage: 2,200 VAC/minute ・ Applicable wire: AWG #28 to #14 * In using the products,refer to “Handling Precautions for Terminals and Connectors” described on our website (Technical documents of Product information page). * Dimensional unit : mm * RoHS2 Compliance * Contact JST for details. 36 J300 SERIES COMMON TYPE/J350D Receptacle housing • 4 circuits • 6 circuits 4.88 22.8 5.08 Series name B A J-3 Series name 16.4 17.38 B A J-3 5.08 Line No. Series name 22.8 16.4 10.16 22.8 Line No. Series name Keying Model No. Q’ty/bag 2 ̶ ̶ 200 4 6 ̶ 10 ̶ F35FDC-02V-K F35FDC-04V-K F35FDC-06V-K F35FDC-10V-K J300 SERIES/KEYING BLOCK 20.32 5.08 No. of circuits (19.98) 5.08 24.9 5.08 Line No. 16.4 22.8 • 10 circuits (19.98) B A J-3 Line No. 16.4 17.38 5.08 (20.7) 17.38 J-3 A B 5.08 J300 SERIES COMMON TYPE/J360T (19.98) 14.74 9.96 17.38 • 2 circuits 200 200 100 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance Receptacle housing assembly with common connection No. of circuits 4.9 Keying Model No. Q’ty/box ̶ F35FDC-00(2-A1D)V-EC 700 J300 SERIES/J380D (for keying block) ̶ Material and Finish (20.7) 17.4 J- 3 A B 5.08 Contact for common connection: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, blue Line No. 22.8 37 Series name RoHS2 compliance Note: 1. Contact JST about 0.76 µm gold-plated product and tin-plated product. 2. Unlisted in UL / TÜV. J300 SERIES COMMON TYPE/J350D Tab housing Assembly 4 No. of circuits Circuit No. 1 3 2 12 30 J-350 Series name 5 4 5 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76µm gold-plated product and tin-plated product. 5. Refer to the top page of J350D (Common type) for circuit figure. 6 5.08 A 5.08 25.4 (6.2) 196 J300 SERIES COMMON TYPE/J360T 18.17 21.6 3 2 P12B-F35DK-GFAR Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Circuit No. 1 Q’ty/box 6 57 44.6 B Model No. ̶ Material and Finish 4 33.08 Line No. Keying ±0.05 44.6 (10.8) 2 - φ4.6 ±0.1 Connector outline Panel layout J300 SERIES/KEYING BLOCK Tab housing (Free hanging type) Circuit No. 32.48 No. of circuits Keying Model No. Q’ty/box 12 ̶ F35MDF-12V-K 50 6 Material 5 4 3 2 1 J-350 Glass-filled PBT, UL94V-0, black 4 33.6 Series name 5 RoHS2 compliance Note: Unlisted in TÜV. J300 SERIES/J380D (for keying block) 32.48 25.4 3 4 5 6 B A 18.17 2 Line No. 13.78 1 Circuit No. 21.52 18.17 5.08 5.08 36.43 Tab housing (Panel mounting type) ±0.05 33.4 ±0.3 12 ±0.3 6 5 4 3 2 1 4 19.2 J-350 33.6 No. of circuits ±0.3 43 2-φ3.6 ±0.1 9.6 Series name Circuit No. Connector outline 5 32.48 4-R0.5 (MAX) Panel layout 25.4 5.08 3 4 43 Q’ty/box F35MDP-12V-K 41 Material and Finish Glass-filled PBT, UL94V-0, black RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Unlisted in TÜV. 5 6 B A 18.17 2 13.78 1 Model No. ̶ 2-φ3.5 21.52 18.17 5.08 Circuit No. Keying Line No. 52 38 J300 SERIES COMMON TYPE/J350D Header (Top entry type) Through-hole φ2 ±0.1 Connector outline φ1.1 (4.78) ±0.1 3.81±0.05 Copper foil land φ3(MIN) No. of circuits Keying Model No. 12 ̶ 20 ̶ BC12B-F35DK-GGR BC20B-F35DK-GGR Series name 6 5 4 3 2 1 21.6 7 8 9 10 5.08 ±0.05 Q’ty/box 25.40 32.48 56 45.72 52.80 32 Material and Finish Circuit No. J300 SERIES COMMON TYPE/J360T 7 8 9 10 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 µm gold-plated product and tin-plated product. J-3 5 0 5.08 ±0.05 Dimensions (mm) A B (3.54) A±0.05 PC board layout Connector mounting side B A 5.08 B 18.17 5.08 3.81 3.8 1 2 3 4 5 6 A 5.08 J300 SERIES/KEYING BLOCK 3.8 Line No. Header (Side entry type) Circuit No. No. of circuits Series name 10 9 8 7 27.18 Keying Model No. 4 ̶ 12 ̶ 20 ̶ SC04B-F35DK-GGR SC12B-F35DK-GGR SC20B-F35DK-GGR 6 5 4 3 2 1 J-3 5 0 J300 SERIES/J380D (for keying block) 5 6 7 5.08 7.62 12, 20 circuits (0.82) ±0.1 φ1.1 Copper foil land 2-φ4 (MIN) Through-hole 2-φ3 ±0.1 Connector outline PC board layout Connector mounting side 12, 20 circuits 39 10 1 (3.54) 5.08 ±0.05 7.62 ±0.05 5.08 ±0.05 A±0.05 9 2 4 circuits A±0.05 (3.54) 2.54 ±0.05 Copper foil land φ4 (MIN) Through-hole φ3 ±0.1 (0.82) (0.82) 3.8 A 8 3.8 4 3.34 3 5.08 2 18.17 19.67 1 B 5.08 18.17 19.67 A 5.08 3.34 Line No. Q’ty/box 5.08 12.16 152 25.40 32.48 56 45.72 52.80 32 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcement: Copper alloy, nickel-undercoated, selective gold-plated B A Dimensions (mm) A B Connector outline PC board layout Connector mounting side 4 circuits RoHS2 compliance This product displays (LF)(AU) on a label. Note: Contact JST about 0.76 µm gold-plated product and tin-plated product. J300 SERIES COMMON TYPE/J360T Triple-row Common type (J360T) Tab side Contact for Contact for Contact for common connection Tab side common connection Tab side common connection Tab side (Panel mounting type) (Direct mounting type) (Direct mounting type) Receptacle housing assembly with common connection Normal Receptacle housing Receptacle side Appearance Circuit figure J300 SERIES/KEYING BLOCK Contact for common connection Tab side J300 SERIES/J380D (for keying block) ・R  ationalization of wiring is realized by the common connection inside the connector Contact for common connection Tab side Contact for common connection Receptacle side Specifications ・ Current rating: AC/DC Receptacle housing (Total input current on single-row) Receptacle housing assembly with common connection (Total input current on all circuits) Unit: A Wire size (AWG) #14 #16 #18 #20 12.0 10.5 8.5 6.5 15.0 13.5 11.5 9.5 ・ Voltage rating: 600 V AC/DC ・ Temperature range: -55℃ to +105℃ (including temperature rise in applying electrical current) ・ Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. ・ Insulation resistance: 1,000 MΩ min. (When using receptacle housing) ・ Withstanding voltage: 2,200 VAC/minute (When using receptacle housing) ・ Applicable wire: AWG #28 to #14 * In using the products,refer to “Handling Precautions for Terminals and Connectors” described on our website (Technical documents of Product information page). * Dimensional unit : mm * RoHS2 Compliance * Contact JST for details. 40 J300 SERIES COMMON TYPE/J360T Assembly layout Panel mounting type Direct mounting type (28.6) B B J-3 A A A J-3 B B J300 SERIES/KEYING BLOCK A (28.6) C C C (36.8) C (36.8) *When mating with receptacle housing (3-circuit) Receptacle housing A No. of circuits Keying Model No. 3 - 9 - 18 - 24 - F36FTC-03V-K F36FTC-09V-K F36FTC-18V-K F36FTC-24V-K J300 SERIES/J380D (for keying block) Dimensions (mm) A 4.9 15.0 30.3 41.2 Q’ty/ bag 200 60 Material and Finish 25.3 (28) RoHS2 compliance Note:9, 18, and 24-circuit products are not approved by UL / TÜV standards. A J-3 6.5 B C Glass-filled PBT, UL94V-0, black Line No. 16.4 22.8 Series name Receptacle housing assembly with common connection 41.2 No. of circuits Model No. Q'ty/bag 21 F36FTC-21(24-C8T)V-KC 60 Material and Finish Contact for common connection: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 25.3 (28) A J -3 6.5 B 6.5 C RoHS2 compliance Note:1. Contact JST about 0.76 µm gold-plated product. 2. Unlisted in UL / TÜV. 5.08 35.56 16.4 22.8 Cross-section of receptacle housing assembly with common connection Line No. Series name Illustration when using Circuit figure wten using Contact for common connection Tab side 1 2 3 4 5 6 7 Inserted the contact for common connection to the right side of receptacle housing 41 * When mating with receptacle housing assemby with common connection Contact for common connection Receptacle side J300 SERIES COMMON TYPE/J360T Common tab housing Assembly Circuit No. 13.55 ±0.3 2-φ3.6 ±0.1 1 30 5 4 4-R0.5 (MAX) C Panel layout ̶ P09B-F36TK-GFR P18B-F36TK-GFR A Dimensions (mm) B C D E Q’ty /box 35.0 26.1 17.8 10.16 18.8 364 50.2 41.3 33.1 25.40 34.1 224 Material and Finish J300 SERIES/KEYING BLOCK RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76 µm gold-plated product and tin-plated product. 5. Refer to the top page of J360T (Common type) for circuit figure. A B Circuit No. Line No. 2 2-φ3.5 3 J300 SERIES/J380D (for keying block) 6.5 B 26.09 C 29.44 1 26.09 ̶ Model No. Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black J-360 Connector outline 9 18 Series name 2 27.1±0.3 B ±0.05 E ±0.3 3 • No. of circuits Keying Panel mounting type A 5.08 D No. of Keying circuits ・ Direct mounting type 2-φ3.6 ±0.1 B ±0.05 ̶ ̶ 24 ̶ P09B-F36TK-GFAR P18B-F36TK-GFAR P24B-F36TK-GFAR A Dimensions (mm) B C D Q’ty /box 35.0 26.1 17.8 10.16 364 50.2 41.3 33.1 25.40 224 60.4 51.5 43.2 35.56 168 4 14.72 ±0.3 Material and Finish 3 2 1 Panel layout Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black 30 J-360 Series name Connector outline 9 18 Model No. Circuit No. C A B Circuit No. Line No. 1 2 RoHS2 compliance Note: 1. Punch holes in the panel. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 4. Contact JST about 0.76 µm gold-plated product and tin-plated product. 5. The directions such as series names of 24-circuit product are different from 9 and 18-circuit products. 6. 24-circuit product is not approved by UL standard. 7. Refer to the top page of J360T (Common type) for circuit figure. 2-φ3.5 3 6.5 26.09 B 29.44 C A 5.08 D 42 JFA CONNECTOR/J300 SERIES Model number allocation Receptacle contact Tab contact S F3 F - 41 GF - P 2.0 Form: S...Strip form, B...Loose piece, L...Loose piece with curled barrels J300 SERIES/J310S Series name S F3 M - 41 GF - M 2.0 N Form: S...Strip form, B...Loose piece L...Loose piece with curled barrels Series name Kind of terminal: F...Receptacle contact Applicable wire: 002...AWG #28 #24, 01...AWG #24 #20, 41...AWG #20 #16, 71...AWG #16 #14 Surface finish: GF...Nickel-undercoated, 0.38 µm selective gold-plated GFA...Nickel-undercoated, 0.38 µm selective gold-plated (A type) GI...Nickel-undercoated, 0.76 µm selective gold-plated GIA...Nickel-undercoated, 0.76 µm selective gold-plated (A type) T...Tin-plated (reflow treatment) Material: P...Copper alloy Kind of terminal: M...Tab contact Applicable wire: 002...AWG #28 41...AWG #20 #24, 01...AWG #24 #20 #16, 71...AWG #16 #14 Surface finish: GF...Nickel-undercoated, 0.3 µm selective gold-plated GI...Nickel-undercoated, 0.76µm selective gold-plated T...Tin-plated (reflow treatment) Material: M...Copper alloy Terminal size Terminal size Sub model No. Receptacle housing J300 SERIES/J310D Tab housing F31 M S F - 03 V - K X F31 F S S - 03 V - K X Series name Type of connector: F...Receptacle housing, FR...Receptacle housing Reverse type Rows: S...Single-row, D....Dual-row with 5.08 mm line pitch M...Double-row with 7.62 mm line pitch T...Triple-row, F....Quadruple-row Mounting arrangement: S...Side locking, C...Center locking, PA...Panel mounting type J300 SERIES/J310M No. of circuits: 1 6, 8 10, 12, 16, 18, 20, 24, 30, 40 Flammability: V...UL94V-0 Color indication: K...Black, S...White, E...Blue, M...Green Keying: X...X-Keying, Y...Y-Keying, Z...Z-Keying, W...W-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, Blank...Without Keying No. E...Space (2 spaces) for Keying block Header B 05 B - F31 S K - GG X R J300 SERIES/J320S PC board mounting direction: B...Top entry type S...Side entry type BC...Top & center locking SR...Side reverse SC...Side & center locking No. of circuits: 2 6, 8 10, 12, 16, 20, 40 Product name: Header Series name J300 SERIES/J320M Rows: S...Single-row D...Dual-row with 5.08 mm line pitch M...Dual-row with 7.62 mm line pitch T...Triple-row F...Quadruple-row Color indication: K...Black, S...White, E...Blue Surface finish: GG...Nickel-undercoated, 0.38 µm selective gold-plated GK...Nickel-undercoated, 0.76 µm selective gold-plated T...Tin-plated (reflow treatment) Keying: X...X-Keying, Y...Y-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, E...Space (2 spaces) for Keying block, XA...XXX-Keying, XB...XXY-Keying, XC...XYX-Keying, XD...YYX-Keying, Blank...Without Keying No. Packaging form: R...Tray, M...Magazine stick J300 SERIES/J320T 43 Series name Type of connector: M...Tab housing, MR...Tab housing Reverse type Rows: S...Single-row, D...Dual-row, T...Triple-row, F...Quadruple-row Mounting arrangement: F...Free hanging, P...Panel mounting S...Side locking, PL...Panel mounting Housing lock No. of circuits: 1 6, 8, 10, 12, 16, 20, 30, 40 Flammability: V...UL94V-0 Color indication: K...Black, S...White, E...Blue, M...Green Keying: X...X-Keying, Y...Y-Keying, Z...Z-Keying, W...W-Keying, XX...XX-Keying, YY...YY-Keying, XY...XY-Keying, Blank...Without Keying No. JFA CONNECTOR/J300 SERIES Model number allocation Receptacle housing assembly Common tab housing assembly F36 F T C - 21 (24-C8T) V - K C P 18B - F36T K - GF A R Series name Type of connector: F...Receptacle housing J300 SERIES/J310S Rows: D...Dual-row, T...Triple-row Mounting arrangement: C...Center locking PC board mounting direction: Panel mounting type The number of receptacle contact that can be mounted to the housing.: 00, 21 No. of circuits Assembly: 9, 12, 18, 24 Indication of Common: 2-A1D...Common circuit is set to No. 1 circuit at each row of A and B. 24-C8T...Common circuit is set to No. 8 circuit at each row of A, B and C. Flammability: V...UL94V-0 Color indication: K...Black, E...Blue, M...Green Surface finish of assembled short circuit terminal : C...Nickel-undercoated, 0.38 µm selective gold-plated : D...Nickel-undercoated, 0.76 µm selective gold-plated Keying block Series name: F35D...J350D, F36T...J360T Color indication: K...Black, M...Green Surface finish: GF...Nickel-undercoated, 0.38 µm selective gold-plated G I ...Nickel-undercoated, 0.76 µm selective gold-plated Mounting arrangement : A...Direct mounting type, AN...Direct mounting without housing cover type Blank...Panel mounting type Packaging form: R...Tray J300 SERIES/J310D J3 K F - V R - X Series name: Panel mounting type Product name: Keying block Type of connector: F...For receptacle housing M...For header housing J300 SERIES/J310M Flammability: V...UL94V-0 Color/Keying indication: R-X...Red/X-Keying, Y-Y...Yellow/Y-Keying, E-Z...Blue/Z-Keying, S-W...Natural (White)/W-Keying J300 SERIES/J320S J300 SERIES/J320M J300 SERIES/J320T 44
F31FSS-03V-KX 价格&库存
很抱歉,暂时无法提供与“F31FSS-03V-KX”相匹配的价格&库存,您可以联系我们找货
F31FSS-03V-KX
    • 1000+4.95000
    库存:8000
    F31FSS-03V-KX
      • 1+7.288131+0.94468
      • 10+4.5420110+0.58873
      • 50+4.0015050+0.51867
      • 100+3.65279100+0.47347
      • 500+3.57432500+0.46330
      • 1000+3.522021000+0.45652
      • 2000+3.495862000+0.45313
      库存:6
      F31FSS-03V-KX
        • 1+5.076851+0.65806
        • 50+4.1409950+0.53675
        • 100+3.62750100+0.47020
        • 300+3.27966300+0.42511
        • 500+3.21341500+0.41652
        • 1000+3.163711000+0.41008
        • 4000+3.122304000+0.40471
        库存:200
