FCF8-20-01-L-47.24-S 数据手册
HIGH-SPEED COST
EFFECTIVE COAX CABLE
(0.80 mm) .0315" PITCH • FCF8/FCS8 SERIES
FCF8
FCF8
Mates:
FCS8
Notes:
Design your full cable
assembly with Samtec’s
High-Speed Cable
Solutionator® at
www.samtec.com/cablebuilder
01
–10, –20, –30
SPECIFICATIONS
Cable:
38 AWG coax
Overmold:
Nylon
Terminal Material:
Phosphor Bronze
Contact Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-25 °C to +105 °C
Current Rating:
1.8 A per pin
(1 pin powered)
NO. OF
POSITIONS
PLATING
OPTION
–L
–“XX.XX”
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Length in Inches
03.00" (76.2 mm)
minimum
GND
GND
A
B
N
01
GND
GND
A
B
–10
(11.85) (19.00)
.467
.748
–20
(19.85) (27.00)
.781 1.063
–30
(27.85) (35.00)
1.096 1.378
(12.55) .494
ALSO AVAILABLE
(2.42)
.095
FCS8
NO. OF
POSITIONS
–10, –20, –30
SPECIFICATIONS
Insulator Material:
Black LCP
Contact Material:
BeCu
Contact Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Shield:
Nickel Plated Phosphor Bronze
-55 °C to +125 °C
Current Rating:
1.8 A per pin
(1 pin powered)
NO. OF
POSITIONS
01
N
Some lengths, styles and
options are non-standard,
non-returnable.
Mates:
FCF8
S
CABLE LENGTH + (16.43) .647
Cable lengths longer than
40.00" (1 meter) are not
supported with S.I. test data.
FCS8
CABLE
LENGTH
A
(7.46)
.294
- 01 -
PLATING
OPTION
S
Other sizes and lengths
(MOQ Required)
A
–L
“X”R
–TR
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
NO. OF
POSITIONS
A
B
C
D
–10
(16.59) .653
(15.56) .613
(10.70) .421
(13.06) .514
–20
(24.59) .968
(23.56) .928
(18.70) .736
(21.06) .829
–30
(32.59) 1.283 (31.56) 1.243
(26.70) 1.051
(29.06) 1.144
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Note:
Some sizes, styles and
non-returnable.
B
(7.48)
.294
C
D
samtec.com?FCF8 or samtec.com?FCS8
F-224 WEB
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FCF8-20-01-L-47.24-S 价格&库存
很抱歉,暂时无法提供与“FCF8-20-01-L-47.24-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+959.404021+123.85102
