HCHCONNECTOR
Board-to-wire
Features
●Miniaturization
Using the short length female terminal, the miniaturization is
realized.
●Surface mounting
Corresponding to the surface mounting (lead-free), mounting
workability is improved.
●Reliability
High reliability ensures by using proven female terminal in the
automotive electrical equipment.
2.54mm pitch, 0.64 unsealed connector for automotive
corresponding to the surface mounting.
Specifications
¡Current rating: 5A AC, DC (0.5mm2, Single circuit)
¡Voltage rating: 50V AC, DC
¡Temperature range: -40°C to +120°C
(including temperature rise in applying
electrical current)
¡Contact resistance: Initial value/10mΩ max.
After environmental testing/20mΩ max.
¡Applicable wire: AVSS
0.3mm2 to 0.5mm2
∗ Compliant with ELV/RoHS.
∗ Contact JST for details.
1
HCH CONNECTOR
Female terminal
Applicable wire range
11.6
Model No.
Conductor
(mm2)
Insulation O.D.
(mm)
Q’ty/reel
SHCM-A03T-P025
0.3 to 0.5
1.4 to 1.8
5,000
Material and Finish
2.5
Copper alloy, tin-plated (reflow treatment)
Female connector
¡4 circuits
12.46
Circuits
Model No.
Q’ty/box
4
HCMPB-04-K
600
9
HCHFB-09-KE
300
14.8
Material
Housing: PBT, black
Retainer: PBT, blue
11
7.95
Housing
2.54
Retainer
3×2.54=7.62
¡9 circuits
(1.3)
7.95
(11.25)
14.8
25.2
2
HCH CONNECTOR
Male connector
¡4 circuits
¡9 circuits
2.54×8= 20.32
3×2.54=7.62
2.54
(8.65)
(8.65)
15
21
21.8
21
15
32.3
8.2
1.95
10.9
8.2
10.7
1.95
10.9
19.6
10.7
21.8
2.54
12.65
25.4
15.9
28.6
Circuits
Model No.
Q’ty/reel
4
SM04B-HCHK-TB
220
9
SM09B-HCHK-TB
220
Material and Finish
Housing: Glass-filled LCP, black
Terminal: Brass, nickel-undercoated, tin-plated
Reinforcing tab: Brass, nickel-undercoated, tin-plated
Note: This product displays (LF)(SN) on a label.
Taping Specifications
¡4 circuits
¡9 circuits
45+2.5
-1
57+2.5
-1
2±0.5
2±0.5
φ380±2
Feeding direction
φ380±2
Feeding direction
3
(φ1
3
(φ1
Feeding direction
28±0.1
1.75±0.1
1.75±0.1
Feeding direction
±0.1
4
2±0.1
φ1.5+0.1
28±0.1
φ1.5+0.1
4±0.1
2±0.1
Carrier tape
26.2±0.1
52.4±0.1
56±0.3
44±0.3
40.4±0.1
20.2±0.1
Carrier tape
Cover tape
Cover tape
Feeding direction
Feeding direction
Carrier tape
The end
part
Connector
160min. mounting part
3
Cover tape leader
Leader
part
100min.
400min.
Carrier tape
The end
part
Connector
Cover tape leader
Leader
part
100min.
400min.
HCH CONNECTOR
PC board layout, Assembly layout
¡4 circuits
¡9 circuits
2.54×8=20.32
4.3±0.05
4.3±0.05
2.54×3=7.62
1.04±0.05
2.54±0.05
1.04±0.05
2.54±0.05
(25.9)
(11.45)
11.2
10
1(PCB Edge)
1(PCB Edge)
10
11.2
(19.1)
3.6
3.6
21.2
33.9
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. The dimensions above should serve as guideline. Contact JST for details.
Crimping machine, Applicator
Crimp applicator MKS-L
Strip terminal
Crimping
machine
Dies
Crimp applicator with dies
SHCM-A03T-P025
AP-K2N
MK/SHCM-A03-025
APLMK SHCM-A03-025
Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
4
很抱歉,暂时无法提供与“HCMPB-04-K”相匹配的价格&库存,您可以联系我们找货
