HIL CONNECTOR
3.3mm pitch/Crimp style Wire-to-wire connectors
Specifications –––––––––––––––––––
• Current rating: 5A AC, DC (2 circuits AWG #18)
• Voltage rating: 300V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: Conductor size/01 type AWG #24 to #20
/21 type AWG #22 to #18
Insulation O.D./01 type 1.3 to 2.5mm
/21 type 1.5 to 2.7mm
(when using retainer for 21 type 1.5 to 2.5mm)
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
This HIL connector is 3.3mm pitch wire-towire connector that has a mechanism to
prevent an incomplete mating when mating
connector.
• Inertia lock mechanism to prevent an
incomplete mating
• Box-shaped contact to prevent the influence
by external forces
• Polarizing key to prevent connector from
mating with incorrect circuits
Note: The current rating varies depending on the number of circuits and the wire
size used in each connector. The table below lists the current rating as a
function of the number of circuits and the wire size.
Current unit: A
Circuits
Wire size (AWG)
#22
#24
2
#18
5
#20
4
3
3
3
4
4
3
2
4
3
3
2
2
6
3
3
2
2
8
3
3
2
2
Assembly layout
List of combinations
Resin color
(Plug/
Receptacle)
Natural
Red
Blue
Polarizing key
pattern
Polarizing key
pattern 1
Polarizing key
pattern 2
Polarizing key
pattern 3
(34.6) Including retainer
(9)
(31.6)
(13.8)
(31.6)
1
Plug
Model No.
Receptacle
Model No.
HILP-( )V-1-S
HILP-( )V-2-R
HILP-( )V-3-E
HILR-( )VF-1-S
HILR-( )VF-2-R
HILR-( )VF-3-E
HIL CONNECTOR
1.2
Contact
Socket contact
1.8
Pin contact
12.7
15.9
4.3
1.9
0.5
4.3
Model No.
Applicable wire
Insulation O.D. (mm)
Q´ty / reel
24∼20
1.3∼2.5
5,000
22∼18
1.5∼2.7
5,000
mm2
AWG #
SHIF-01T-P0.5
0.2∼0.5
SHIF-21T-P0.5
0.3∼0.75
Pin contact
Socket contact
SHIM-01T-P0.5
SHIM-21T-P0.5
Material and Finish
Copper alloy, tin-plated
RoHS compliance
Note: Insulation O.D. is 1.5mm to 2.5mm when using retainer for 21 type barrel size contact.
Applicator
Crimping
machine Crimp applicator
Contact
SHIM-01T-P0.5
SHIM-21T-P0.5
AP-K2N
MKS-L
Dies
Crimp applicator with dies
Applicator
Crimping
Contact
MK/SHIF/M-01-05 APLMK SHIF/M01-05
SHIF-01T-P0.5
MK/SHIF/M-21-05 APLMK SHIF/M21-05
SHIF-21T-P0.5
AP-K2N
MKS-L
Dies
Contact position location numbers
Retainer
Contact position numbers are stamped
Retainer
L JST
I A
I
A
L JST
Receptacle housing
Plug housing
Receptacle housing
Plug housing
L JST
3
A
3
A
2
3
2
1
1
1
L JST
A
A
L JST
L JST
4
1
3
1
1
4
A
L JST
A
4
A
1
5
L JST
7
6
4
8
3
7
2
6
1
5
5
1
5
1
8
4
5
2
2
1
I
6
3
A
2
6
3
6
2
I
L JST
3
7
4
7
3
L JST
4
8
8
5
2
2
4
1
3
4
2
2
1
3
5
3
A
1
3
6
6
A
1
2
3
5
2
3
6
L JST
2
4
4
2
2
1
1
1
1
1
2
2
4
L JST
2
3
2
2
HIL CONNECTOR
Housing
Material: Housing...PA 66, UL94V-0, natural
Retainer...Glass-filled PA 66, UL94V-0, natural
Voltage Current
Circuits rating rating
Receptacle housing (for pin contact)
HILR-02VF-1-S
Q´ty /
bag
9
24.4
Q´ty /
bag
19.1
2
8.6
8.6
1
1
A
A
24.4
L JST
HILP-03V-1-S
Q´ty /
bag
19.1
A
A
3
1
1
A
A
HILP-04V-1-S
4.25
13.8
2
4
1
3
A
A
L JST
24.4
8.9
8.6
1
1,000
8.6
A
2
3
1,000
A
L JST
L JST
4
1,000
L JST
Q´ty / HILS-03V
Q´ty /
bag (commonly used for
bag
3-circuit housing and
6-circuit housing)
HILP-06V-1-S
19.1
4.25
13.8
3A
5
4
3
2
1
11.9
8
6
5
3
2
1
15.2
15.2
I
I
A
A
L JST
Q´ty /
bag
4.25
7
A
2
I
3
6
L JST
4
7
L JST
8
4
13.8
HILS-04V
1
5
L JST
1,000
15.5
11.9
A
A
19.1
A
1
L JST
Q´ty /
bag
500
1,000
I
2
4
24.4
1,000
12.2
A
3
5
L JST
6
A
L JST
L JST
6
3A
500
Q´ty / HILP-08V-1-S
bag
RoHS compliance
Note: Current rating is for use with AWG #18 wire.
3
HILS-02V
Q´ty /
(commonly used for
bag
2-circuit housing and
4-circuit housing)
L JST
19.1
Q´ty /
bag
13.8
300V
Q´ty /
bag
2
11.9
11.9
2
24.4
HILR-08VF-1-S
8
1,000
3A
13.8
300V
1,000
12.2
L JST
L JST
3
L JST
HILR-06VF-1-S
6
HILS-03V
Q´ty /
bag
(commonly used for
6-circuit housing)
4.25
9
1,000
Q´ty /
bag
13.8
300V
1,000
4A
HILR-04VF-1-S
4
1,000
8.9
L JST
L JST
2
L JST
Q´ty /
bag
9
300V
4.25
9
1,000
HILR-03VF-1-S
3
HILS-02V
Q´ty /
bag
(commonly used for
4-circuit housing)
5A
A
300V
HILP-02V-1-S
A
2
Retainer
Plug housing (for socket contact)
1,000
很抱歉,暂时无法提供与“HILP-08V-3-E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1000+0.62119
- 5000+0.59370
