HS16PA-3
HS16PA-3
    HRS(广濑)
    HS16PA-3
HS16PA-3 数据手册
2017/10/27 06:05:31(JST) Hayley North APPLICABLE STANDARD -25 C TO OPERATING TEMPERATURE RANGE RATING C +85 VOLTAGE AC 350 V , DC 500 V CURRENT 7 A C TO -10 STORAGE TEMPERATURE RANGE APPLICABLE CABLE +60 C φ8.5 SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X X X X X X X - X - X - X - X - X - X - X - X - X - X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. ELECTRIC CHARACTERISTICS CONTACT RESISTANCE CONTACT SHALL BE MEASURED AT DC INSULATION RESISTANCE 500 VOLTAGE PROOF 1000 1 5 A m MAX. 1000 V DC. V AC. FOR 1 min. M MIN. NO FLASHOVER OR BREAKDOWN. MECHANICAL CHARACTERISTICS CONTACT INSERTION AND φ2 . 970 DRAWING FOR REFERENCE:This is subject to change without notice WITHDRAWAL FORCES CONNECTOR INSERTION AND    0 - 0.003 INSERTION AND WITHDRAWAL FORCES :1.5 N BY STEEL GAUGE. MEASURED BY APPLICABLE CONNECTOR. INSERTION AND WITHDRAWAL FORCES WITHDRAWAL FORCES LOCKING DEVICE WITH UNLOCK MECHANICAL OPERATION 1000 VIBRATION SHOCK MIN CONTACT RESISTANCE: TIMES INSERTIONS AND EXTRACTIONS. 5 : 40 N MAX. m MAX. FREQUENCY : 10 → 55 → 10(Hz) , ①NO ELECTRICAL DISCONTINUITY OF 10 s. SINGLE AMPLITUDE 0.75 mm, AT 2h, FOR 3 DIRECTIONS. ②NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. IN OPPOSITE DIRECTIONS OF EACH 3 DEMENSION AXIS FOR 3 ① NO ELECTRICAL DISCONTINUITY OF 10 s. TIMES AT 490 m/s2 DURATIONS OF PULSE 11 ms. ② NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. ENVIRONMENTAL CHARACTERISTICS DAMP HEAT EXPOSED AT 40 ℃, 90 TO 95 %, 96 h. ① (STEADY STATE) INSULATION RESISTANCE: 10 MΩ MIN (AT HIGH HUMIDITY). ② INSULATION RESISTANCE: 100 MΩ MIN (AT DRY). ② RAPID CHANGE OF TEMPERATURE TEMPERATURE -55→ R/T(1) → +85 → R/T ℃ NO DAMAGE.CRACK AND LOOSENESS OF PARTS. ① INSULATION RESISTANCE: 1000 MΩ MIN. 1 TIME 30 →10 TO 15→ 30 →10 TO 15 min UNDER 5 CYCLES. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. CORROSION SALT MIST EXPOSED IN 5  SALT WATER SPRAY FOR 48 h. NO HEAVY CORROSION RUIN THE FUNCTION. DRY HEAT EXPOSED AT + 85 ℃ , 96 h. NO DAMAGE,CRACK AND LOOSENESS OF PARTS. COLD EXPOSED AT - 55 ℃ , 96 h. NO DAMAGE,CRACK AND LOOSENESS OF PARTS. RESISTANCE TO SOLDERING SOLDERED AT SOLDERING IRON BIT TEMPERATURE +380±10℃ NO DEFORMATION OF CASE OF EXCESSIVE LOOSENESS HEAT FOR 3 OF THE TERMINALS. SOLDERABILITY SOLDERED AT SOLDERING IRON BIT TEMPERATURE +350±10℃ WETTING ON SOLDER SURFACE. FOR 2 TO 3 s. NO SOLDER CLUSTER. △ 1 +1 0 s. COUNT DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 1 DIS-C-00000966 HY.KISHI HY.KOBAYASHI 16.05.14 REMARK APPROVED HY.KOBAYASHI 15.10.28 NOTE (1) R/T : ROOM TEMPERATURE. CHECKED HY.KOBAYASHI 15.10.28 Unless otherwise specified, refer to JIS C 5402. (IEC60512) DESIGNED HY.KISHI 15.10.28 DRAWN HY.KISHI 15.10.28 Note QT:Qualification Test AT:Assurance Test X:Applicable Test FORM HD0011-2-1 DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. ELC-119230-00-00 HS16PA-3 CL101-0604-0-00 1 △ 1/1 DRAWING FOR REFERENCE:This is subject to change without notice 2017/10/27 06:05:32(JST) Hayley North
HS16PA-3 价格&库存
很抱歉,暂时无法提供与“HS16PA-3”相匹配的价格&库存,您可以联系我们找货
