F-219
TD –108–G–AA
HTS–115–T–C–2
TS –119–G–A–1
(2.54 mm) .100"
TS, TD, HTS SERIES
PRECISION MACHINED TERMINAL STRIPS
SPECIFICATIONS
For complete specifications see
www.samtec.com?TS,
www.samtec.com?TD or
www.samtec.com?HTS
Insulator Material:
Black G.F. Polyester (TS, TD)
Black Liquid Crystal Polymer
(HTS)
Terminal Material:
Brass, except Style G is
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni or
Sn over 100 µ" (2.54 µm) Cu
or 50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
RoHS Compliant:
Yes
Lead-Free Solderable:
Wave only
Mates with:
SS, SD, HSS, SL,
SDL, ESS, ESD
TYPE
STRIP
1
PLATING
OPTION
NO. PINS
PER ROW
LEAD
STYLE
–G
TS
= 20 µ" (0.51 µm) Gold
Except –J & –L are
10 µ" (0.25 µm) Gold
(2.54) .100 x No. of Positions
= Single
Row Terminal
Strip
(2.54)
.100
–T
(2.54)
.100 TYP
= Tin
HTS
= Single Row
High Temp
Terminal Strip
(2.54)
.100
01 thru 32
=TS Series
RECOGNITIONS
(5.08)
.200
For complete scope
of recognitions see
www.samtec.com/quality
01 thru 36
(2.54)
.100
TD
= HTS & TD Series
(2.54)
.100 TYP
= Double Row
Terminal Strip
(2.54)
.100
FILE NO. E111594
Note: Some lengths, styles and options
are non-standard, non-returnable.
–AA
(0.46)
.018
DIA
(1.78)
.070
DIA
(0.46)
.018
DIA
(4.22)
.166
(0.64)
.025
DIA
(4.22)
.166
(1.78)
.070
DIA
(1.32)
.052
(1.32)
.052
(3.96)
.156
±.015
Component No. = T-1R5-
(1.78)
.070 DIA
(0.51)
.020
(1.32)
.052 DIA
(0.46)
.018 DIA
LEAD
STYLE
(DIA) (±.015)
–A
(0.46) (3.96)
.018
.156
–A–1
(0.64)
.025 (5.33)
(0.89) .210
.035
–A–2
Y
X
X
(1.83)
.072
DIA
Y
(2.54)
.100
X
(1.83)
.072
DIA
(12.90)
(1.02) .508
.040 ± .015
(4.75)
.187
(3.18)
.125
± .010
(DIA) (±.015)
–C
(0.46) (3.96)
.018
.156
–C–1
(0.64)
.025 (5.33)
(0.89) .210
.035
–C–2
Y
X
Y
–L–1, –L–2, –L–3
(1.07)
.042
DIA
(3.81)
.150
(7.62)
.300
± .015
LEAD
STYLE
-C Component No. =T-1R2-C-X Component No. =T-1R9-
–J
(4.47)
.176
(0.89)
.035
(3.99)
.157
-A Component No. =T-1R0-A-X Component No. =T-1R7
–G–1
(0.51)
.020 DIA
–C, –C–1, –C–2
–A, –A–1, –A–2
(1.32)
.052 DIA
(0.51)
.020 DIA
Component No. = S-1P1-
(1.07)
.042
(1.83)
.072 DIA
(0.76)
.030
(1.32)
.052
DIA
(0.64)
.025
SQ
Z
Y
Component No. = S-1W1
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
LEAD
STYLE
(DIA)
(±.015)
–L–1
(12.95)
.510
(17.86)
.703
Y
Y
–L–2
(9.14)
.360
(14.05)
.553
–L–3
(6.60)
.260
(11.51)
.453
很抱歉,暂时无法提供与“HTS-101-G-AA”相匹配的价格&库存,您可以联系我们找货
