ZST–113–03–F–D–0735
F-215 (Rev 22MAR16)
HTST–125–01–L–DV
(2.54 mm) .100"
TST, HTST, ZST SERIES
SHROUDED .025" SQ POST IDC HEADERS
Mates with:
IDSD, SMSD
SPECIFICATIONS
For complete specifications
www.samtec.com?TST,
www.samtec.com?HTST or
www.samtec.com?ZST
Insulator Material:
TST, ZST: Black Glass
Filled Polyester
HTST: Natural LCP
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (IDSD/TST):
3.4 A per pin
(1 pin powered per row)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Flammability Rating: UL 94V-O
Withstanding Voltage:
1000 VRMS
RoHS Compliant: Yes
TST
= Cable Strip
LEAD
STYLE
PLATING
OPTION
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
Specify
LEAD
STYLE
from
chart.
= Gold flash on post,
Matte Tin on tail
(Not available on –DV)
(Standard sizes.)
HTST
–F
–L
= High Temp
Cable Strip
(2.92)
.115
(4.19)
.165
(14.35)
.565
–01
–02
–03
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(2.54) .100 x No. of Positions + (7.62) .300
(2.54) .100 x No. of Positions + (5.08) .200
LEAD T/H
STYLE (A)
Processing:
Lead–Free Solderable:
HTST: Yes
TST, ZST: Wave Only
SMT Lead Coplanarity:
(0.10 mm) .004" max (05-15)
(0.15 mm) .006" max (17-36)
NO. PINS
PER ROW
1
TYPE
STRIP
–T
= Matte Tin
02
(2.54)
.100
(2.54)
.100
01
(0.38)
.015
–D
OTHER
OPTION
–D
Surface
Mount
(lead style
–01 only)
(HTST only)
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
–P
–DV
= Pick &
Place Pad
= Double Row
Surface Mount
(lead style
–01 only)
(HTST only)
–TR
= Tape
& Reel
Packaging
–D–RA
= Double Row
Right-angle
(lead style –04
& –05 only)
B
(6.35)
.250
(10.16)
.400
(8.89)
.350
A
LEAD RIGHTSTYLE ANGLE
(B)
–04 (3.30) .130
–05 (5.84) .230
(9.27)
.365
ROW
OPTION
(5.08)
.200
(11.18) .440
(0.64) .025 SQ TYP
–DV
(HTST ONLY)
–D–RA
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
1
ZST
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart.
Matte Tin on tail
BODY
HEIGHT
D
FILE NO. E111594
OTHER
SOLUTIONS
05, 07, 08, 10, 12, 13,
15, 17, 20, 25, 32, 36
• Shrouded board-to-board
headers and stackers to
mate with SSW, SSQ,
ESW, ESQ, SSM and
BCS Series. See TSS,
HTSS and ZSS Series.
(Standard sizes.)
ALSO AVAILABLE
(MOQ Required)
• Other platings & sizes
• Alignment Pins
• Single Row
• Locking Leads
• Polarized
Contact Samtec.
02
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
–T
(2.54)
.100
= Matte Tin
(9.27)
.365
(2.54)
.100
01
(6.35)
.250
(8.89)
.350
(2.29)
.090
MIN
(0.38)
.015
Note: Some lengths, styles
and options are non-standard,
non-returnable. ZST is
non-standard, non-returnable.
–F
(0.64) .025 SQ TYP
(2.54)
.100
–“XXXX”
= Body Height
LEAD
STYLE
–01
–02
–03
–04
–05
–06
–07
–08
–09
C
(OAL)
MAX BODY
HEIGHT
(16.00) .630
(13.72) .540
(18.54) .730
(16.26) .640
(21.08) .830
(18.80) .740
(23.62) .930
(21.34) .840
(26.16) 1.030 (23.88) .940
(28.70) 1.130 (26.42) 1.040
(31.24) 1.230 (28.96) 1.140
(33.78) 1.330 (31.50) 1.240
(36.32) 1.430 (34.04) 1.340
BODY
HEIGHT
C
(OAL)
Note: For added mechanical stability, Samtec
recommends mechanical board spacers be
used in applications with gold or selective
gold plated connectors. Contact
ipg@samtec.com for more information.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
很抱歉,暂时无法提供与“HTST-120-03-F-D”相匹配的价格&库存,您可以联系我们找货
