QUAD ROW
TERMINAL/ SOCKET
2.6
A
(1.27 mm) .050" PITCH • FOLC/MOLC SERIES
FOLC
FOLC
Board Mates:
MOLC
NO. PINS
PER ROW
1
20, 25,
30, 35,
40, 45, 50
MOLC
Board Mates:
FOLC
Q
–L
= Mixed
Technology
OPTION
PACKAGING
–LC
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
–M1 & –M2
Leave blank
for tubes
= Locking
Clip
(Manual
placement
required)
–TR
= Tape & Reel
(–MX only)
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact
Samtec for
quantity breaks)
(–MX only)
(5.59)
.220
No. of positions x (1.27) .050 + (0.51) .020
(4.57)
.180
LEAD
STYLE
C
C
MIXED TECHNOLOGY
THROUGH-HOLE
View complete specifications at: samtec.com?FOLC
MOLC
1
NO. PINS
PER ROW
20, 25,
30, 35,
40, 45, 50
(Standard
sizes)
LEAD
STYLE
–‘X’1
= Through-hole
(Specify from
chart)
–02
= Surface Mount
PLATING
OPTION
Q
–L
FOLC
1RRISRVLWLRQV[
1RRISRVLWLRQV[
MATED
HEIGHT
LEAD STYLE
MATED
MOLC FOLC HEIGHT*
OPTION
–P
THROUGH-HOLE
(1.91) .075
(3.04) .120
= Pick &
Place Pad
(–02 only)
MOLC
–01, –M1
= Locking
Clip
(Manual
placement
required)
= Mixed
Technology
View complete specifications at: samtec.com?MOLC
PACKAGING
Leave blank
for tubes
–TR
= Tape & Reel
(–02 &
–M1 only)
–FR
= Full Reel
Tape & Reel
(must order
max. quantity
per reel;
contact Samtec
for quantity
breaks)
(–02 &
–M1 only)
SURFACE
MOUNT
MIXED
TECHNOLOGY
C
–04, –M2
–LC
= 10 µ"
(0.25 µm)
Gold on
post,
Matte
Tin on tail
–M1
APPLICATIONS
F-224
G b p s
s
PLATING
OPTION
–L1 & –L4
PROCESSING
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
p
= Low Insertion
Force Through-hole
Insulator Material:
Black Liquid Crystal Polymer
Contact Material (FOLC):
BeCu
Terminal Material (MOLC):
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.6 A per pin
(4 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
165 VAC/230 VDC
Insertion Depth (FOLC):
(3.30 mm) .130" to
(4.06 mm) .160"
Max Cycles (FOLC):
100
–01
(5.97) .235
–11
–01
(7.75) .305
–31
(11.43) .450
*Processing conditions
will affect mated height.
LEAD
STYLE
–01 & –04
SPECIFICATIONS
Lead-Free Solderable:
Yes
SMT Lead Coplanarity (MOLC):
(0.10 mm) .004" max (20-25)
(0.15 mm) .006" max (30-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
m
= Through-hole
(Standard
sizes)
8
MAX
LEAD
STYLE
–LC OPTION
A
B
–01
(5.59) .220 (3.38) .133
–11
(7.34) .289
–31
(11.05) .435
(3.66) .144
samtec.com/127mm-TigerEye
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“FOLC-135-L2-S-Q-P”相匹配的价格&库存,您可以联系我们找货
