IPL1-106-01-S-S-RA-K
    SAMTEC(申泰)
    .100 TERMINAL ASSEMBLY
IPL1-106-01-S-S-RA-K 数据手册
F-217 IPL1–106–01–L–D–RE1–K IPL1–110–02–L–S–K IPL1–105–02–L–D–K IPL1–120–01–L–D–RA–K (2.54 mm) .100" IPL1 SERIES DISCRETE WIRE HEADER SPECIFICATIONS For complete specifications www.samtec.com?IPL1 Mates with discrete wire cable assemblies Mates with: MMSD, MMSS, MMSDT, MMSST Insulator Material: Natural LCP Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Voltage Rating: 675 VAC/954 VDC RoHS Compliant: Yes Keyed polarization Align & Latch™ PROCESSING Lead–Free Solderable: Yes –S & –D (–02 Lead Style) SMT Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10) (0.15 mm) .006" max (11-25) –SH SMT Lead Coplanarity: (0.15 mm) .006" max (02-25) RECOGNITIONS NO. PINS PER ROW LEAD STYLE 02, 03, 04, 05, 06, 08, 10, 12, 15, 16, 20, 25 = Throughhole IPL1 1 For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 –01 –02 (Standard sizes) –RE1 APPLICATION = Surface Mount MMSD –01. –02 & –RA = No. of positions x (2.54) .100 + (1.52) .060 –SH & –RE1 = No. of positions x (2.54) .100 + (4.06) .160 (8.76) .345 (7.04) .277 IPL1-RE1 (9.58) .377 (6.10) .240 (5.08) .200 –02–D Note: Some lengths, styles and options are non-standard, non-returnable. (5.59) .220 –02–SH –S = Single Row –SH = Single Row Horizontal (–02 lead style only) –D = Double Row –01–S-RA (6.35) .250 TAIL OPTION –K =Keyed Polarization –RE1 =Right-angle Elevated (–01 lead style only) (–K is a required callout) (6.86) .270 (2.03) .080 (3.05) .120 –01–D (2.16) .085 –01–S –01–S–RE1 (1.02) .040 (8.26) .325 (2.16) .085 (2.54) .100 (8.13) .320 (1.52) .060 (2.54) .100 (2.03) .080 (0.64) .025 SQ –02 –01 –RA K –RA =Right-angle (–01 lead style only) (5.46) .215 (2.54) .100 (7.62) .300 (5.44) .214 –L = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail (2.54) .100 01 02 (8.76) .345 • Other sizes • With or without plug polarization • Guide post holes • Other platings • Weld tab Contact Samtec. ROW OPTION 01 02 (MOQ Required) PLATING OPTION (1.52) .060 –02–S ALSO AVAILABLE Surface mount, right-angle, right-angle elevated and vertical through-hole (2.54 mm) .100" pitch –01–D–RA WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –01–D–RE1
IPL1-106-01-S-S-RA-K 价格&库存
很抱歉,暂时无法提供与“IPL1-106-01-S-S-RA-K”相匹配的价格&库存,您可以联系我们找货
