LCW-109-08-G-S-300
LCW-109-08-G-S-300
    SAMTEC(申泰)
    插件
    线对板针座
LCW-109-08-G-S-300 数据手册
F-211-1 SUPPLEMENT (Rev 23MAY19) LCW–125–11–G–S–300 LCW–115–09–S–S–300–RE (2.54mm) .100" LCW SERIES FRICTION LOCK TERMINAL STRIPS Mates with: SSW, SSQ, ESW, ESQ, IDSS 1 LCW NO. PINS PER ROW LEAD STYLE PLATING OPTION ROW OPTION POST HEIGHT –S –XXX SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?LCW Insulator Material: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27µm) Ni Insulation Resistance: 5000 MW @ 500 VDC Operating Temp Range: -55 °C to 125 °C with Gold -55 °C to 105 °C with Tin Withstanding Voltage: 1000 VRMS @ 60 Hz Current Rating: 3A RoHS Compliant: Yes PROCESSING = Single Row 01 thru 36 (36 positions standard) –L (5.08) .200 (2.54) .100 36 01 (2.54).100 X No. of Spaces (7.87) .310 (2.54) .100 (0.64) .025 SQ TYP Lead–Free Solderable: No = Locking Clip Removed From Each End –G =10µ" (0.25µm) Gold on post, Gold flash on balance (2.54).100 X No. of Positions (2.54) .100 TYP = “C” –RX Specify “230” or “300” standard post length from chart below. –M = 10µ" (0.25µm) Gold on post, Matte Tin on tail OPTION = Right Angle (Specify from chart) –LL = Locking Lead (N/A with Right Angle) ALSO AVAILABLE –S Two leads crimped in opposite direct­ions on or near centerline. (“A”=.300" or less) N/A w/1 or 2 positions Locking Socket = 30µ" (0.76µm) Gold on post, Matte Tin on tail –T –“XX” see www.samtec.com?SSW (Body Style -P) = Matte Tin = Polarized RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality LEAD STYLE FILE NO. E111594 * * – 07 – 08 – 09 –10 –11 –12 –13 –14 * * * –15 –16 –17 –19 – 20 * – 08 – 09 –10 –11 –12 –13 –14 Note: Some lengths, styles and options are non-standard, non-returnable. Right Angle Versions Straight Pin Versions * –15 –19 – 20 TAIL A (2.54) .100 (5.08) .200 (10.16) .400 (12.70) .500 (15.24) .600 (17.78) .700 (22.86) .900 (27.94) 1.100 (7.62) .300 (2.92) .115 (3.81) .150 (25.40) 1.000 (20.32) .800 (3.30) .130 (8.38) .330 (10.92) .430 (13.46) .530 (16.00) .630 (21.08) .830 (16.16) .636 (5.84) .230 (23.62) .930 (18.54) .730 OAL POST B C (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (23.62) .930 (26.16) 1.030 (31.24) 1.230 (5.84) (36.32) .230 1.430 (16.00) .630 (11.30) .445 (12.19) .480 (33.78) 1.330 (28.70) 1.130 (13.46) .530 (18.54) .730 (21.08) .830 (23.62) .930 (26.16) 1.030 (31.24) (7.62) .300 1.230 (36.32) 1.430 (16.00) .630 (33.78) 1.330 (28.70) 1.130 Specify “LEAD STYLE” from chart. -RA LEAD & -RR STYLE TAIL – 09 –10 (5.08) .200 (2.54) .100 –11 –12 –13 –14 C B –15 –19 – 20 – 09 A –10 –11 –12 –13 –14 –15 –19 *Available with –LL (Locking Lead) Option – 20 -RE TAIL A (4.06) .160 (6.60) .260 (9.14) .360 (11.68) .460 (16.76) .660 (21.84) .860 (1.52) .060 (19.30) .760 (14.22) .560 (2.29) .090 (4.83) .190 (7.37) .290 (9.91) .390 (14.99) .590 (20.07) .790 A (6.60) .260 (9.14) .360 (11.68) .460 (14.22) .560 (19.30) .760 (24.38) .960 (4.06) .160 (21.84) .860 (16.76) .660 (4.83) .190 (7.37) .290 (9.91) .390 (12.45) .490 (17.53) .690 (22.61) .890 (2.29) – .090 (20.07) (17.53) .690 .790 (14.99) (12.45) .490 .590 -RP TAIL A (7.62) .300 (10.16) .400 (12.70) .500 (15.24) .600 (20.32) .800 (25.40) 1.000 (5.08) .200 (22.86) .900 (17.78) .700 (5.84) .230 (8.38) .330 (10.92) .430 (13.46) .530 (18.54) .730 (23.62) .930 (3.30) .130 (21.08) .830 (16.00) .630 POST C Specify “LEAD STYLE” from chart. (5.08) .200 (2.54) .100 (5.84) .230 C A REGULAR RIGHT ANGLE X (7.62) .300 OPTION X OPTION X – RA (1.52) .060 (4.06) .160 (0.64) .025 MAX – RR (1.52) .060 (0.64) .025 MAX – RE – RP Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM REVERSE RIGHT ANGLE REGULAR RIGHT ANGLE All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. – PR
LCW-109-08-G-S-300 价格&库存
很抱歉,暂时无法提供与“LCW-109-08-G-S-300”相匹配的价格&库存,您可以联系我们找货
