LPHS-08-32-L-VP1
LPHS-08-32-L-VP1
    SAMTEC(申泰)
    Power Socket Connector, Brass
LPHS-08-32-L-VP1 数据手册
LOW PROFILE, EXTREME HIGH-POWER/SIGNAL COMBO FEATURES & BENEFITS • 30 A per power blade and 1 A per signal pin MAX • Low 7.5 mm profile design (right-angle) for improved system airflow and space savings 30 • Double-stacked power blades per bank for increased density and power A m p s • Ideal for coplanar and perpendicular applications • Rugged guide posts are standard for blind mating assistance • Socket available as vertical with press-fit tails and right-angle through-hole; mates with terminal or standard .062" (1.60 mm) PCB card Standard Creepage* 5.63 mm Standard Clearance* 2.69 mm *Selectively loading contacts achieves customer specific creepage and clearance requrements. Contact asp@samtec.com KEY SPECIFICATIONS (LPHT/LPHS) PITCH INSULATOR MATERIAL (12.00 mm) .472" (pwr) (1.27 mm) .050" (sig) Black LCP TERMINAL MATERIAL PLATING Signal: Brass Au or Sn over Power: Copper Alloy 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE VOLTAGE RATING MATING CYCLES LEAD-FREE SOLDERABLE 40 °C to +105 °C 250 VAC / 500 VDC 250 (MFG Tested) Yes (RT1 & RT2 option) Notes: Series is rated up to 60 A per power bank. Some lengths, styles and options are non-standard, non-returnable. The Molex EXTreme LPHPower™ line is a second source to the Samtec LPHT/LPHS Series. *EXTreme LPHPower™ is a trademark of Molex Incorporated. F-224 samtec.com/extreme-lphpower Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. 30 A SIGNAL/POWER COMBO SYSTEM - SERIES LPHT Terminal POWER POSITIONS - Total, 2 per power bank Total –02, –04, –06, –08, –10 –12, –16, –20, –24, –32 LPHS Socket - SIGNAL POSITIONS - PLATING OPTION - TAIL –L GP –VP1 = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Vertical Press-fit (LPHS only) –RT1 = Right-angle Through-hole (Use with (1.60 mm) .062" thick board) –RT2 = Right-angle Through-hole (Use with (2.36 mm) .093" thick board) LPHT Board Mates: LPHS POWER POSITIONS SIGNAL POSITIONS A (–02) A (–04) A (–06) A (–08) A (–10) –16 (33.97) 1.337 (45.97) 1.810 (57.97) 2.282 (69.97) 2.755 (81.97) 3.227 –20 (36.51) 1.437 (48.51) 1.910 (60.51) 2.382 (72.51) 2.855 (84.51) 3.327 –24 (39.05) 1.537 (51.05) 2.010 (63.05) 2.482 (75.05) 2.955 (87.05) 3.427 –32 (44.13) 1.737 (56.13) 2.210 (68.13) 2.682 (80.13) 3.155 (92.13) 3.627 A (16.28) .641 (7.49) .295 B (5.08) View complete specifications at: samtec.com?LPHT .200 LPHS POWER POSITIONS SIGNAL (18.00) POSITIONS A (–02) .709 B (–02) A (–04) B (–04) A (–06) B (–06) A (–08) B (–08) A (–10) B (–10) Board Mates: LPHT –16 (31.64) 1.918 (25.88) 1.019 (43.64) 1.718 (37.88) 1.491 (55.64) 2.191 (49.88) 1.964 (67.64) 2.633 (61.88) 2.436 (79.64) 3.135 (73.88) 2.909 –20 (34.18) 1.346 (28.42) 1.119 (46.18) 1.818 (40.42) 1.591 (58.18) 2.291 (52.42) 2.064 (77.18) 2.763 (64.42) 2.536 (82.18) 3.235 (76.42) 3.009 –24 (36.72) 1.446 (30.96) 1.219 (48.72) 1.918 (42.96) 1.691 (60.72) 2.391 (54.96) 2.164 (72.72) 2.863 (66.96) 2.636 (84.72) 3.335 (78.96) 3.109 –32 (41.80) 1.646 (36.04) 1.419 (53.80) 2.118 (48.04) 1.891 (65.80) 2.591 (60.04) 2.364 (77.80) 3.063 (72.04) 2.836 (89.80) 3.535 (84.04) 3.309 A B (7.49) .295 (5.08) .200 (18.00) .709 (21.42) .843 -VP View complete specifications at: samtec.com?LPHS -RT samtec.com/extreme-lphpower Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. A F-224
LPHS-08-32-L-VP1 价格&库存
很抱歉,暂时无法提供与“LPHS-08-32-L-VP1”相匹配的价格&库存,您可以联系我们找货
