ZSS–113–03–L–D–0735
F-215
HTSS–125–01–L–DV
(2,54 mm) .100"
TSS, HTSS, ZSS SERIES
SHROUDED .025" SQ POST HEADERS
Mates with:
SSW, SSQ, ESW, ESQ,
SSM, BCS
TYPE
STRIP
1
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
03
Specify
LEAD
STYLE
from
chart.
–F
–D
= Gold flash on post,
Matte Tin on tail
(Not available on -DV)
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
ROW
OPTION
SPECIFICATIONS
For complete specifications
see www.samtec.com?TSS,
www.samtec.com?HTSS or
www.samtec.com?ZSS
Insulator Material:
Black Glass Filled Polyester
(TSS, ZSS)
Natural PCT (HTSS)
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
Flammability Rating:
UL 94V-O
Withstanding Voltage:
1000 VRMS
RoHS Compliant: Yes
TSS
(TSS only)
= Connector Strip
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
HTSS
= High Temp
Connector Strip
LEAD
STYLE
–01
–02
–03
Processing:
Lead–Free Solderable:
Yes (HTSS)
Wave Only (TSS, ZSS)
SMT Lead Coplanarity:
(0,15 mm) .006"
(Standard sizes.)
(2,54) .100 x No. of Positions + (3,81) .150
(2,54) .100 x No. of Positions + (1,27) .050
T/H
(A)
(2,92)
.115
(4,19)
.165
(14,35)
.565
02
–T
–D
–D–RA
LEAD RIGHT
STYLE ANGLE
(B)
–04 (3,30) .130
–05 (5,84) .230
(9,27)
.365
(2,54)
.100
01
–DV
= Double Row
Surface Mount
(lead style
–01 only)
(HTSS only)
= Matte Tin
(2,54)
.100
B
(6,35)
.250
(10,16)
.400
(8,89)
.350
A
–L
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
= Double Row
Right Angle
(lead style –04
& –05 only)
(5,08)
.020
(11,18) .440
(0,38)
.015
(0,64) .025 SQ TYP
–DV
(HTSS ONLY)
–D–RA
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
ZSS
1
NO. PINS
PER ROW
OTHER
SOLUTIONS
• Shrouded IDC headers
and stackers to mate with
IDSD, SMSD Series.
See TST, HTST and
ZST Series.
(Standard sizes.)
(MOQ Required)
• Other sizes
• Other platings
• Alignment Pins
• Single Row
• Locking Leads
• Polarized
Contact Samtec.
02
(2,54)
.100
–T
(2,54)
.100
(6,35)
.250
(8,89)
.350
(2,29)
.090
MIN
(0,64) .025 SQ TYP
(2,54)
.100
–“XXXX”
= Body Height
–L
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
= Matte Tin
(0,38)
.015
Note: Some lengths, styles
and options are non-standard,
non-returnable. ZSS is
non-standard, non-returnable.
Matte Tin on tail
(9,27)
.365
01
BODY
HEIGHT
D
–F
Specify
LEAD
STYLE
from
chart.
03, 05, 07, 08, 10, 12,
13, 15, 17, 20, 25, 32, 36
ALSO AVAILABLE
PLATING
OPTION
LEAD
STYLE
BODY
HEIGHT
LEAD
STYLE
–01
–02
–03
–04
–05
–06
–07
–08
–09
C
(OAL)
MAX BODY
HEIGHT
(16,00) .630
(13,72) .540
(18,54) .730
(16,26) .640
(21,08) .830
(18,80) .740
(23,62) .930
(21,34) .840
(26,16) 1.030 (23,88) .940
(28,70) 1.130 (26,42) 1.040
(31,24) 1.230 (28,96) 1.140
(33,78) 1.330 (31,50) 1.240
(36,32) 1.430 (34,04) 1.340
C
(OAL)
Note: For added mechanical stability, Samtec
recommends mechanical board spacers be
used in applications with gold or selective
gold plated connectors. Contact ipg@
samtec.com for more information.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
